11-14-2014, 12:07 PM | #1 |
Newbie Join Date: Nov 2014 Location: Anchorage
| silly puddy in ft diff????
noob question!!!!! where would one put "silly puddy" in the front diff?? just open the case and fill it with puddy, or packed somewhere else, also will it hold up to the high speed bashing my yeti loves???? never knew sill puddy was a "thick lube" and would also protect my gears. |
11-14-2014, 12:22 PM | #2 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: silly puddy in ft diff????
Most people use that when their wanting to lock the front diff gears. Try a thicker lube if your not wanting to lock it entirely.
11-14-2014, 12:24 PM | #3 |
Newbie Join Date: Jun 2014 Location: Lathrop
I think it's supposed to "lock" the diff gears so that the front axle is locked and not independent. Basically the silly puddy is jammed in the front diff where the spider gears are so that they don't spin independent but the whole axle spins in one direction(like a Wraith)...it's basically a cheap alternative to buying a locker spool. If you're bashing more than crawling I'd probably not go that route...instead use a 500k diff oil.
11-14-2014, 12:43 PM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
It's supposed to "lock" the diff but still have enough give to avoid busting axles when bashing.
11-14-2014, 01:03 PM | #5 | |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: silly puddy in ft diff???? Quote:
independent front suspension (IFS) makes a left wheel move op and down without influencing the right wheel (and vice versa). Found under the Exo and Yeti (front) A 'solid axle' is the opposit of IFS (and not related to the state of the diff). These are found under the Wraith and yeti(Rear). Everything else in your reply: +1. | |
11-14-2014, 02:07 PM | #6 |
so I like basing around at mostly high speed with my yeti, but crawling a little here and there, should I try heavy weight oil or silly puddy, or an actual ft locker, I know I ll loose some sterring, but will it hold up to me hauling a#% on 3s eveyewere.
11-14-2014, 04:29 PM | #7 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
I've used silly putty on two axial yeti's with good results. If your curious about where to put it reference my build thread Dasco's Yeti 2.0 |
11-15-2014, 07:13 AM | #8 |
Quarry Creeper Join Date: Sep 2014 Location: UK
If all you're going to do is crawl then locking it entirely is an option. If you want to race or general bash, then avoid locking it. The consensus from the experienced guys on this forum as been 500k wt diff oil. I've done this myself and it's great. |
11-15-2014, 10:05 AM | #9 |
| Re: silly puddy in ft diff???? I'm guessing this fluid effectively creates a limited slip diff? And that's what we're achter, right?
11-15-2014, 10:06 AM | #10 |
Yep.
silly puddy in ft diff???? - Similar Threads | ||||
Silly question | bryco13 | G-Made Crawlers | 2 | 06-19-2012 08:51 PM |
Silly Females | Culetto | Chit Chat | 11 | 01-24-2010 09:10 AM |
whats the Diff, between maxx 3.3 diff and revo diff? | 12voltfun | Traxxas Crawlers | 2 | 06-06-2009 09:16 PM |
maybe a silly question? | Rocksolo | Electronics | 3 | 05-20-2009 05:10 PM |
