08-19-2015, 10:50 AM | #21 | ||
Newbie Join Date: May 2015 Location: Illinois, USA
If you use something as thick and sticky as you describe, doesn't that essentially lock the diff? Last edited by THX_138; 10-26-2015 at 10:52 PM. | ||
08-19-2015, 01:26 PM | #22 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: Unlock rear diff
I have mine unlocked with 2.5 mil diff fluid and it's definitely not locked, still allows slip. I did add additional o-rings to the axle shafts just to hold the orange o-rings in place.
08-19-2015, 06:03 PM | #23 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Neither the ½ or the 1mill fully lock the axle, they're tight make no mistake of that but they're not locked. From what I've seen of the stock weight fluid in the front I'd just use grease instead to lubricate the gears cos it's so loose with that stock stuff it's not even worth bothering with. |
08-19-2015, 06:28 PM | #24 | |
| Re: Unlock rear diff Quote:
Only other option I can see to run very thin diff fluid is to drill a 2.5mm (3/32") hole in the diff centre case so you can plug it with a short M3 grub screw. Just work out which part of the diff case isn't the bit where the cross pin sits. Should work with the plastic case but an upgrade to alloy would be better, in this case you'd be drilling right through the HR logo. RPP hobby.com |Hot Racing CNC Aluminum Differential Case Axial TowerHobbies.com | Hot Racing CNC Aluminum Diff Cup Exo Wraith AX10 SCX10 Last edited by altd896; 08-26-2015 at 09:42 AM. | |
08-19-2015, 07:12 PM | #25 |
Newbie Join Date: May 2015 Location: Commiefornia
I just assembled my new SSD Wide Centered Axle with the diff unlocked. I used water repellant bicycle grease & packed it in. O-rings on the inside only. Feels smooth. Haven't run it yet, as Im still assembling my kit & going off the map by turning it into a Trophy Truck. |
08-25-2015, 02:06 PM | #26 |
Pebble Pounder Join Date: Jan 2015 Location: USA!!!
I just ordered a gear set, shafts, o rings and e clips. Anything else I need? I was only able to find associated 100k, is that going to be too thin? Someone should make a diy |
08-25-2015, 08:52 PM | #27 | |
100K might be ok, depends on how/where your driving. | |
08-26-2015, 07:16 AM | #28 |
Pebble Pounder Join Date: Aug 2015 Location: Jackson
I use 20,000 in mine.. Works fine for my application..
08-26-2015, 07:38 AM | #29 |
| Re: Unlock rear diff I mostly drive in tall grass, sand, gravel and cement. I do an occasional hill climb on the same terrain. I run a 3200k sct motor on 3s and beat the crap out of it
08-28-2015, 09:56 AM | #30 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
You could try drill a small hole in the Diff housing and completely assembling the axle less the diff cover. With a syringe or something fill the diff up and the screw in a set screw. Therefor everything is in place before filling and less of a chance of it leaking out.
Unlock rear diff - Similar Threads | ||||
unlock rear diff | turboed13b | Vaterra Twin Hammers | 6 | 08-19-2013 09:57 AM |
Spider gears in rear diff (aka losing the rear locker) | Sethmetal | Vaterra Twin Hammers | 2 | 02-26-2013 11:57 PM |
Rear Diff | 88gators325 | HPI Wheely King | 2 | 09-20-2009 09:05 AM |
rear diff? | rokker32 | Losi Mini-Rock Crawler | 3 | 08-10-2009 04:39 AM |
cc-01 rear diff. | cspyy | 1.9 Scale Rigs | 0 | 02-15-2008 08:05 PM |
