09-03-2015, 01:09 PM | #61 |
| Re: Bent my first SSD axle today....disappointed
Is it possible to machine the hex pin into the shaft instead of drilling a hole for one? Maybe that would fix it? Sent from my VS986 using Tapatalk |
09-03-2015, 01:38 PM | #62 |
RCC Addict Join Date: Aug 2007 Location: Seattle
If I can't use a Shift hub I'll have to put up with the bending.
09-03-2015, 01:53 PM | #63 | |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: Bent my first SSD axle today....disappointed Quote:
Also its not feasable to machine in the pin, the pins are a totally different material, and very hard-to the point of being brittle. | |
09-03-2015, 02:08 PM | #64 |
What about some heavy duty, steel clamping hexes? They would brace the pin area that seems to be bending.
09-03-2015, 02:30 PM | #65 |
Pebble Pounder Join Date: Dec 2014 Location: Duluth
| Re: Bent my first SSD axle today....disappointed |
09-03-2015, 08:07 PM | #66 |
09-03-2015, 08:43 PM | #67 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
Sooooooo impatient.........
09-05-2015, 05:01 AM | #68 | |
Rock Stacker Join Date: May 2015 Location: central PA
I'm not sure their steel is better than anybody else's. I'll be the ginny pig as soon as I bend the stock axles. I would like them even better if they were not sold in a set, then the price would be better at tempting to me to try them out. Last edited by RustyUs; 09-05-2015 at 05:31 AM. | |
09-06-2015, 04:06 AM | #69 |
RCC Addict Join Date: Oct 2014 Location: UK
Interesting, we will be testing a similar design...
09-16-2015, 12:56 AM | #70 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Confirmed at my LHS today... The VP centered currie shafts will work in the SSD centered Yeti axle for those of you who need a solution while SSD works out the kinks. I don't own this setup, but the measurements on the shafts are identical in the critical dimension from the locker tang to the bearing flange. |
09-16-2015, 10:16 AM | #71 |
Centered yeti or wraith? Two very different lengths
09-16-2015, 10:52 AM | #72 |
Wraith I would assume. Currie is much shorter than the Yeti width SSD.
09-16-2015, 01:40 PM | #73 |
Yes, wraith.
09-16-2015, 02:03 PM | #74 | |
Pebble Pounder Join Date: Feb 2013 Location: Canada
09-17-2015, 08:06 AM | #75 |
So I can't find any Currie axles locally. Only one store here but they carry Vanquish. I was also told Vanquish would not be selling the shafts alone anymore. "If you need a new one you would have to send your damaged one back in order to get it replaced". Wether this is true or not I'm not sure. Not many places on the Web have them right now. A main was the only place I found searching for 5 minutes. Here's a photo of my bent axle shaft. |
09-17-2015, 08:14 AM | #76 |
My local hobby shop has a good relationship with VP and could get them for you. They ship. Call them. Jphracing.com |
09-17-2015, 08:25 AM | #77 | |
Rock Stacker Join Date: Jun 2014 Location: Ontario, Canada
09-17-2015, 08:31 AM | #78 |
Unlock the rear diff - that will help a ton. Yeti's are heavy, and even on 2S a 1/8 power system is a lot of power for a locked diff heavy truck with soft grippy tires. Back in the day I used to race TMaxx's, and tried out a spool in the rear - I started destroying drive shafts left and right. Even upgrading to steel didn't help - I've still got the bent steel shafts in my parts box. Somethings got to give, and it's almost always the axle. After going back to the diff, I even went back to plastic shafts eventually to save weight. Unlocking the rear and using some super thick oil would give most of the benefits of the locked diff but still allow a bit of slip on landings - that should take a lot if not all of the stresses off. |
09-17-2015, 03:55 PM | #79 |
That doesn't sound right. Pretty sure vp will continue to sell them... Sent from my VS986 using Tapatalk |
10-04-2015, 06:00 PM | #80 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
The currie shafts do not work on the wraith Ssd rear axle. They are lacking the collar at the spool end so the wheel hexes rub on the end caps and wear a hole in them and the bearing falls out. I learned the hard way.
Bent my first SSD axle today....disappointed - Similar Threads | ||||
New SSD SCX10 axle housings | STANG KILLA SS | Axial SCX-10 | 1394 | 03-10-2023 08:34 AM |
SSD Rear Axle | Hunter711 | Axial Yeti | 152 | 09-09-2019 12:56 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
Bent an Axle shaft today | JavelinSST390 | HPI Wheely King | 3 | 08-19-2007 06:30 PM |
