04-12-2015, 10:26 AM | #1 |
Rock Stacker Join Date: Feb 2015 Location: North Bend
| Yeti kit rear dif. mesh
Putting together the rear diff. from the kit. I can't seem to dial in the mesh. When I cycle the pinion it moves free for about half cycle and then it gets harder to turn. Then it cycles free for another half cycle and then gets hard to turn again. I've taken it apart and rebuilt it a couple of times and still get the same resistance. Is a little resistance in two spots "OK?" I've got the rear axle from my RTR Yeti to compare which seems to cycle with no resistance at all. Not sure if that's a fair comparison. Should I be ok with the resistance or look for options? What are the options? My Yeti RTR is my first hobby-quality RC and the kit is the first kit I've built so I'm learning as I go. |
04-12-2015, 10:43 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Yeti kit rear dif. mesh
Stock r and p ? If it is the hardened od/ud gears they tend to do that, no worries. Just dont shim it overly tight and it will break in.
04-12-2015, 10:44 AM | #3 |
Do you share your last name with a famous designer ?
04-12-2015, 11:41 AM | #4 |
| Re: Yeti kit rear dif. mesh Yes using whatever stock parts provided directly out of the kit. I haven't done anything with shims. Should I try and shim it or run it and see if it will break in?
04-12-2015, 11:42 AM | #5 |
| Re: Yeti kit rear dif. mesh |
04-12-2015, 09:06 PM | #6 |
I was checking to see if you where my ex brother inlaw. You would have understood if you were him.... You live in Washington ?
04-13-2015, 01:00 PM | #7 |
04-13-2015, 02:43 PM | #8 |
About 20 miles down 18 from you. Look up warcrc.net or nwscalerc the clubs hold monthly u4 races. Both clubs have web forums and FB pages. Of coarse nothing beats the info you will gather here |
04-13-2015, 05:00 PM | #9 | |
| Re: Yeti kit rear dif. mesh Quote:
I've been to the RC shop in Covington and bought some parts, got good advice, and signed the waiver to run on their U4 track. It's hard to get down there and give them my business but I'm planning on going in there whenever I'm down there to run on their track. Hoping to get out and do the U4 races for sure. | |
Yeti kit rear dif. mesh - Similar Threads | ||||
Axial Yeti: Rear Sway Bar Quick Disconnect Kit | CarterFab | Axial Yeti | 4 | 08-13-2019 02:20 PM |
Yeti Kit Rear Driveshaft Issue | stone202 | Axial Yeti | 8 | 11-13-2015 10:18 AM |
rear bevel mesh issue with vanquish axle | hellfire360 | Axial Yeti | 10 | 03-25-2015 03:10 PM |
Rear ratio / pinion & spur mesh | Matthewboerner | Axial Wraith | 3 | 11-06-2011 12:00 PM |
