05-25-2015, 08:54 PM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Eugene
| Help with throttle after installing centered Currie!!!
So I got my centered Currie installed and everything buttoned back together. I flipped the front diff like they say too and am assuming that is what reversed my throttle. Forward is reverse and reverse is forward. I flipped it on my DX4C and now goes forward with forward and reverse with reverse. My question is do I need to go into my ESC (mamba max pro) and change the setting? It really gets after it in reverse but not so much on forward. Assuming it's set up to have more forward get up and go than backwards.
05-25-2015, 09:16 PM | #2 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Help with throttle after installing centered Currie!!!
yeah its best to go into castle link and reverse the motor in the software, especially if its a sensored motor.
05-25-2015, 09:17 PM | #3 |
It is sensored. Is there a setting to simply reverse it?
05-25-2015, 09:17 PM | #4 |
I wanna be Dave Join Date: Sep 2004
by chance did you unplug your motor? by just reversing two of the wires from the motor to the esc will cause it to run in reverse.
05-25-2015, 09:18 PM | #5 |
I didn't. I haven't touched anything but the axle and the front diff, but I will check to make sure.
05-25-2015, 09:19 PM | #6 |
05-25-2015, 09:22 PM | #7 |
i havent switched to another axle so maybe what bad hoopty was saying is whats going on. sorry if i caused any more confusion.
05-25-2015, 09:24 PM | #8 |
Hey no problem! Any idea is a good idea! I've never ran any different axles either, but had to flip the front diff so I'm assuming that's what did it!
05-25-2015, 10:27 PM | #9 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
Do the setting on the castle link. I have read in many threads that it is bad to reverse the wires on a sencerd motor. The castle link is super easy to do and you can really tweak the way your rig accelerates and brakes.lots of options |
05-26-2015, 12:10 AM | #10 |
Got it guys! Thanks again! Switched the settings on my castle link and everything worked great.
05-26-2015, 12:31 AM | #11 |
its always good when something is a simple fix. ;) and yeah i dont know why but ive read you shouldnt ever swap a motor wire on a sensored motor. |
05-26-2015, 01:50 PM | #12 |
i wasnt implying that he should swap the motor wires i was wondering if he did when he was taking everything apart. my grammar sucks ;)
Help with throttle after installing centered Currie!!! - Similar Threads | ||||
A little insight on the VP centered rear currie | molina | Axial Yeti | 43 | 07-31-2016 08:24 PM |
Question about the Vanquish centered Currie?? | molina | Axial Yeti | 19 | 05-29-2015 06:29 AM |
Currie centered axle issue | R6MAXX | Axial Wraith | 15 | 04-08-2015 08:17 AM |
