02-11-2015, 04:08 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
| yeti gearbox question
Call me a dumb hillbillie, but i found under the main slipperplate spareroom for an bearing bushing and i placed it there. Know this mod from the ax10/wraith housing to avoid flex on the mainshaft und lower noise. |
02-23-2015, 12:25 AM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: Roseville
| Re: yeti gearbox question
Following
02-23-2015, 09:17 AM | #3 |
Newbie Join Date: Dec 2014 Location: NY
Good find. What size bearing did you use and did it make any difference while running? Sent from my iPhone using Tapatalk |
02-23-2015, 05:45 PM | #4 |
Its the standard bearing (axle, knucklearms) U will like the afford over the months. Less stress on the shaft will reduce ugly sound effects beeing the spur elliptic offcenter |
02-23-2015, 08:30 PM | #5 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
And I just happen the have a spare bearing or two.....
02-27-2015, 06:58 PM | #6 |
Rock Stacker Join Date: Feb 2015 Location: Maryland
| Re: yeti gearbox question When I upgraded to the steel spur gear and machined slipper plates my spur gear had about 1mm wobble in it. Luckily I remembered this post and installing the bearing straightened everything out. |
yeti gearbox question - Similar Threads | ||||
Yeti xl esc question | JS6011 | Axial Yeti XL | 3 | 12-24-2014 12:40 AM |
Question for those with Yeti and Wraith | A8ball | Axial Yeti | 3 | 09-03-2014 07:34 AM |
Bullhead / Clodbuster Gearbox question | lindorf | Tamiya Clod Buster | 3 | 10-07-2012 04:43 PM |
xr10 gearbox question | docsrcrepair | Axial XR10 | 8 | 11-06-2011 04:56 AM |
Tamiya planetary gearbox set question | str8axle | General Crawlers | 3 | 01-12-2007 08:35 PM |
