10-15-2014, 08:50 AM | #1 |
Newbie Join Date: Sep 2014 Location: SLC
| Shawn's YETI
Front End: Axial HD Gears Blue Monkey Long Spool Locker Dlux modified Diff housing Traxxas CVD’s RPM A-arms (clearance for Traxxas CVD’s) STRC Carriers VP Knuckles VP Steering rack VP Steering posts Traxxas Turnbuckles w/Revo Ends EXO Front Bumper Modified STRC EXO Shock tower Pro-Line Powerstroke shocks (Slash 4x4 rears) Rear: Axial HD Underdrive Gears Axial stock shocks w/Dual Spring added Blue Monkey Trailing Arms Blue Monkey Upper links DMG rear skid plate Traxxas turnbuckles for lower swaybar VP Linkmounts Dlux Modified axle housing Electronics: Tekin Pro4HD 3000kv Castle MMP Castle BEC Hitec 7954SH Servo w/ Axial Servo Arm Spectrum 301 Receiver HeyOK Winch Controller KMS K3 Servo Winch Transmission: 12/64 Gears Axial machined motor mount Axial machined slipper plate Body: EXO Hood and Roof (some modification needed to fit) Custom cut lexan side panels (thanks CarterFab for the idea) VP Method 105 Wheels (350 SLW front / 600 SLW Rear) Custom built 1” wheel cans (thanks again CarterFab for the idea) Axial 2.2 Maxxis Trepadors R35 Crawler Innovations Deuces Wild Foams Custom built Servo saver delete [/COLOR][/SIZE][/FONT] The journey to completion was long... but well enjoyed. Made my own 1" cans for the VP's since nobody had any in stock... Stock foams and VP's (Left) CI Deuces Wild on the wider cans (Right) Blue monkey locker with traxxas CVD's (Defiantly not a bolt on) Had to make some custom spacers to take the slop out of the hub since the hub pin on the Traxxas CVD's wasn't in the same spot as the stock Axial pin (2.5mm I think). Dual rate springs I had laying around... Blue Monkey trailing arms installed Winch... why not? Still not sure how I broke this... I think she is nearly done... for now atleast Last edited by STIshawn; 06-06-2015 at 08:59 PM. |
10-15-2014, 09:02 AM | #2 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: Shawn's YETI
Wow great job.
10-15-2014, 08:20 PM | #3 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
| Re: Shawn's YETI
looking sweet..
10-15-2014, 10:00 PM | #4 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
| Re: Shawn's YETI
Looks great. I have the same setup as you in the front end. wondering if you machined your stubs back .032" as suggested by blue monkey? I ended up taking nearly .052" off as it would push the outter bearing out of the seat. As for the pin location all mine needed was the fiber/Teflon washers like Traxxas uses on their RTR cars to take any slop out.
10-16-2014, 07:43 AM | #5 | |
| Re: Shawn's YETI Quote:
10-16-2014, 08:25 AM | #6 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Re: Shawn's YETI
I used the mip shafts with mine and let me tell ya they didn't even need milling even though I still did then kicked myself in the ass... Sent from my iPhone using Tapatalk |
10-16-2014, 10:05 AM | #7 |
Rock Stacker Join Date: Sep 2014 Location: Delta
| Re: Shawn's YETI
I am surprised to see you blew apart one of the TRX CVD's I have been using them on an slash 4x4 jacked up on roids and havent broke one yet. Must have really had the truck in a tough spot to manage that. Other than that. Good looking rig you got there. I think it looks awesome with the color scheme you have going on.
10-16-2014, 10:42 AM | #8 | |
10-24-2014, 10:17 PM | #9 |
| Re: Shawn's YETI
So after running the Yeti through a few packs last weekend I bent both traxxas front CV's so I went ahead and installed the MIP's. Used a reamer to clearance out the knuckles some, also went ahead and did a little bit of dremel work to the carriers to get a tiny bit more steering travel. Overall I'm feeling pretty good about the outcome. |
10-24-2014, 11:48 PM | #10 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: Shawn's YETI
Very clean work
10-25-2014, 12:55 AM | #11 |
Rock Crawler Join Date: Apr 2014 Location: Portland
| Re: Shawn's YETI
Nice looking Bling on the yeti. Nice wheel Cans.. But Black lettering on the postings? |
10-31-2014, 11:11 PM | #12 |
Pebble Pounder Join Date: Dec 2008 Location: Everett, WA
| Re: Shawn's YETI
Question... Are the Yeti and Exo front bumpers exchangeable? Is the bottom mount for the bumper the same? Thanks
11-03-2014, 08:21 AM | #13 |
| Re: Shawn's YETI |
11-03-2014, 08:45 AM | #14 |
| Re: Shawn's YETI |
11-05-2014, 01:05 PM | #15 |
Rock Stacker Join Date: Jul 2013 Location: Citrus Heights
| Re: Shawn's YETI
On your strc carries did you have any problems with it being tight on the knuckles cause mine are tight so it makes the steering hard and ive have no ideal why its like that ive asked a couple other guys if they had the problem they said no?
11-05-2014, 01:22 PM | #16 |
| Re: Shawn's YETI Same problem here..had to file the strc carriers.. didn't want to file the vp knuckles
11-05-2014, 01:23 PM | #17 |
| Re: Shawn's YETI
Ok thank you for the info about how much did you have to file
11-05-2014, 04:06 PM | #18 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
| Re: Shawn's YETI
Same problem on my rig. I used a sanding drum in the Dremel on the back of my VP knuckles. Easier to access. Basically I removed the anodizing and gave it a once over with a sanding stick to remove and burrs. Fits perfect. Were only talking a few thousandths worth of interference.
11-23-2014, 06:01 PM | #19 |
Newbie Join Date: Nov 2014 Location: Placerville
| Re: Shawn's YETI
i had the same issue with the traxxas CVD's blew it up within 7 min of running it. looks like the MIP's are the way to go.
06-06-2015, 10:16 PM | #20 |
| Re: Shawn's YETI So I spent some time with the Yeti locked front and rear... So matter what I installed, modified, or purchased, the Yeti just doesn't crawl like my solid axle rigs. So I made some changes: I pulled the winch off and Installed the original bumper Remade my body panels and cut the hood off the stock body. Unlocked the front and took the MIP's off Installed the Axial universals and a GCM diff cup w/HPI gears and 500K fluid Pulled the prolines and put on traxxas big bores with an old spring from my road car up top. Got a little crazy and put Yeti XL shocks on the rear (used the two softest short springs from the kit) Pulled the VP wheels and CI DW foams Made some custom two-stage foams and mounted them on CI wheels. Installed a VP centered currie axle (makes the car launch so much better) Overall: The Yeti just isn't that great at crawling... BUT it is great for high speed bashing/racing! https://www.youtube.com/watch?v=bpxcu1cllCI |
Shawn's YETI - Similar Threads | ||||
Shawn's Wraith | shwng1973 | Axial Wraith | 19 | 02-28-2012 02:38 PM |
Shawn's LCC | Shawn M | Team Losi Comp Crawler | 6 | 11-18-2010 08:52 PM |
Shawn's Pajero RC4WD Trail Finder | shawnd | 1.9 Scale Rigs | 6 | 10-02-2009 12:39 PM |
Shawn's Yellow Jeep on TF chassis | shawnd | 1.9 Scale Rigs | 6 | 10-01-2009 07:14 PM |
