01-17-2015, 01:03 PM | #1 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
| Associated ESS or Traxxas OBA?
I really want to add audio to my Yeti Wondering if people have tried? My understanding of some pros and cons Traxxas OBA waterproof harder to set up volume is adjustable only one "engine" sound speakers attach to body Team Associated ESS not waterproof speaker built into unit uploadable engine sounds Any other input would be greatly apprciated. |
01-17-2015, 04:26 PM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: Associated ESS or Traxxas OBA?
Traxxas OBA can only run 7 cell NiMH or 2 cell lipo
06-24-2015, 10:36 AM | #3 |
Newbie Join Date: Jun 2015 Location: Grants pass
I've got on board audio on my wraith it's so sweet!! What info do you want??
06-24-2015, 10:49 AM | #4 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Hhhmmmm, interesting. Which is cheaper?
06-24-2015, 10:54 AM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Associated ESS or Traxxas OBA? |
06-24-2015, 11:02 AM | #6 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
can the traxxas system work with aftermarket radio? couldn't you set a bec to power it?
06-24-2015, 01:15 PM | #7 |
the way it is wired, I would certainly say you could use a BEC to power it!!! Great call! I think I heard someone say as long as the radio has a 3rd channel it will work. Used as a neutral so you can rev the motor without going anywhere. |
06-24-2015, 11:13 PM | #8 |
I was reading on a traxxas forum and he had a standard 2-channel radio and it worked fine with the on board audio... Even though the traxxas system doesn't have different sounds, it put out mor than twice the volume! I can't even hear the electric motor over the on board audio!!!
06-25-2015, 06:04 AM | #9 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
I have the ESS in my Yeti. Fits nicely above the battery tray and under the body. It doesn't have any voltage regulation so you can run on 3S, but you need to watch the volume or it will blow the speaker out. The different available sounds make for a great setup. Depending on how quickly your rig accelerates you can play with the different sounds to match. My throttle curve has a bell in it so at half throttle I'm not going very fast. I found a sound file that works well with that. If you have a very steep slope throttle curve, there are several sounds that ramp up very quickly. Not being waterproof sucks, but I just watch what I do with it. You could wire in a bec to always have it at 8.4v or whatever. The default wiring is to fit in parallel to your esc/battery connection without having to solder anything. This is really nice if you want to take it out for water/snow runs. Just be sure you use an extension cable from your rx so you can plug/unplug outside the rx box. |
Associated ESS or Traxxas OBA? - Similar Threads | ||||
Team Associated's ESS-One Engine Sound System | JatoTheRipper | Electronics | 24 | 10-12-2015 03:26 PM |
ESS-One Engine Sound System Review | Theibault | Electronics | 0 | 11-29-2014 09:06 AM |
ESS-YOU-Y_V!! WJ on OCP60 Axles | YoUnG_vErSiOn | Large Scale Rigs | 10 | 02-18-2013 05:34 AM |
METALHEAD'S Ess See Ecks Ten | METALHEAD | Axial SCX-10 | 66 | 11-20-2009 10:57 AM |
