09-02-2014, 11:48 AM | #1 |
Newbie Join Date: Sep 2014 Location: Addison
| Yeti spur gear
Hello all. Newbie here, picked up an yeti this weekend for my son and myself to play with. Lot of smiles & laughing, good time. Unfortunately we stripped the spur gear (ax31065). Local hobby shops do not have the parts in stock, online not much better. I'm looking for advice where to purchase spur gear & slipper pads (ax3106. I talked to Dereck at Axial customer support he said he would send one out when they get them in stock, might be September 15. Hate to wait that long, any suggestions are appreciated.
09-02-2014, 12:06 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
| Re: Yeti spur gear
Seems they are shipping with the mesh too loose. I did the same thing, but was able to tighten up the mesh and keep running. ebay has some, I just bought two of them. http://www.ebay.com/itm/Axial-Racing...item1e9101f150 Associated has a 62t (stock is 64t) that I think will work without any issues. Gear: TowerHobbies.com | Associated Spur Gear 32P 62T Pads: TowerHobbies.com | Associated Factory Team High Torque Slipper Pad Last edited by rm25x; 09-02-2014 at 12:10 PM. |
09-02-2014, 12:42 PM | #3 |
| Re: Yeti spur gear
Rm25x. Thanks for the reply, I will check eBay. I thought parts would be easier to find. Guess the Yeti is still a little to new to have a large parts selection yet. I have the spur gear out, I might try to reinstall and adjust the mesh to keep running it until I get a new one.
09-02-2014, 04:03 PM | #4 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
| Re: Yeti spur gear
I was able to get some from CKRC so that I would already have spares in route by time my Yeti gets across the pond.
09-02-2014, 05:24 PM | #5 |
RCC Addict Join Date: Oct 2009 Location: west coast..
| Re: Yeti spur gear
I also ordered mine frome bay when my yeti does get here Ill have replacements.. I have not been able to find the steel gear anywhere however..
09-02-2014, 07:38 PM | #6 |
| Re: Yeti spur gear
Thanks for all the advice & information. I found some on eBay and ordered them tonight. Can't wait to get the yeti back in good shape.
09-02-2014, 09:37 PM | #7 |
Newbie Join Date: Feb 2014 Location: Bettendorf, Iowa
| Re: Yeti spur gear
I was watching one of Harley's videos, and he said that you should also buy a hardened pinion as well. The steel spur gear will eat up the stock pinion. I don't know where to find a hardened pinion gear though. But I haven't looked very hard either. Robinsons, maybe?
09-02-2014, 11:54 PM | #8 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: Yeti spur gear
If your running the stock motor you will need a 5mm pinion be it a a Robinson Racing or Hot Racing pinion. RPP carries the Robinson Racing pinions.
09-03-2014, 06:52 AM | #9 |
Rock Stacker Join Date: Mar 2008 Location: Queens
| Re: Yeti spur gear
Got mine on eBay after I chewed mine up running it in sand. Just search "32p 64tooth spur". Should pop right up.
09-03-2014, 07:11 AM | #10 |
| Re: Yeti spur gear
Extra Hard High Carbon Steel Motor Pinion 5mm bore / .8 Module Pitch or Extra Hard High Carbon Steel Blackened Finish Motor Pinion 5mm bore / 32 pitch can be used. Robinson Racing Products - Products and Pricing - Brushless Motor Pinion Gears |
09-03-2014, 07:44 AM | #11 |
| Re: Yeti spur gear
I've done some reading on metal versus plastic spur gears. One camp says break the spur as kind if a transmission "fuse". Others say metal all the way. What are pros and cons on the yeti specifically. Is metal the best bet, or I'm I asking for trouble somewhere else?
09-03-2014, 08:42 AM | #12 |
| Re: Yeti spur gear
I plan on sticking with plastic. Quieter and as long as the gear mesh is set right it will hold up well. The slipper clutch is designed to take the shock out of the system.
09-03-2014, 08:54 PM | #13 |
| Re: Yeti spur gear
Just got an email, from eBay. The slipper pads I ordered last night got cancelled. Looks like I'll have 2 spur gears and no slipper pads. Has anyone made homemade slipper pads from a piece of thin leather, and glued them to the spur gear?
09-04-2014, 09:26 PM | #14 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Yeti spur gear Quote:
I have also used a 58 tooth Axial spur gear with great success. | |
09-04-2014, 10:52 PM | #15 |
| Re: Yeti spur gear
I had stripped a gear out on the trail, for a temp fix I installed a random spur gear, using double sided tape instead of slipper pads. Just an option for you guys, do what you have to do to get it back up and running! Tighten up the mesh and wait for a couple key upgrades to become available to fix the stripping woes. |
09-05-2014, 08:42 AM | #16 |
Quarry Creeper Join Date: Mar 2014 Location: San Antonio
| Re: Yeti spur gear
Does anyone have anything other than a plastic motor mount in the works yet?
09-05-2014, 08:54 AM | #17 |
| Re: Yeti spur gear
Axial has a machined one coming, it's listed in the manual on the option parts page. It's also listed on Towers website.
09-05-2014, 09:10 AM | #18 | |
Also you can replace the plastic bushing the spur gear rides on with a 5x11 bearing to help the gear run more true. | |
09-05-2014, 09:22 AM | #19 |
| Re: Yeti spur gear |
09-05-2014, 09:25 AM | #20 |
| Re: Yeti spur gear
Pics or it didn't happen.
Yeti spur gear - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Micro T spur and Micro Crawler spur gear. Same thing? | matts175 | Losi Micro-Rock Crawler | 4 | 10-15-2011 01:18 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
