10-30-2014, 01:09 AM | #1 |
Newbie Join Date: Oct 2014 Location: Leitchfield
| Throttle cut out when turning
Ok so today I had my esc replaced with a castle sidewinder 3 and also has a castle fan installed for the esc and another for the motor. When I got back home, I was running it out in the yard and when I turn, the throttle and servo kick out intermittently. I thought my battery might have been low. While I was charging the 3s battery I put in my 2s and everything ran perfectly. I just thought my 3s was going dead. When the 3s was fully charged, I put it back in and it done the same thing again. Anybody know what would be causing this. I threw in a buddy's venom 3s and it did the same thing. I made a post about this earlier but it was deleted by me by accident.
10-30-2014, 01:36 AM | #2 |
| Re: Throttle cut out when turning
Forgot to mention it has a savox sc 0251 servo
10-30-2014, 04:19 AM | #3 |
Pebble Pounder Join Date: Jan 2014 Location: Reynoldsburg
It is likely the bec can't keep up on 3s. Try an external bec and see if it still happens.
10-30-2014, 05:12 AM | #4 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
X2 ^^^ Definitely needs an external bec. Castles internal bec is weak and you're using a voltage robbing little bugger of a servo. |
10-30-2014, 06:11 AM | #5 |
Ok. I'm new to all this. Which bec would you all suggest and since my ports in my receiver are all full, do I tie my fans into the bec or my servo?
10-30-2014, 06:46 AM | #6 |
Quarry Creeper Join Date: Sep 2011 Location: NW
Basic castle BEC Castle Creations | CC BEC and CC BEC Pro Use a receiver bypass adapter to have it power your steering servo only. Or a double to also include the fan. Receiver bypass adapter, or u can make your own. Point is to run the ground and signal from the RX to the servo and keep the power run just between the bec and servo. CreationFab - Other Plugs |
10-30-2014, 07:02 AM | #7 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
You can also lose the fans too...not necessary.
10-30-2014, 11:27 AM | #8 |
Quarry Creeper Join Date: Jun 2011 Location: Salt lake city
| Re: Throttle cut out when turning I would highly recommend keeping the esc fan at least. The sv3 is the same esc as the ae3 that came stock. They will over heat with a 550 motor in a big heavy 4x4 truck. my ae3 will overheat in 5 min on 3s in the rock with stock gearing. Last edited by the_ocho; 10-30-2014 at 01:34 PM. |
10-30-2014, 01:25 PM | #9 |
I'm running my MMP on 6s and the fan doesn't even come on, but that's quite a different scenario.
10-30-2014, 01:35 PM | #10 |
| Re: Throttle cut out when turning |
10-30-2014, 02:57 PM | #11 |
I'm gonna keep the fans. They've definately extended my run times before getting hot for sure. I ordered the no brainer bec before I seen any of these replies. Hopefully it will take care of my problem. I was going to replace my esc with another factory one but it was 109 bucks. Then I almost pulled the trigger on a castle mamba max pro sct motor and esc combo but not being waterproof kinda bugged me. Then i went with the fans which aren't waterproof but oh well. It is what it is.
10-30-2014, 08:24 PM | #12 | |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: Throttle cut out when turning Quote:
The fans are a must on 3s trust me....and the bec is the problem ..I run that setup and my motor did the exact same thing . Installed the castle bec..all fixed you will need to program the castle esc to 6.0v with the castle link. Well worth the effort with this servo!! | |
Throttle cut out when turning - Similar Threads | ||||
only cut tires. post up your cut tire photos | evan03 | Tires and Wheels | 172 | 12-05-2021 07:54 PM |
Dove cut, bobbed, cut, chopped, you name it its been threw it... California Raisin... | Madjones | Losi Micro-Rock Crawler | 6 | 11-17-2014 09:07 AM |
Help. Throttle controlling throttle and steering | andneverexhale | Electronics | 6 | 08-21-2014 07:46 PM |
axles start turning at different times when I engage the throttle | J-Fish | Electronics | 5 | 02-02-2013 04:02 AM |
*** proline flat irons to cut or not to cut you tell me *** | Cmace23 | Tires and Wheels | 14 | 01-21-2012 12:33 AM |
