Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Best aluminum rear axle for u4 on yeti
Old 10-07-2014, 08:30 AM   #21
Default Re: Best aluminum rear axle for u4 on yeti
I've had a lot of runs on my Yeti lately and i've bent the rear axle shafts left and right more than once. Will aluminum axle housings help me prevent bending shafts again?
dextan22 is offline   Reply With Quote
Old 10-07-2014, 09:08 AM   #22
I would think so if u went with a non lockout type like a gcm
AWraith build is offline   Reply With Quote
Old 10-07-2014, 09:10 AM   #23
I would love to see a slow mo vid of the amount of twist under load on the whole rig.
Old 10-07-2014, 09:31 AM   #24
binaryterror's Avatar
Actually no...to stop bending shafts you need to get better shafts. When mine become bent bad enough I care, I'll be talking to Creeperbob about his axles.
The GCM offers no more support than the stock set up or any of the VP's.
The shafts bend where they are cross drill for the hex pin, or at the threaded portion. Both happen more if you aren't constantly checking the tightness of the wheel nuts - but with happen anytime as well.
binaryterror is offline   Reply With Quote
Old 10-07-2014, 02:34 PM   #25
Not always tha case on where they bend. I bent one in the center on the long side. I just assumed it was due to flex under load in the lockout area.
Old 10-07-2014, 03:52 PM   #26
Plastic definitely flexes, especially OCP.
That's the reason I went with the GCM centered pumpkin. Been beating the crap out of it. Until you hold one and assemble one, you have no idea how stout the GCM is. I'll put it up against anything out there, Curries, VP OCP, even plastic with beef tubes.
Wouldn't even be a fair fight.
gdb85 is offline   Reply With Quote
Old 10-07-2014, 04:10 PM   #27
I'm not a fan of the quality of a GCM, maybe its an old one, but a buddy has a front and rear on his wraith. Pumpkin is huge, link mounts and steering mounts are just extremely dated and needs much more to compete with the others. Also still has the same failure bearing on the pinion the VP's use and stock, which is the biggest problem on all things related to an Axial straight axle.
I'll put my plastic DLUX bearing OCP on my Yeti against anything - then again I'm an old school RC racer, I know how to drive, been doing it for decades now. Yet to bend a rear axle in a plastic OCP or VP AR60 other than the known weak spots - the threaded area and the pin hole.
Old 10-07-2014, 10:12 PM   #28
I'm not a fan of the quality of a GCM, maybe its an old one, but a buddy has a front and rear on his wraith. Pumpkin is huge, link mounts and steering mounts are just extremely dated and needs much more to compete with the others. Also still has the same failure bearing on the pinion the VP's use and stock.
I'm sure no one else her can drive an rc. Nice call out! Lol what a joke
Old 10-08-2014, 05:19 AM   #29
I've traveled for RC racing, and RC Crawling for decades - I've been able to compare RC racers to RC Crawlers bashing and racing - there is a huge difference when you throw speed in
Nice call out? - seems like the previous poster called me out since I run Plastic AR60's modded with the 5x13 bearing fix.
Old 10-08-2014, 05:30 AM   #30
Whoa fella! I wasn't calling nobody out, just a little good hearted back & forth about opinions on axles that's all.
When it comes to RC I don't take myself or my toy trucks too seriously.
Old 10-08-2014, 05:35 AM   #31
I have GCM Axles front and rear on my U4 truck and they have held up well. Not super scale, but they are tough as nails. I also have gone through a couple of sets of Creeperbobs axles, they bent about 2mm past the hex pin. which surprised me.
I currently have the currie on my yeti, also with creeperbob axles, had a few issues initially with the VP tubes, but they were replaced under warranty, which was great, but it took almost a month. If you love metal and durability, go with GCM, if you
wanna go scale, go with VP, if you're on a budget, go with beeftubes.
.com is offline   Reply With Quote
Old 10-08-2014, 08:50 AM   #32
I think the gcm looks scale. It's looks just like a Chevy 14bolt. Im sorry "but I know how to drive" seemed a bit cocky. I've raced moto for 25 years and the ones bragging about themselves are usually the guys stuck in the beginner class. A good pro doesn't say much. Im not here to hurt feelings so sorry.
Old 10-08-2014, 08:56 AM   #33
All my point was aimed at was good driving means something to making parts last. If you drive into a curb, you will break things, simple as that.
Old 10-08-2014, 09:25 AM   #34
Oh so your just talking more about plain ignorance in the rc world. Got it
Old 10-11-2014, 06:29 AM   #35
BCK
Where can I get a gcm axle? Their website doesn't list them? Or am I looking at another GCM that does rc products!??
BCK is offline   Reply With Quote
Old 10-11-2014, 06:57 AM   #36
GCM Racing WebStore-2014 - MetalHead Drivetrain
Old 10-11-2014, 08:38 AM   #37
Blue monkey sales them to.
Old 10-12-2014, 03:20 AM   #38
I have a Traxxas Slash with all the MIP driveshafts and testing it on the street i crashed it into a pole and one of the rear wheels got some serious wobble, after i checked the axle that goes into the hex it got bent, i bought a replacement part from MIP (10131) and when i received it it has a new design without a hole for the pin but keyed and with a steel hex:
http://www.miponline.com/store/media...part-10131.jpg
Without a hole on it that should be pretty bulletproof
Pabust is offline   Reply With Quote
Old 10-12-2014, 08:11 AM   #39
I gave in to a set of Curries in grey. :(
Old 10-18-2014, 02:32 PM   #40
I'm going with a centered GCM with the 5x13 pinion bearing, along with some CREEPERBOB axle shafts. I broke my axle housing where the two bolts that hold the right trailing arm perch go through, took it off a jump and landed hard on the right rear and it snapped. With the GCM tubes, the big pinion bearing, and creeperbob axles it will be bomb proof!
npcaldwell is offline   Reply With Quote
Best aluminum rear axle for u4 on yeti - Similar Threads
*** GiveAway ***AXIAL ALUMINUM REAR AXLE LOCK-OUTS RPP Hobby Axial SCX-10 148 08-01-2009 12:12 PM
Non steering aluminum rear axle knuckle conversion? 65BAJA Tamiya TLT Crawlers 16 01-07-2007 01:34 AM
