10-07-2014, 10:29 AM | #21 |
Rock Crawler Join Date: May 2008 Location: carson city
| Re: How can we increase Yeti ground clearance?
I will tonight.
10-07-2014, 02:33 PM | #22 |
Pebble Pounder Join Date: Jul 2012 Location: USofA
Hey Werty Made, what measurement are you getting from the ground to the belly pan at the lowest point with some 5.5" tires on? I was wondering abot going with a little longer shock up front too, something with a 70mm ish spring.
10-09-2014, 03:13 PM | #23 |
| Re: How can we increase Yeti ground clearance? you could always just use a longer shock rod end.
10-09-2014, 03:44 PM | #24 |
There's an idea, when you change out ends like this how do you back up the shaft without scratching it?
10-09-2014, 03:47 PM | #25 |
| Re: How can we increase Yeti ground clearance? Get one of these fine shock tools. It even has a hollow ball extractor and installer. |
10-09-2014, 04:03 PM | #26 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
Under the bottom spring cup, the shaft is flatten on 2 sides to hold it, it is not on a part of the shaft that goes into the shock so no need to worry about the seal. I was pleasantly surprised to find that out when I swapped the bottom rod ends.
08-14-2017, 04:43 PM | #27 |
Newbie Join Date: Aug 2017 Location: Canada
| Re: How can we increase Yeti ground clearance? |
How can we increase Yeti ground clearance? - Similar Threads | ||||
Increase ground clearance on my Wraith | Alex Yuen | Axial Wraith | 11 | 07-12-2016 05:30 PM |
Ground Clearance? | Norris | RC4WD Bully | 9 | 03-20-2010 08:35 PM |
Ground clearance | BigBoss | General Crawlers | 3 | 03-02-2010 01:59 AM |
Creeper is "clicking" in tranny and i wanna increase ground clearance!!! | 97xjguy | Venom Creeper | 12 | 12-20-2009 04:31 PM |
ground clearance help? | RcFanatic92 | Newbie General | 7 | 03-08-2008 12:53 PM |
