07-26-2017, 06:06 PM | #1 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Robinson Gen3 slipper
I'm in the process of giving my yeti some much needed love and a facelift. One of the upgrades I decided to do is install the Robinson Gen3 slipper unit. Doing some bench testing on it today and noticed there's tiny metal flakes coming off the pinion/spur. Is this normal upon initial use? I'm thinking it's just the metal on metal wearing into settling into each other but don't want to damage it before I can even drive it. I feel like the mesh is set pretty good but don't want to back it off to far and bust a tooth on my pinion gear or something. Is it normal to have some metal wear off like this?
07-26-2017, 06:45 PM | #2 |
Newbie Join Date: May 2017 Location: Gretna
| Re: Robinson Gen3 slipper
I recently installed the same thing and experienced the same issue. I've ran 6 6500mah 3s packs through it since install and had no issues with the slipper or pinion. Ended up blowing out the transmission on the 4th pack, but I don't think that had anything to do with the slipper. Sent from my iPhone using Tapatalk |
07-26-2017, 06:55 PM | #3 |
That's good to hear. I just upgraded the tranny and transfer case to aluminum cases with hd gears throughout so that should hold up fine. Finally ditched the rtr electronics and went to a monsterX/HH 3500kv xl combo. Do you run a spur cover robowarrior? Thinking I should for a few packs, then open it up and clean it out. Are you still seeing metal flakes after 6 packs?
07-26-2017, 07:18 PM | #4 |
I've run mine for over a year, initial wear was minor, clutch needed constant adjustments, and one day it had seated and no adjustments. I've started setting mesh by sound and feel. With the 32p I don't run covers on either truck Hang up and Drive |
07-26-2017, 07:32 PM | #5 |
Thanks mike. It's good to know I'm not experiencing something too drastic. Was definitely worried when I saw metal shavings...
07-26-2017, 07:50 PM | #6 |
What i think it is is a hard black shipping coating. My teeth seem brighter Hang up and Drive |
07-27-2017, 04:41 AM | #7 | |
| Re: Robinson Gen3 slipper Quote:
I am running the exact same motor and esc combo in mine. I do run with the spur cover, as the area I run in is pretty sandy. The flakes did go away after a few packs, but came back after changing to new different sized pinion. I think it's just wearing whatever finished/coating that RRP puts on their hardened spurs and pinions. Sent from my iPhone using Tapatalk | |
07-27-2017, 08:50 AM | #8 |
i run in a sandy dirt area myself. I'll get a few packs through this thing soon and keep an eye on it. Now I can continue making progress and not be so worried about it. Appreciate the help
07-28-2017, 05:09 PM | #9 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
This is completely normal, its basically a break in process. The same will happen if u set your gear mesh to tight also. The thing to remember is that these two gears take the raw power from your motor and are being pushed every time u drive, that is why an absolute steel gear will shred apart a non hardened gear every time.
07-28-2017, 05:24 PM | #10 |
Hmm. You made me realize I probably should've bought a hardened pinion gear too...
07-28-2017, 05:30 PM | #11 |
Yes u need that for sure. The worst that will happen now is that your spur will destroy your pinion and metal shavings will be everywhere.
07-29-2017, 07:35 AM | #12 |
It'll be added to the next order I put in
08-05-2017, 03:18 AM | #13 | |
Rock Stacker Join Date: Mar 2015 Location: Houston
See, I would be inclined to think the opposite…you have a quality slipper clutch installed yet you blew up the tranny?…I'd say that your tranny is blown BECAUSE of the slipper clutch…the slipper clutch that was setup all wrong and instead of allowing some slip to protect the drivetrain from shock, instead allowed the drivetrain shock to travel right through the over tightened slipper and therefore causing the tranny to absorb the shock…which, of course, broke the drivetrain that the slipper was designed to protect But hey…that's just one man's opinion… Why, again, did you install the slipper clutch in the first place? Sent from my Apple iPhone 7…which, as you know, clearly defines me as being superior to you in every way | |
09-02-2017, 02:06 PM | #14 |
Newbie Join Date: Aug 2017 Location: south jersey
how does this effect performance vs the stock slipper? why is it any better?
09-02-2017, 02:45 PM | #15 |
Newbie Join Date: Jun 2016 Location: Canada
I have run RRP slippers in Slash's and I have found them to last a long time under extreme slipping conditions. The Slash has a plastic gear that melts to nothing when you thrash the truck. Strangely they don't like to get wet and tend to rust on the shaft and not let the spring apply enough pressure to grip and then you think something is blown. Always try to run the same RRP hardened pinions with their spurs because not all "hardened" gears are the same. For the cost of them I would just run a 32 pitch traxxas gear and regular steel pinion instead.
09-02-2017, 03:34 PM | #16 | |
The stock either is too tight, or too loose.You want slip when grip has you bound up, I find if I hear the slipping , I turn a bit more or less and that will let me get thru, or just plain stop and then back or whatever is needed to unbind Hang up and Drive | |
Robinson Gen3 slipper - Similar Threads | ||||
Top Shaft for Robinson Racing GEN3 Slipper | RCDad57 | Axial Wraith | 3 | 10-16-2016 11:31 PM |
Robinson slipper 56T Gen3 Slash | sixhundred71 | Axial Wraith | 2 | 03-25-2015 07:38 AM |
Robinson Racing Gen3 Slipper | ednerin | Axial Yeti XL | 1 | 01-23-2015 08:08 PM |
Robinson Racing Gen3 Slipper Unit | cmnyj28 | Axial Wraith | 18 | 06-19-2014 06:11 PM |
