04-18-2018, 10:43 AM | #301 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
| What did you do to/with your Yeti today?
Soooo... yea. Anyone recommend an AR60 axle shaft that can hold up to the Beast mode power? P.S., Actually caused from a tumble. Sent from my iPhone using Tapatalk Last edited by Nastyman211; 04-18-2018 at 03:41 PM. |
04-19-2018, 09:49 PM | #302 |
Rock Stacker Join Date: Mar 2018 Location: Iowa
| Re: What did you do to/with your Yeti today?
What did I do? Well not much lately. Went for a trail run this evening. Then came home and swapped shock oil and springs. Sent from my SM-J727R4 using Tapatalk |
04-20-2018, 12:19 AM | #303 | |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: What did you do to/with your Yeti today? Quote:
As i see in the Pic you are using the plastic hubs, changing to pin mounted hubs (gpm, lattice Innovation) may help also. I'm still running the first axle set of my SSD wide Diamond, never bend or broke. Send by my Pixel 2 XL with Tapatalk | |
04-20-2018, 08:15 AM | #304 |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
Bob's Ti axles are slick. I eventually broke a set at the drive pin after 6 months of 3-4 day a week abuse on 3s. Bought another set. Sent from my ONEPLUS A5010 using Tapatalk |
04-21-2018, 03:08 AM | #305 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
I hit a rock, hidden in tall grass, head on, full speed at 3S. Kaboom! Center drive shaft bent, but no other damage. I'll bend it back and order a new one as well. Does anyone know if there's a MIP replacement? Axial part number is AX31139, and I can't find any good info on MIP alternatives.
04-21-2018, 08:32 AM | #306 |
Bending it back was easier said than done... Skickat från min SM-G920F via Tapatalk |
04-21-2018, 10:37 AM | #307 |
| Re: What did you do to/with your Yeti today? |
04-21-2018, 01:53 PM | #308 |
| Re: What did you do to/with your Yeti today? Indeed it sucks, but what I did was pretty much the equivalent of hitting a brick wall at full throttle, so I guess I should count myself lucky. 25$ for a new shaft in Sweden, and a week or so of waiting. It could have been a lot worse.
04-22-2018, 06:33 AM | #309 | |
I agree. Sent from my iPhone using Tapatalk | |
04-25-2018, 06:45 PM | #310 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
I purchased two new sets of the AX30395 38/13 gears to replace the crap stock gears. I’m on my third set of stock gears in the rear and the front finally wore out. I would’ve upgraded sooner, but I had spare cheap gears out of my Bomber to use up first.
04-28-2018, 07:37 AM | #311 |
Rock Crawler Join Date: Mar 2012 Location: UK
04-28-2018, 10:55 AM | #312 |
I rebuilt the front diff last night with a Dlux bulkhead, Axial 38/13 HD gears, fast Eddie bearings, and fresh 500K fluid. I made a point to really pack the 500 K fluid in there including under the side gears. On a quick test the diff performs well, at slow speeds one front tire will sit against an obstacle but a blip of throttle and it pulls well. One of the output o rings was wasted, but at didn’t have a replacement and that 500K fluid doesn’t seem to run out much. Next will be rebuilding the rear axle with a Dlux housing, HD gears, aluminum beef tubes, etc. I need to buy a new spool and some HD axles. I was looking at the SSD wide axle set as I keep bending the short side axle on the stock setup. |
05-01-2018, 04:46 AM | #313 |
05-03-2018, 01:50 PM | #314 |
05-10-2018, 10:53 AM | #315 |
05-10-2018, 10:56 AM | #316 |
Added some jewelry to mine and then went out to put some scratches in it. Sent from my ONEPLUS A5010 using Tapatalk |
05-12-2018, 06:57 AM | #317 |
05-15-2018, 06:49 AM | #318 |
05-15-2018, 09:17 AM | #319 |
05-18-2018, 09:23 AM | #320 |
What did you do to/with your Yeti today? - Similar Threads | ||||
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
