04-23-2015, 12:06 PM | #1 |
| SSD 2 Speed Install and Review Got my 2 speed in, thought i would post up a little install and review thread. I really like the large clear instructions. for a piece like this i was glad to have them. First thing i did was remove and clean the trans. dont want any debris falling in and sticking to the lube when you open the case. Step 1 assemble shift fork i skiped step 2 leaving the bearings in the case. Step 3 install bearings in gears normally i would have liked to see rubber shielded bearings, but inside a sealed trans this is not needed, infact the metal sheilds are more effecient with less resitance. Bearings seemed to be pre oiled but i added 3 drops each just in case. Step 4 slide on cog ring the cog ring on the hex shaft was a hair loose but i assume this is done to help it slide/shift easier. Step 5&6 slide gears and washers on. i skiped step 7 leaving the bearings in the case Step 8 slide on shift fork onto groove. i have to say i was REALLY impressed with all the tolerances.everything nearly snaps together its so perfect. excellent fit and finish. on par if not above VP. Step 9 install into trans. i test fit here. you have to remove the little plug from the inside of the case to allow the shift fork shaft to slide threw. after test fit i removed and lubed. i prefer Lucas Red and Tacky #2 Step 10 reinstall trans into yeti and assemble shift linkage using left over short axial rod ends. Step 11 install servo mounts. i will say these for being so simple they are quite impressive, they have to fit some odd angles and offsets especially the front one, and they fit just perfect. well all the hardparts are installed. next up electronics. just awaiting a servo saver to come in. ill cover servo/radio setup and do some testing and a review. stay tuned Last edited by STANG KILLA SS; 04-23-2015 at 12:08 PM. |
04-23-2015, 01:21 PM | #2 |
Newbie Join Date: Apr 2007 Location: france
| Re: SSD 2 Speed Install and Review
Nice, can't wait to have mine installed.
04-23-2015, 02:24 PM | #3 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Sub'd for the build up. Don't know that I ever plan on installing a 2-speed, but still want to see how it all works and fits together.
04-23-2015, 09:26 PM | #4 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
Sick. Looks soooo nice. Those guys kick ass! Love the garage
04-24-2015, 09:34 AM | #5 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Finally pics of install and a (partial) review. All the griping over Axial slacking off on the 2 speed and all the excitement over this kit from SSD and nobody has posted much on it. Keep us updated!
04-24-2015, 09:56 AM | #6 |
Rock Stacker Join Date: Mar 2015 Location: Clarksville
I'm surprised SSD didn't do a decent write up on it. I'm waiting at least one decent pic/review before I order it.
04-24-2015, 12:07 PM | #7 |
Rock Stacker Join Date: Jan 2013 Location: loveland
I installed mine last night and it was as simple as that. Everything fit nicely and seems to shift smooth. I only tested in my basement so far but I'll give it a work out this weekend
04-24-2015, 06:29 PM | #8 |
Rock Stacker Join Date: May 2011 Location: WA
I installed mine and shifting seems kinda sticky, I greased it and used a servo saver. Donno my issue lol
04-25-2015, 01:55 AM | #9 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD 2 Speed Install and Review |
04-25-2015, 07:26 AM | #10 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
04-27-2015, 02:45 PM | #11 |
Also use plenty of grease on the shift for as the shift lock will spining around it during use.
04-27-2015, 04:58 PM | #12 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
Looks like a quality item. I think I'll add it to my kit's part list.
05-02-2015, 01:15 AM | #13 | |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
| Re: SSD 2 Speed Install and Review Quote:
You have to make sure you put the right travel on your servo... hope that helps.... INVEST IN ONE OF THESE...... Last edited by rustneversleeps; 05-02-2015 at 01:21 AM. | |
05-06-2015, 01:08 PM | #14 |
Ok servo saver came in and ive pretty much got this install wrapped up. first I pulled the motor, Esc, and steering servo to run the shift servo wire to the receiver. I gotta say this is pretty cool of axial. then I spent some extra time to make the tierod as straight and parallel with the shift fork shaft as I could. make the tierod as short as you can. with the motor/trans not spinning, I was getting a bit of some binding usually only when the servo was pulling the tierod. the shift fork shaft would get kinda sideways and hang. however, with the end points adjusted and with the motor/trans spinning it seems to work perfect everytime im using the Kimbrogh medium size servo saver here. came with splines for all brands of servos. for setup on a Futaba 4PL first activate your switch, I used DT4, the lowest switch on the grip. and set it to 2 Position then setup your channel 3. mine needed reversed. I started with +/- 30 ends points to start with. ended up here. working video! im getting a bit of noise in 2nd gear, but im hoping that will smooth out once gears are broken in. Also a nice peak at the sweet SSD Scale Yeti knuckles here. |
04-13-2017, 01:34 PM | #15 |
Newbie Join Date: Mar 2017 Location: St louis
Sure glad this write-up exists. Evidently, SSD doesn't include an instruction sheet any more. |
04-13-2017, 02:05 PM | #16 | |
04-28-2017, 11:27 PM | #17 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
What's the long term results been on the 2 speed? I just installed the SSD kit. Still working out the kinks & dialing it in.
04-29-2017, 07:04 PM | #18 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
I'm thinking about one for a Bomber and SCX10.1 in the future. Is it a simple bolt in for the Bomber and does it fit the SCX10.1? |
04-30-2017, 09:26 AM | #19 | |
Compared to before, shift action/throw is 100% improved. There's still a few hang ups, leaving it in "neutral" but each consecutive shift is more precise & engages more positively. I'm sure after a few runs (and me learning the ideal point to shift) it will be smooth & easy going as things settle in and wear together. Here's the parts I used: AX31183-8 AX31183-4 AX31183-6 | |
04-30-2017, 10:08 AM | #20 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
In my admittedly very limited experience My Yeti far outshines my Wraith as a "go almost anywhere" trail truck. The SSD 2 speed gear set is a part of the reason for this.
SSD 2 Speed Install and Review - Similar Threads | ||||
ssd yeti 2 speed | JesterSpec | Axial Yeti | 235 | 06-29-2016 04:43 PM |
To the guys gearing up for the SSD 2 speed! | molina | Axial Yeti | 18 | 05-05-2015 08:23 AM |
SSD 2 Speed and DX4C help! | molina | Axial Yeti | 8 | 04-23-2015 11:29 PM |
CK Aftermarket Parts Install Review | Drakeremoray | HPI Wheely King | 2 | 08-13-2010 02:31 PM |
