vanquish centered axle shafts to GCM centered housing compatibility Wraith/Yeti Centered Pumpkin Rear Axle Shafts - Vanquish Products Hello I've recently twisted the tang off of an axle in my Yeti running a GCM centered housing and custom shafts, and was wondering if the new Vanquish centered axle shafts will fit my housing for a quick off the shelf replacement? |
Re: vanquish centered axle shafts to GCM centered housing compatibility I assume they would and if they do would be the best option. Only one way to find out for sure. |
Re: vanquish centered axle shafts to GCM centered housing compatibility I would assume they would but I can tell you for sure that these fit (I have the GCM axle also) and have been holding up fine for 3 months now... Replacement Axle Shafts for Aluminum Rear Centered Axle Housing / Axial Wraith |
Re: vanquish centered axle shafts to GCM centered housing compatibility Yes thats what GCm says to use. I would go chromoly over those personally. |
Re: vanquish centered axle shafts to GCM centered housing compatibility Yes the RC4WD axles were one of them Chris recommended, I guess I'll be the guinea pig and try a set of Vanquish they should be good. |
Re: vanquish centered axle shafts to GCM centered housing compatibility I ended up ordering a set of these shafts last night, guess we'll know if they fit in a day or two. If they fit I suppose the chromoly will hold up better than anything available. |
Re: vanquish centered axle shafts to GCM centered housing compatibility Wish I saw this yesterday, I just built my currie and could of gave a bunch of measurements. Interested to see the compatibility |
Re: vanquish centered axle shafts to GCM centered housing compatibility I just installed them yesterday, looks like the drive pins might rub on the little bearing retainers cups because they don't have the shoulder on the shafts to keep the tangs from going into the locker too deep. I'll either just let them create their own clearance or drill the cups out so they just retain the bearing with the outer race. They look stout though. |
