05-19-2018, 08:48 AM | #321 |
Rock Crawler Join Date: Mar 2012 Location: UK
| Re: What did you do to/with your Yeti today? |
05-25-2018, 03:19 AM | #322 |
05-26-2018, 09:19 AM | #323 |
05-26-2018, 05:43 PM | #324 |
Rock Crawler Join Date: Dec 2010 Location: tracy
Possibly selling mine to fund my f350 tow rig Sent from my Moto Z (2) using Tapatalk |
05-29-2018, 11:18 AM | #325 |
06-01-2018, 01:59 PM | #326 |
06-02-2018, 10:34 AM | #327 |
RCC Addict Join Date: Jun 2016 Location: Germany
Got some drivetime today. After yesterday drive was ended after 200m, broke Rodend and lost drivespline. Send by my Pixel 2 XL with Tapatalk Last edited by magic_yeti; 06-02-2018 at 03:21 PM. |
06-24-2018, 02:34 PM | #328 |
Pebble Pounder Join Date: Oct 2015 Location: B.C.
08-12-2018, 07:58 AM | #329 |
12-24-2018, 12:42 AM | #330 |
Rock Crawler Join Date: Apr 2017 Location: US
Its been great to sit down and work on the yeti's today. Been installing some upgrades on each and more to come little by little. It was just what the doctor ordered to relax and chilli. Sent from my SM-J727T using Tapatalk |
12-24-2018, 03:21 AM | #331 |
Dat bench, tho. |
12-24-2018, 04:41 PM | #332 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
12-26-2018, 02:12 PM | #333 |
Rock Stacker Join Date: Feb 2016 Location: Gorham, Maine
Exotek chassis conversion completed.... RPM front A-Arms....Proline Raptor body purchased.... now just need a smaller ESC to fit in the narrower chassis....
12-26-2018, 02:43 PM | #334 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
Took my sons out for their first bash!! Good times Sent from my iPhone using Tapatalk |
12-31-2018, 09:15 PM | #335 |
Working on one of the yeti's one upgrade at a time. One day this one will be almost bullet proof. Sent from my SM-J727T using Tapatalk |
01-02-2019, 12:50 PM | #336 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
I installed a VP rear diff cover after breaking the tiny hole inserts in the plastic cover. I finally ditched the Axial plastic beadlocks and glues the BFG RTR tires to a set of Crawler Innovations 6 Bolt 1” wide wheels with VP SLW hubs. I reused the CI DD foams I’d been running for years. I had purchased the 6 bolt wheels back in late 2015. The new wheels run much more true than my thrashed beadlocks did. I made a spring spacer for the steering rack to reduce the slop, it seems to have done the trick. I fired up the Castle link and changed punch control from 25% to 50%, initial battery draw from low to medium, and set the BEC from default 5.1 volts to 6.0 volts to speed up the MG968 steering servo. I have a set of the Voodoo U4 Silver tires and matching DD foams, but I haven’t decided on wheels. I was thinking some metal beadlocks, but the 1.5” wide 6 bolt may be the way to go for reduced weight and cost. I need to replace the rear axle shafts again. I’m running a dlux AR60 plastic housing with aluminum beef tubes. I have an incision spool and Axial HD 38/13 years waiting to install. Can anyone recommend which shafts would be better, Locked Up or VP? It looks like the locked up might work better through the beef tubes, but which is stronger? |
01-05-2019, 09:16 PM | #337 |
Today I beat the crap out of the Yeti until the rear driveshaft let go. I was in some muddy/snowy conditions and my new front shield inside the body kept it from becoming a complete mess.
01-06-2019, 01:41 PM | #338 | |
| Re: What did you do to/with your Yeti today? Quote:
check your lockouts, loose ones could cause axle bending. if you use stock plastic lockouts, i would change to clamping ones or get a ssd wide centered axle (never bend a axle) or alternatively modify the stock ones to 4 mounting screws (top button front rear) did this with mine before i changed to the ssd axle.... | |
01-07-2019, 01:11 PM | #339 |
| Re: What did you do to/with your Yeti today? Sent from my iPhone using Tapatalk |
01-15-2019, 08:25 AM | #340 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
got a rather large box from proline... (re)build thread coming soon... ;) |
What did you do to/with your Yeti today? - Similar Threads | ||||
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
