05-23-2015, 11:40 AM | #1 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Cooling stock esc & motor
hi all, just been running my yeti in 2S with the massive proline super swamper XL 2.2" : the motor is very hot and the esc is rpetty hot, should I add fans before burning the yeti to the ground ! As anyone got the same issue or keeps running in the same conditions. I was also thinking of changing the pinion to go faster, not good for the heat ! Might change the parameters in the ESC with the usb castle adapter, to lower the torque while starting. |
05-23-2015, 11:45 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
You need to drop your pinion size down 3 or 4 teeth and check for binding. I always start at a 10t pinion and work up. If I run a full pack and temps are good I go to an 11 t and so on till it's 100 outside and my max temp is 140.
05-23-2015, 02:05 PM | #3 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Cooling stock esc & motor
There is a thread about this. With stock tires they drop 2 teeth on the pinion. With the taller tires as already stated, may need to drop more.
05-23-2015, 03:44 PM | #4 | |
| Re: Cooling stock esc & motor Quote:
It's not going very fast at the moment ! | |
05-23-2015, 03:49 PM | #5 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Easiest way to combat that, is to get a higher voltage battery.
05-23-2015, 04:00 PM | #6 |
| Re: Cooling stock esc & motor |
05-23-2015, 06:40 PM | #7 |
Newbie Join Date: Mar 2015 Location: White Bear lake
I dropped to a 13t pinion and haven't had an issue since. Was told in another thread that axial tends to over gear the models. But I went down that far since I wasn't looking for speed. With the Ssd two speed it does just fine.
05-23-2015, 07:12 PM | #8 |
05-23-2015, 11:23 PM | #9 |
| Re: Cooling stock esc & motor You may have other issues going on....can you post a video of your car and perhaps a snap shot of your esc settings from a computer (castle link screen)?
05-24-2015, 02:56 PM | #10 |
Quarry Creeper Join Date: Nov 2014 Location: WA
maybe the timing is too high...
05-25-2015, 01:13 AM | #11 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
Ive been running on the RTR motor/esc on 3s for a while now without any heat issues. All stock esc settings. I do have an aluminum motor plate and a cheapo finned heatsink on the motor for peace of mind. I even moved down to a 56t spur/ 20 pinion. Try a 3s pack. Even if you still need to drop a tooth or two on the pinion, it'll still be faster than 2s. |
05-25-2015, 02:15 AM | #12 |
05-26-2015, 08:00 AM | #13 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
Take that Sensorless motor timing to 0, it will really lower the motor temps.
Cooling stock esc & motor - Similar Threads | ||||
Stock ESC & motor how do you like it? | tapped-out | Axial Yeti | 7 | 11-27-2014 06:09 AM |
