01-23-2015, 06:53 AM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Newfoundland Canada
| Yeti Kit Rear Driveshaft Issue
Got my kit yesterday and started the build. When I got to the part of assembling the rear driveshaft followed the directions per instructions. Once I screw in the set screw to hold the shaft to the transfer case output the driveline gets super tight. Without the driveshaft on its super smooth but as soon as the set screw is in place everything tightens up. The only thing I see would cause this is the yoke on the driveshaft is rubbing the t-case. Any suggestions ? |
01-23-2015, 08:10 AM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: Yeti Kit Rear Driveshaft Issue
The output shaft on the transfer case needs flipped around. One side is longer than the other.
01-23-2015, 09:25 AM | #3 |
| Re: Yeti Kit Rear Driveshaft Issue |
01-23-2015, 09:29 AM | #4 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
I have experienced the same issue, OhioSS' solution made it right.
03-21-2015, 03:09 PM | #5 |
Rock Stacker Join Date: Nov 2008 Location: THE COOP
I had same issue. This fixed it. I went back to the manual and it is actually a mistake in the manual.
03-21-2015, 04:36 PM | #6 | |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: Yeti Kit Rear Driveshaft Issue Quote:
Glad you guys all got it fingered out though! | |
11-13-2015, 01:39 AM | #7 |
Quarry Creeper Join Date: May 2012 Location: Berlin
I came to this same conclusion and had to flip mine when I built it. Glad I wasn't the only one.
11-13-2015, 10:13 AM | #8 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
Are they all the same?Or the newer versions are coming the right way?
11-13-2015, 10:18 AM | #9 |
Yeti Kit Rear Driveshaft Issue - Similar Threads | ||||
Axial Yeti: Rear Sway Bar Quick Disconnect Kit | CarterFab | Axial Yeti | 4 | 08-13-2019 02:20 PM |
Lift kit/driveshaft issue | Bn2h8 | Axial SCX-10 | 6 | 04-23-2014 08:01 AM |
driveshaft issue | Exocaged | Axial AX-10 Scorpion | 3 | 11-12-2013 10:52 AM |
RCBros Honcho rear leaf kit issue | 1BadJeepBruiser | Axial SCX-10 | 17 | 10-31-2010 12:30 PM |
