11-23-2014, 09:36 AM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: here
| quick question which esc of the two I have.
Alright guys, I ppicked up a yeti this weekend. The rig came installed with a Fuze 1/10 4WD SCT Sensorless esc comb, 540 4-pole 5mm shaft 3900kv. Also have the stock ESC/Motor combo, other than I'm able to program stock esc with my castle link(this is a plus). Any pros or con's or which esc is better/should I run? I'd post a picture but it looks like yours.LOL |
11-23-2014, 10:05 AM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: quick question which esc of the two I have.
Looks like the fuse is a 540 and a slightly higher kv so more top end . the vanguard is a 550 so it has a longer can and more low end. I would say use the fuse for a while and switch them out to see how they both perform for the type of driving you plan to do.
11-23-2014, 01:50 PM | #3 |
Pebble Pounder Join Date: Jun 2014 Location: South Ontario, Canuckistan
Depends, If you like speed use the Fuze but if you plan on doing some crawling use the stock. If you want the best of both world's, run on 3s bring up the pinion a couple teeth and stick a fan or heatsink on the stock motor. |
quick question which esc of the two I have. - Similar Threads | ||||
Quick Rooster Crawler ESC question | Hydro-Tank | Electronics | 22 | 02-16-2012 04:08 PM |
Quick ESC Question | skullking | Losi Micro-Rock Crawler | 3 | 01-02-2010 04:14 PM |
Quick CR-01 ESC question. Noobie fool. | Neeley | Tamiya CR-01 | 10 | 11-19-2008 11:47 AM |
quick question please! esc with a 16turn limit? | holycaveman | Electronics | 0 | 02-25-2007 09:38 PM |
quick question moped ESC | BrandonW | Electronics | 1 | 05-27-2006 03:52 PM |
