Strc lower links has anyone had or having issues with pulling the plastic ends off the strc lower links? i just bought a pair and people are already telling me i should of went with a one piece design. thanks |
Re: Strc lower links i am mid build of my kit... i have those on my bench for this build. i got the upper and lower rears to go in. So far the plastics in this kit i am less than impressed with. I think ill be looking at different plastic ends soon |
Re: Strc lower links i just put the plastic ends onto the strc lower links. i added a little CA to the threads of the set screw that goes into the plastic. there isnt much meat around the ball itself so i could see them breaking there. |
Re: Strc lower links had a failure with the new links within 5 minutes of 1st run with them. http://i62.photobucket.com/albums/h9...ps9t10tnpt.jpg |
Re: Strc lower links If I was you and I wanted to make those work, I'd drill and tap the ends of the trailing arms to 4mm and get some revo rod ends and 4mm grub screws. If it was me, I'd get the UCFAB or VP and be done with it. |
Re: Strc lower links Ucfab all the way!! They are sooooo nice. Mine make me smile every time I see them. But you will need revo 4mm ends for impact at good speed |
Re: Strc lower links i bought some UCfab arms. |
