10-11-2015, 08:22 AM | #1 |
Pebble Pounder Join Date: Jan 2015 Location: USA!!!
| Issue with unlocked rear
Hey guys, A few weeks ago I decided to run an open rear diff. I originally used orings on the axle shafts and 100000k silicone oil. The orings were not enough to keep the fluid in and it made a mess of the inside of the axle. Someone else recommend silicone ear plugs, the putty kind. I thought this would be a good idea because it won't leak or dry out. At slow speeds everything works great. Once I get on the throttle hard it makes a terrible ratcheting sound, almost like an impact driver. It also goes half as fast as it used too. It also only seems to do it when the wheels are under load. It will not make the noise when it's on the work bench Is it possible the silicone is causing it to lock up too much? Not enough? I'm at a loss. |
10-11-2015, 08:58 AM | #2 |
Rock Stacker Join Date: Aug 2015 Location: jackson
| Re: Issue with unlocked rear
you better take it a part . sounds like the ring and pinion are striped out . the ring gear may have come loose from the diff cup . those little screws are hard to get tight .
10-12-2015, 09:03 PM | #3 |
Rock Stacker Join Date: Jun 2015 Location: SoCal
Yeah, my guess is the ring and pinion skipping or the internal diff gears skipping.
10-13-2015, 06:03 AM | #4 |
Yeah not sure what it was. The ring and pinion showed a little wear but not much at all. Same with the spider gears looked fine but I packed a little more silicone in there and it runs very smooth again. Hurry up weekend
10-13-2015, 08:21 AM | #5 |
| Re: Issue with unlocked rear |
10-15-2015, 08:00 AM | #6 |
I like this option, I hope it proves to be dependable for you. Keep us informed. |
10-15-2015, 09:25 AM | #7 |
Newbie Join Date: Feb 2015 Location: boise
kinda had the same thing happen, it was front ring and pinion. also had the same issue with the unlocked rear, ended up putting the locked diff back in
10-15-2015, 12:42 PM | #8 |
I put a little more silicone in the housing and put it'll together. Ran it hard twice and haven't had any problems
Issue with unlocked rear - Similar Threads | ||||
rs10 rear axle issue | tpain123 | Redcat Crawlers | 5 | 05-16-2011 07:22 AM |
rear motor issue | artl666 | Electronics | 3 | 11-10-2010 09:55 PM |
Is DX3R worth it just to get FWD with unlocked rear | keithgemmill | Newbie General | 15 | 09-26-2010 07:05 AM |
Rear power issue? | lildjloop | RC4WD Bully | 5 | 01-22-2010 10:59 AM |
rear belt issue | b2bomber | General Crawlers | 0 | 08-31-2006 12:45 PM |
