07-22-2017, 11:43 AM | #201 |
RCC Addict Join Date: Mar 2011 Location: easton
| Re: What did you do to/with your Yeti today?
Built the rear cage, mounted it to the body only to realize I need to order new body mounts.... so I used the old style scx body mount to know how big the holes had to be up front. That way I can adjust them later when I have the right ones Sent from my iPhone using Tapatalk |
07-24-2017, 06:31 PM | #202 |
Pebble Pounder Join Date: Jul 2012 Location: Saint Louis
| Re: What did you do to/with your Yeti today? New wheels and tires. Sent from my iPhone using Tapatalk |
07-28-2017, 08:58 PM | #203 |
Newbie Join Date: Jun 2017 Location: Aussie
| Re: What did you do to/with your Yeti today? |
08-09-2017, 03:25 AM | #204 |
| Re: What did you do to/with your Yeti today? Happened yesterday but finally got the body mounts in for it so I made the front holes fit better. Also discovered that if you run Losi offset short course wheels, they don't fit horrible and seem to have plenty of clearance. Now just need to wait for the box from tower to replace the tini pins in the front. |
08-10-2017, 02:00 PM | #205 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
I think I got the toe settings figured out. went to my local shop and get another set of traxxas rods with ends that were shorter. I don't have any fancy setup gear so eyeballs it is. gonna test it out today when I get home from work. next on the list is lights and DIY body panels. maybe some 3D printed driver heads. not letting the cat out of the bag yet but its gonna be an awesome duo. |
08-10-2017, 03:00 PM | #206 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
Installed a Sanwa ERS-963 servo that I got cheap and a CC 10a bec. I've run a few 3s packs and so far I'm impressed. http://www.rccrawler.com/forum/attac...1&d=1502398749 |
08-10-2017, 10:32 PM | #207 |
Yeah i got somemsteering uhh... stuff to iron out. Servo is slow as all heck making it a handfull to control even with rtr esc and motor. Its got all vp steering links but the spring is weak and absorbing steering force from the servo. Sloppy slop slop. But! Alignment is great! But... gear mesh sounds like its off. More noise than usual. Might be from the rear as its now plastic making it sound different? Might be best to just crack open the trans. I havent done tht since i bought it used last year. Yikes. Oh and i just finished painting my radiator. Tamiya aluminum silver with some gloss clear coat. Shiny! Last edited by Shinchu; 08-10-2017 at 10:53 PM. Reason: Several light coats |
08-23-2017, 06:57 PM | #208 |
Comfirmed! Destroyed the only gear left that is still plastic... the spur. Even after adjusting after my last post, it was way off only like half tooth engagement. So gave it more and tightened everything down, sounded much better just whirring brushless awesomeness. Then, today hitting up some hiking trails in mission hills with my son piloting his barrage and me blasting around with the yeti... it does what it do. Rrrrrripweeeeeeee no more spur. Odd. It was driving like a champ. Maybe driving beforemwith half engagement warped the pitch and it slowly killed itself? Well for $7 at rpp im not gonna cry about it. Just the downtime sucks lol Yeti is seriously like the rc version of the hulk haha |
08-25-2017, 09:41 PM | #209 |
Oookay... opened up the gearbox and... spur gear is fine? But whats this? The pinion gear has backed up inside the motor mount like a scared turtle!!! Buaahahhahahaa!!! So the yeti lives on! For now... Oh and for poops and chuckles, i put the axial giant fog lights on the front bumper. No leds just decorative. Or... explosive? Almost mounted the radiator but... nah. |
09-14-2017, 04:53 AM | #210 |
In an attempt to finally get more speed and make it actually have down travel at ride height, I ordered a castle 1415 2400kv motor with mamba x esc, 35 and 45 wt shock oil, 70mm axial red springs for the front, 90mm axial white and yellow for the rear. The set up I found uses the white in the rear but I think it was for a regular yeti and mine is currently a tt Sent from my iPhone using Tapatalk Last edited by c0bra; 09-14-2017 at 04:56 AM. |
09-18-2017, 08:43 PM | #211 |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
New wheels. Will add more dirt to them this weekend. Sent from my Nexus 6P using Tapatalk |
09-18-2017, 10:35 PM | #212 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
Snapped my stock caster blocks. Stepped up to STRC caster and knuckles. Can't wait to break something else!! Haha!! Sent from my iPhone using Tapatalk |
09-19-2017, 06:20 PM | #213 |
That didn't take long... Sent from my iPhone using Tapatalk |
09-23-2017, 07:03 PM | #214 |
Swapped out ESC and did some rewiring today: Sent from my iPhone using Tapatalk |
09-24-2017, 02:54 PM | #215 |
3s with CC Mamba Max = wicked fast!!! Woohoooo!!! Sent from my iPhone using Tapatalk |
09-25-2017, 12:49 AM | #216 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
09-29-2017, 08:20 PM | #217 |
Voodoo U4's with CI foams strapped on today. Heck yes!! Sent from my iPhone using Tapatalk Last edited by Nastyman211; 09-30-2017 at 05:38 AM. |
10-09-2017, 08:13 PM | #218 |
10-19-2017, 09:29 PM | #219 |
| What did you do to/with your Yeti today? Last edited by Nastyman211; 11-05-2017 at 11:48 PM. |
10-26-2017, 07:53 AM | #220 |
Yeeup... so that happened. Just another excuse to upgrade!! -Grinding gears Sent from my iPhone using Tapatalk |
What did you do to/with your Yeti today? - Similar Threads | ||||
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
