03-30-2015, 06:37 AM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: Okinawa, Japan
| HobbyWing 3400kv Sensored Xerun Gearing and settings?
I ordered the this hobbywing sct pro ezrun setup. 3556sd 120a esc For those of you out there running this as well, what gearing are you running and what temps is it generating? Also what settings on the esc? I had planned on running stock gearing on 3s, what do you think? |
03-30-2015, 08:39 AM | #2 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Re: HobbyWing 3400kv Sensored Xerun Gearing and settings?
I haven't seen people running that comb on here. That doesn't mean anything, but you may not find a direct on point answer. That said, the motor is a 4 pole and is likely a little weaker than the stock motor in the RTR. As for gearing, you are running a motor that is 8% faster than the stock motor (3400 KV as compared to 3150). The gear ration as between the pinion and spur in stock form is 16P and 64S (4:1). If you drop down one tooth to a 15T pinion, you will get a gear ratio of 4.267:1. The difference is approximately 6.7% meaning that you will get approximately 1.3% greater speed than a stock axial Yeti with that set up. I should tell you that the stock motor was undergeared from the factory, so you may be just fine with the 16T pinion or may be able to use an 18T pinion if you desire more speed. The programming template is available here: HOBBYWING TECHNOLOGY CO., LTD. Some suggestions: Drag brake: This depends on if you are a high speed runner or a crawler. Crawlers like more drag brake, but high speed runners like less to increase stability. I would run 10-20% drag brake and see how you like it. If you are a crawler, go ahead and start at 40% and move up from there. Punch: This is all up to you. I like my settings punchy, but it comes at the price of low speed control. I would keep the stock settings at level 5 and see how you like it. With a 4 pole motor you probably have all the power you need without a crazy punch setting. Brake Force: I suggest keeping it at 50% Neutral Range: This depends on your transmitter. I like a narrow gap as it makes the trigger feel more connected. Timing: The $64 million dollar question. Timing adds heat and greater RPM to a motor. Generally 4 poles don't need or want timing and you are better set to go up to a larger pinion gear if you want greater speed. That said, I run my 2700 KV 4 pole motor with 10 degrees of timing. I would suggest you play around with it and see what gives the best performance given your driving style and the temp on the motor. I have found that with 0 degrees of timing the last 25% of the power band feels noticeably softer in most motors. With a 2 pole motor (not that you have one) I run a ton of timing to get a huge push in the mid range and upper RPM power band. Play around with the timing setting and check temps! Some motors have almost no reaction to timing while others require one particular amount of advance to be happy. Try to keep the motor temps below 160 at the end of a run and you will be golden. Other Settings: I would not fool with the rest of the settings. Keep the heat protection on and auto lipo detect active. There are a bunch of people running the motor as a crawling motor in other Axial products that you can read about here: Hobbywing xerun 3656 3400kv |
03-30-2015, 10:40 AM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
The 120amp ESC you have is great. I have a few HobbyWing ESC's. 150a, 120a, 60a... They all are very adjustable. I keep my settings in the middle of the range. I keep my punch setting on 4 of 9, I believe that's the range. About 40%, regardless. Same with my timing. Brake force at 75% Drag brake on 5% at the moment. That varies as far as what I'm doing. Bashing = 5% - 10% Crawling = 20% - 40% Drag. As far as your motor, its great! Much better than people realize. Check out this thread. R/C Tech Forums - View Single Post - Hobbywing XERUN 3656sd 4wd SC 540 4 pole motor Thread I have the 3656sd 4000kv in my Wraith. Crawls very well. Geared down to 60/12. on 3s its very quick. You will be very happy with your purchase. No matter what settings you choose. |
03-30-2015, 03:32 PM | #4 | |
| Re: HobbyWing 3400kv Sensored Xerun Gearing and settings? Quote:
03-30-2015, 03:56 PM | #5 |
Great answers guys!!! This was so much help. Thanks for taking the time. |
03-30-2015, 03:59 PM | #6 |
Pebble Pounder Join Date: Jan 2015 Location: USA!!!
I run that motor/ESC combo but 4000kv with factory setting and stock gearing. The programing box I received is defective so I cannot change the settings. Regardless, the thing hauls! It will lift the front wheels from any speed. It does run a little hot, then again I live in hot south Florida and I drive the snot out of it. I have had the ESC put itself into safe mode with dramatically less power available 2 or 3 times. This only happened after 30+ min of pretty much full throttle high speed runs. I got a integy motor heatsink and fan to see if that helps out at all
03-30-2015, 06:35 PM | #7 | |
Each to his own, not trying to start a pissing contest. | |
03-30-2015, 07:04 PM | #8 |
No quarrel here. I buy chinese all the way. Hence my 45 dollar 4065 leopard motor including shipping. It's stupid powerful. I even have a few no name motors in my drawer. Count me in for a bargain.
03-30-2015, 11:44 PM | #9 |
Agreed, I got this sensored esc/motor with programmer for 111 shipped. I wanted to do the tekin pro4hd but didn't think it would be worth over a hundred difference for the tekin plus mmp and castle link.
04-02-2015, 12:32 AM | #10 |
Newbie Join Date: Apr 2007 Location: france
Hello, I have this motor in my yeti. I use the standard 16t pinion for bashing, very impressive with 3s Lipo: very good top speed and does wheelies on asphalt or grass. For crawling, I use a 12t pinion, its smoother and gives better run times and less stress for the esc. Can't wait to have the two speed components. |
04-02-2015, 04:17 AM | #11 | |
04-02-2015, 06:02 AM | #12 |
Temp was a little high, but now I use a fan on it and it's very good.
04-02-2015, 09:16 AM | #13 |
| Re: HobbyWing 3400kv Sensored Xerun Gearing and settings? |
04-02-2015, 10:42 AM | #14 |
I have to beat the piss out of my truck to get my motor to get warm. Geared 56/12 Its on my wraith at the moment. Even on 3s the MMP and 4000kv stays quite cool. |
04-02-2015, 12:17 PM | #15 |
04-02-2015, 12:22 PM | #16 | |
Quarry Creeper Join Date: Apr 2014 Location: USA
I'm used to bashing with this motor in a rig that'll do 45+MPH easy (on 3S). Love the motor, seems like a good choice for my Yeti kit . Okinawa - did you go with the 3400KV? What pinon and how do you like it? Last edited by IPT; 04-02-2015 at 07:17 PM. | |
04-02-2015, 10:54 PM | #17 | |
I only went with this combo because I wanted a sensored setup and got this setup with programmer for $111. I've had good luck with hobbywing in the past. Otherwise I would have ran the pro4hd 3000kv and et3s ESC | |
HobbyWing 3400kv Sensored Xerun Gearing and settings? - Similar Threads | ||||
Hobbywing xerun 3656 3400kv | Gvm23 | Electronics | 26 | 01-30-2014 01:23 PM |
Hobbywing Xerun Sensored brushless combo. | Neeley | Electronics | 2 | 01-20-2012 04:47 AM |
