09-30-2014, 08:37 PM | #1 |
Rock Stacker Join Date: Jun 2014 Location: Pasadena,Texas
| Ottsix Voodoo U4 on YETI- Punch vent hole in tires?
I was hoping someone with the Ottsix U4 tire could clarify one thing for me. A am using the U4 tire on the Crawler Innovations 6 hole plastic glue on wheels. The wheels have a pre formed spot to drill them for a vent. Should I drill out the hole in the wheel or punch a hole in each tire? Also is there a trick to gluing the tires in straight to keepo from getting wobble? |
09-30-2014, 09:09 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Ottsix Voodoo U4 on YETI- Punch vent hole in tires?
I just glued my set up. I like to use a leather punch to put 2-4 equally spaced holes centered in the tread area of each tire.
10-01-2014, 06:35 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Punch is easiest if you have one. 1/8th punch and 4 holes is plenty.
10-01-2014, 07:33 AM | #4 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
| Re: Ottsix Voodoo U4 on YETI- Punch vent hole in tires? |
10-01-2014, 04:56 PM | #5 |
10-02-2014, 08:27 PM | #6 |
Newbie Join Date: Apr 2009 Location: Randleman
Punch an 1/8" hole in the tire????
10-02-2014, 08:38 PM | #7 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Ottsix Voodoo U4 on YETI- Punch vent hole in tires? Should be closer to 1/16th i think. 3 to 4 2mm holes. Last edited by Crank; 10-02-2014 at 08:46 PM. Reason: forgot a 1 |
10-03-2014, 05:57 AM | #8 |
| Re: Ottsix Voodoo U4 on YETI- Punch vent hole in tires? Why not, for racing we used as large as 1/4", never had a single issue. When I cut and shut Voodoo's for my crawler and a buddy, I used scissors to make a hole, its not circular or perfect. The hole size does impact the compression and refill of air in the tire. So the final size is really going to be based on tire/foam combo anyway. I just buy from Crawler Innovations now...not only good prices and service, but Eddie and the team always punch holes in tires when you buy them from him in a combo pack with the CI foams. |
10-07-2014, 02:05 PM | #9 |
Pebble Pounder Join Date: Jan 2014 Location: Reynoldsburg
Do the holes go in the tread, sidewall or somewhere else?
10-07-2014, 02:17 PM | #10 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
Center of the tread.
Ottsix Voodoo U4 on YETI- Punch vent hole in tires? - Similar Threads | ||||
OTTsix 2.2 Voodoo U4 Tires are in stock!!! | CKRC Hobbies | CKRC Hobbies | 1 | 08-26-2014 10:57 PM |
Introducing the Ottsix Voodoo U4 | crawl-o-matic | General Crawlers | 38 | 08-11-2014 07:09 PM |
Ottsix voodoo update | crawl-o-matic | Tires and Wheels | 128 | 08-06-2014 06:18 AM |
