02-01-2016, 07:39 PM | #141 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: SSD Rear Axle |
03-27-2016, 06:16 PM | #142 |
Rock Stacker Join Date: Mar 2012 Location: Truckee
| Re: SSD Rear Axle
When will the diamond skids be back
03-28-2016, 01:52 AM | #143 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Rear Axle
We have plenty in stock. Ask you preferred dealer to get them: WHERE TO BUY |
06-03-2016, 02:12 PM | #144 |
Newbie Join Date: Feb 2016 Location: Louisiana
| Re: SSD Rear Axle
Has anyone had any clearance problems when using a Holmes hobbies locker. I can't for the life of me get it to drop into the axle housing. I've ran it for a while in the stock plastic housing with no problems. It's like either the locker with the bearings on is too wide, or the housings machined spots for the bearings need to be a hair wider. It's sooo close
06-03-2016, 04:21 PM | #145 |
| Re: SSD Rear Axle
Alright, I got impatient and did some sanding on the bearings and got it to all fit together.
06-30-2016, 11:22 AM | #146 |
Newbie Join Date: Jun 2016 Location: worcestershire
| Re: SSD Rear Axle
just wondering what oil/grease you used with your lokar as have this setup on order and need to sort the other bits out.
06-30-2016, 12:36 PM | #147 | |
Quarry Creeper Join Date: Jun 2016 Location: bay area
| Re: SSD Rear Axle Quote:
10-24-2016, 01:18 PM | #148 |
Newbie Join Date: Feb 2016 Location: Poland
| Re: SSD Rear Axle
Hello, sorry for highjacking thread: i recently bought ssd wide diamonda axle and ssd hd shafts. Couple of questions: - when putting in pinion gear should i use two bearings or just one? - are those bearings different sizes or same - i have trouble setting them correclty - tbh inner one is causing issues - if anwser to above is "use some force" - how much is enough? issues described above are 1mm space between main axle parts. Even if i managed to get them correctly lined up and no space is between them problems with spinning the gears appear. I cannot move them freeely until i loosen the screws holding the housing. And still this movement is not smooth. Any ideas how to solve it and what can be the cause? Thanks in advance. Best regards -dm |
09-16-2017, 06:14 PM | #149 |
| Re: SSD Rear Axle
Has anyone got a pair of axles in black and noticed the finish on one is more glossy while the other has a more matte tone to it? I got two offset fronts.
08-31-2019, 02:04 PM | #150 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
| Re: SSD Rear Axle
Where can I buy the delrin skid plate?
08-31-2019, 02:27 PM | #151 |
| Re: SSD Rear Axle
Amain, RPP or RCmart
09-07-2019, 12:38 AM | #152 |
| Re: SSD Rear Axle
Thanks!! Also, wide axle is out of stock, ETA to get back in stock in shops? |
09-09-2019, 12:56 PM | #153 |
| Re: SSD Rear Axle
They order from us most weeks so usually will have things back in stock after a week.
SSD Rear Axle - Similar Threads | ||||
New SSD Wide Axle Kit for Yeti | SSD | Axial Yeti | 28 | 02-19-2017 08:17 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
New SSD Narrow Rock Shield Rear Bumper for SCX10 | SSD | Axial SCX-10 | 15 | 06-13-2015 07:01 PM |
