07-28-2015, 07:20 AM | #101 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: SSD Rear Axle
Mine were a press fit, as they should be.
07-28-2015, 04:05 PM | #102 |
Newbie Join Date: Jul 2014 Location: Philly
| Re: SSD Rear Axle
That is what I thought too. But my experience was not press fit. I felt like I needed a hammer to get mine in especially the inner bearing. I never got that in all the way. I'm gonna contact SSD about it. Just wanted to see if anyone ran into the same issue.
07-29-2015, 06:16 AM | #103 |
| Re: SSD Rear Axle
I received my wide axle yesterday, its very impressive. In case you were wondering how much wider the wide axle is over the stock housing: |
07-29-2015, 07:54 AM | #104 |
Newbie Join Date: Jan 2015 Location: Greene County
| Re: SSD Rear Axle
The more I see this axle the more that I like it. SSD listened to the drivers and eliminated the crappy stock lockouts and added bigger bearings for the pinion. There are other nice touches like an integrated truss and bearing caps, and larger axle shafts. If I didn't have so much tied up in my stock axle (Al lockouts, bearing caps, truss, beef tubes, diff cover, ) I would order one of these in a heartbeat. I may end up trying to sell my stock axle minus the lower link mounts, locker, and gears to help fund one of these. |
07-29-2015, 07:55 AM | #105 |
Newbie Join Date: Jul 2015 Location: Cairns, Australia
| Re: SSD Rear Axle |
10-05-2015, 12:40 PM | #107 |
| Re: SSD Rear Axle
Ones wide to use same hubs on all 4 ones narrow to fit a wraith. Sent from my VS986 using Tapatalk |
10-05-2015, 12:42 PM | #108 |
| Re: SSD Rear Axle The Wraith version is the same width as the stock rear axle. The Yeti version is wider than the stock axle and makes the rear width the same as the front (no more wide hubs needed for the rear wheels).
10-05-2015, 02:35 PM | #109 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Re: SSD Rear Axle thanks, I'll stick with the wraith version, a petty not using my SLW hubs ! |
10-08-2015, 11:12 PM | #110 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
| Re: SSD Rear Axle
Any particular reason why the skid doesn't cover the bottom of the axle?
10-09-2015, 01:56 AM | #111 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Rear Axle |
10-09-2015, 12:11 PM | #112 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: SSD Rear Axle |
10-24-2015, 05:11 AM | #113 |
RCC Addict Join Date: Jun 2006 Location: Maryland
| Re: SSD Rear Axle
Want to order this through RPP but how do I know I'm getting the version with the updated stronger axle shafts?
10-24-2015, 05:30 AM | #114 |
| Re: SSD Rear Axle
We haven't changed the axle shafts in the product. We are currently making new HD axle shafts that will be released as an upgrade.
10-24-2015, 05:39 AM | #115 |
| Re: SSD Rear Axle
Good to know, thanks for the quick reply.
10-24-2015, 06:19 AM | #116 |
| Re: SSD Rear Axle |
10-24-2015, 06:21 AM | #117 |
| Re: SSD Rear Axle |
10-24-2015, 06:29 AM | #118 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
| Re: SSD Rear Axle
Ssd- I'm using a VP locker with the setscrews. Centered yeti axle, and the two shafts don't come together in the very middle for the setscrews to get purchase on. I know there's no reason to make them work with another companies product, but wouldn't it be better for them to come within a mm or half mm for maximum contact inside a spool/locker? Much less chance of a locker stripping, less chance of a failure, can't see a downside. I'd buy em. Still waiting for rpp to get those pumpkin skids in stock, missing u4 races today don't wanna hammer up my pumpkin bolts. I should of taken a picture of the two axleshafts and bearing only in at the middle to show the gap I'm talking about. |
10-24-2015, 06:38 AM | #119 |
| Re: SSD Rear Axle
I run the vp shafts too. They don't have the inner bearing collar to stop the from slidding in. I made a small shim that I slide into the locker to keep slight pressure on the outer bearing so I have no in and out play. It will be nice to have an hd shaft bc as much as I love the axle I bent the shaft doing donuts on grass.
10-24-2015, 06:43 AM | #120 |
| Re: SSD Rear Axle
Our flat end is the same as an Axial shaft so it doesn't sound like anything we should change.
SSD Rear Axle - Similar Threads | ||||
New SSD Wide Axle Kit for Yeti | SSD | Axial Yeti | 28 | 02-19-2017 08:17 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
New SSD Narrow Rock Shield Rear Bumper for SCX10 | SSD | Axial SCX-10 | 15 | 06-13-2015 07:01 PM |
