09-16-2014, 03:51 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
| SLWs with 225??
Will the inside ring clear the nut and bolt on the A arm? I have these other hubs, not sure exactly what they are, that have the same bolt pattern, which seem to bind up... Thanks! |
09-18-2014, 06:11 PM | #2 |
| Re: SLWs with 225??
Anyone??
09-18-2014, 06:20 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I'm running SLW and 350 with a 1/16" spacer (so between a 350 and 475 and still get rubbing). Why does everyone want so narrow in the front? Stability is lost with being narrow. Front wide, rear narrow for some amazing steering is where I'm at. |
09-18-2014, 10:20 PM | #4 |
Newbie Join Date: Sep 2014 Location: MA
| Re: SLWs with 225??
i am running 225's but i had to dremel the stock beadlocks because i have VP exo knuckles
09-18-2014, 10:29 PM | #5 | |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: SLWs with 225?? Quote:
You have to remember not everyone is doing the same as the other guy with this rig. Last edited by SteveC6R; 09-19-2014 at 12:40 AM. | |
09-19-2014, 12:25 AM | #6 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
| Re: SLWs with 225??
you can get Gear Head slw widener rings, so its cheaper than buying new slw hubs if you are unsure of what you want. RPP has them. They step you up 1 size so your 225 become 350's.
09-19-2014, 05:49 AM | #7 | |
I still would rather have steering and stability for a G6 as much as for bashing and racing. Take a second slow down, squeeze in between the gates, more go power. | |
09-19-2014, 10:21 AM | #8 |
| Re: SLWs with 225??
Thanks for the answers y'all! I'll just go wide, it looks kinds funny, but I'll live
09-22-2014, 07:22 PM | #9 |
| Re: SLWs with 225??
And so will it clear with the 350? And what about the vanquish knuckles? Will they clear with the slw wheels and 350s?
09-22-2014, 07:59 PM | #10 | |
As narrow as possible is how I have mine setup and there is no more steering to be had out of any of the components. For anything in the rocks, I want this truck set to it's narrowest setting. | |
09-22-2014, 08:09 PM | #11 |
A wider front track with a narrower rear track will give more steering by changing the rear inner tire acting as a pivot. This is used in RC and full size racing. Won't help on slow speed turns, does help in fast corners. I'm still building the Yeti to be a U4 racer that will handle G6's. It's not a rock truck exactly, I'll use the other toys for pure rock crawling. |
09-22-2014, 08:14 PM | #12 |
Rock Crawler Join Date: May 2012 Location: Washougal
| Re: SLWs with 225??
I agree with Harley on the track width. I have the .7 wide slws on mine right now with a 225 hubs and it just clears. With a 1" wheel I would run a 475 hub. I wouldn't want to run hub spacers on a heavy go fast rig like this but that's just me. |
09-22-2014, 09:43 PM | #13 |
| Re: SLWs with 225??
Do you think the 475s are the narrowest hubs for a 1" slw that will clear the inner ring with stock knuckles? What about once I upgrade to vp knuckles any strc carriers ? |
09-22-2014, 09:55 PM | #14 |
| Re: SLWs with 225?? You can remove the lower screw and nut from the outer hinge pin and go to a captured setup like the EXO used. This will improve your clearances a little.
09-22-2014, 10:02 PM | #15 | |
