02-24-2015, 08:49 PM | #41 |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
| Re: hobbez84's Yeti Kit Build
That's a UCFab sway bar! |
02-24-2015, 09:02 PM | #42 |
Rock Stacker Join Date: Oct 2014 Location: Jasper
Those Carter Fab Panels look so good. Really wish they would be available again soon!
02-25-2015, 06:48 AM | #43 |
Quarry Creeper Join Date: Dec 2014 Location: Northern VA
| Re: hobbez84's Yeti Kit Build |
02-26-2015, 08:06 PM | #44 |
| Re: hobbez84's Yeti Kit Build Last edited by hobbez84; 05-06-2015 at 12:53 PM. |
02-27-2015, 10:02 PM | #45 |
UCFab trailing arms installed. This particular one has counter-sunk cuts. Filled the remaining holes with some left over VP screws for my Wraith build. Arms and wheels match up nicely. I also love the heft of these things. Thank you UCFab/DLUX for the most excellent product! Last edited by hobbez84; 05-06-2015 at 12:55 PM. |
02-27-2015, 10:14 PM | #46 |
Heck yeah man, those look great! Your pinion angle is a little funky though. Have you tried revo ends on one or both sides of your upper links to flatten that out a bit?
02-28-2015, 05:08 AM | #47 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
Pinion angle does look rotated too far back. I may be wrong but it looks like you may have used the longer Jato rod ends on both sides of the links and I believe VP recommends one side only with the Currie axle. |
02-28-2015, 08:31 AM | #48 |
You guys are right, I used jato rod ends on both ends of the upper links. Should I replace the ones tied to the axle with revo ends ?
02-28-2015, 10:36 AM | #49 |
03-02-2015, 11:23 AM | #50 |
As usual, a big thanks to the RCC community for straightening out my errors. Swapped the Jato rod ends on one end back to the Revo rod ends. Truthfully, this being my first solid axle setup, I had no clue what pinion angle was. From what I can tell, fixing this should reduce stress on the drivetrain? On another note, my collection of DLUX stickers is ever growing: I've also come to the conclusion that the VP Method 105 wheels are not suitable for my Yeti. From the beginning I imagined this as a U4 themed racer/basher. So keeping things fast and durable were key. However, in this case, I think the wheels are just too heavy for my application. With that said, I've ordered in Crawler Innovations wheels, CI foams, and Ottsix Voodoo wheels (Gold) The Method 105 will find a good home on my eventual Wraith Build...I already have all the axles built up. Last edited by hobbez84; 05-06-2015 at 12:54 PM. |
03-02-2015, 12:40 PM | #51 |
Good choice if bashing & racing are what you'll mostly be doing. I have both sets of wheels you mentioned, I use the CI 6 bolts for U4 racing and the Methods when we Trail Run & Crawl. |
03-04-2015, 12:42 PM | #52 |
Crawler Innovations stuff. Lots of extras, and the bubble gum is always appreciated. I will be using tried and true AKA glue to hold them together. They have held on well through 5S and 6S abuse on my 1/8 monster trucks. Last edited by hobbez84; 05-06-2015 at 12:55 PM. |
03-04-2015, 01:09 PM | #53 |
03-04-2015, 09:17 PM | #54 |
Did some mock up and ran into a snag. The 1.5" CI wheels are too wide, which causes the inner rim to rub on the knuckle. As I don't want to dremel 4 wheels and potentially ruin the balance, I'll settle for wider slw hubs. I also removed the TBone racing a-arm skids as they also interfere with the CI wheels. Will likely place the a-arm skids and 225/725 slw hubs for sale. 1st impressions on CI wheels is positive. Fitment issues are an easy fix and they are light. Should do well with the voodoo u4 tires. Last edited by hobbez84; 03-04-2015 at 09:21 PM. |
03-04-2015, 11:09 PM | #55 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
Hey there hobbez84, this is a really solid and sweet looking Yeti build! I'm loving your direction and your correction. Keep up the great work and I'll keep checking it out for progress and ideas! |
03-05-2015, 06:44 AM | #56 |
Have you tried the 6 Bolts in the 1" size?
03-05-2015, 08:41 AM | #57 |
| Re: hobbez84's Yeti Kit Build I originally ordered the 1" wheels, but changed my mind and asked Tyler to switch to 1.5 wheels, because I wanted to go with the wider wheels for the extra support. The wheels, foam, and tire combination look very promising, and I'm confident that I found the right combination of weight, traction, and support. Just need to get the wider SLW hubs, and I'm golden. Rockwolf, thank for the kind words! I can't wait till the snow starts to go away and I can get some real dirt on this sonofabitch! |
03-05-2015, 09:17 AM | #58 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Build looks killer, man!
03-05-2015, 02:36 PM | #59 |
RCC Addict Join Date: Jan 2010 Location: Vermont
Those a arm skids look fantastic! Anymore shots of them? And link?... Found them!! Those are sweet!!! Last edited by tedo; 03-05-2015 at 02:40 PM. Reason: internts guuugle... |
03-05-2015, 02:47 PM | #60 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
Yep, My dad had to go to .600 slw's to get the 1.5's to fit. I think I have .350's on my 1" and have room to spare.
hobbez84's Yeti Kit Build - Similar Threads | ||||
Imthatguy's Axial Yeti KIT Build | imthatguy | Axial Yeti | 41 | 09-01-2015 04:49 AM |
Harley's Live Yeti Kit build - Join In | Harley | Axial Yeti | 13 | 01-13-2015 09:00 PM |
Yeti kit delayed!! | lala4fire | Axial Yeti | 37 | 01-13-2015 03:02 PM |
Yeti Kit? | leckster | Axial Yeti | 1 | 10-28-2014 04:06 PM |
Another Yeti Upgrade kit | CKRC Hobbies | CKRC Hobbies | 0 | 09-18-2014 04:00 PM |
