07-13-2015, 05:57 PM | #61 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: The First Ever of its Kind! YETIX Buildthread!
I was curious how the traxxas front spool is holding up? Have you had a chance to beat on it?
07-14-2015, 01:07 AM | #62 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
Try J-B weld Plastic weld inside the diff cup with the spider gears in place. It holds up.
07-14-2015, 12:25 PM | #63 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: The First Ever of its Kind! YETIX Buildthread! Well, I was gonna do silly puddy, but then I found a revo spool with 6mm outputs, so just to stick with the them of being rediculous, I went that route. If you look back in my thread I have pics of that install. |
07-14-2015, 05:53 PM | #64 |
| Re: The First Ever of its Kind! YETIX Buildthread! No problems with the spool so far, it's down at the moment, I'm waiting on my Traxxas aluminum knuckles and c hubs. The integrity were junk.........suprise, suprise.....lol. |
07-19-2015, 03:55 AM | #65 |
Rock Stacker Join Date: Jun 2015 Location: K
The 68 spur will give you more torque, not top end, the larger 22 pinion will give you more top end, but comes at a price with higher motor temps. Love the build so far, funny how you guys are finally having to deal with the slash 4x4 2.2 wheel dilemma that us slash owners have been fighting with for years. If you wanted a 2.2 tire combo on the slash a few years ago the RPM wide crawler wheels was about your best option. Nowadays guys with the slash 4x4 run 2.2/3.0 SCT wheels and cut down the inner bead on 2.2 crawler tires and glue them on to fit. Sent from my XT1080 using Tapatalk Last edited by stillsmokin875; 07-19-2015 at 04:35 AM. |
07-19-2015, 06:59 AM | #66 | |
| Re: The First Ever of its Kind! YETIX Buildthread! Quote:
07-19-2015, 09:08 AM | #67 |
Pebble Pounder Join Date: Jul 2013 Location: Central Rockies
| Re: The First Ever of its Kind! YETIX Buildthread! |
07-19-2015, 09:45 AM | #68 |
It's about 3/4" narrower than the stock yeti front, but the funny thing is that it makes the front and rear width almost identical when you switch to the Traxxas front. The wheelbase is almost exactly the same as well.
07-20-2015, 04:41 AM | #69 |
Pebble Pounder Join Date: May 2015 Location: UK
07-20-2015, 06:10 AM | #70 |
07-23-2015, 04:28 PM | #71 |
08-08-2015, 10:44 AM | #72 |
Ok, got a few updates! 1. Replaced the integy crap with the Traxxas aluminum c hubs and knuckles! 2. Got me a set of super nice Creeper Bob TI rear axle shafts! 3. Upgraded my ESC and motor combo to the Axial yeti xl system, so I'm now running 4S! This rig is a freaking BEAST and a blast to drive!!!! |
08-08-2015, 10:54 AM | #73 |
OK, several people where wanting to know the weight of my rig. My rig has just about every heavy metal upgrade you can do other than I am running custom delrin wheels which are probably a little lighter than an aluminum beadlock. With battery: Without battery: |
08-08-2015, 11:07 AM | #74 |
You must have went driving in freshly cut grass? My chassis looks the same. |
08-14-2015, 08:21 AM | #75 |
So, enough with the bench shots!!! Just want you guys to see that I drive it like I stole it! Oops!!! |
08-14-2015, 01:59 PM | #76 |
Newbie Join Date: Feb 2012 Location: Wollongong NSW Australia
Ha ha ha nice Link ends are the sacraficile part |
08-17-2015, 02:28 PM | #77 |
Fun at the skate park!!!! |
12-15-2015, 10:27 PM | #78 |
Newbie Join Date: Jan 2014 Location: New London
I have a question regarding the Currie matched with the slash front end. How did u fix the problem with the diff/ring gear being on opposite sides? Is the slash front diff able to be flipped around? I know the Currie can not be.. Thanks for the help
12-15-2015, 10:44 PM | #79 |
| Re: The First Ever of its Kind! YETIX Buildthread! You flip the slash diff and install these two bearings up front from boca. |
05-16-2016, 10:12 PM | #80 |
Just got my hands on a unicorn! I've wanted this for my yetiX since the day I first built it. Dlux fab made a small batch of currie pumpkins with the large inner bearing mod. I was able to snag one! Also finally got my killer blue wheels from Duuuuuuuuude mounted up! |
The First Ever of its Kind! YETIX Buildthread! - Similar Threads | ||||
New here, kind of!!! | FHMan1905 | Axial Wraith | 3 | 01-19-2012 09:31 AM |
what kind....... | jeepsohigh | Tires and Wheels | 2 | 09-22-2011 06:41 AM |
Kind of new here.... | Flying Dutchman | Colorado | 13 | 08-19-2010 06:34 PM |
what kind are these? where can i get it? | flipcrawler | Tires and Wheels | 9 | 03-17-2008 07:01 PM |
