11-08-2015, 05:03 PM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Girlfriend Yeti....
I just bought a stripped down (roller) RTR Yeti. Now, this build will be cheapo. It's only to accompany my K-5 Blazer on scale trails, so no high-power combo, or heavy bashing! I want to know what kind of upgrades I NEED to have.. It's a RTR version, all plastic. It have the STRC knuckle and hubs. I also have , not installed, Vanquish wheel hubs front/rear Vanquish steering bearing upgrade. I haven't open the transmission, but I guess it have metal gear in the transmission.. So, what are the needed upgrade..? |
11-08-2015, 05:06 PM | #2 |
| Re: Girlfriend Yeti....
I have a SW3 combo with a 4600kv Is it too fast, even with the smallest pinion...? Or I could change it for a 35/27T brushed motor! |
11-08-2015, 05:16 PM | #3 |
Pebble Pounder Join Date: May 2010 Location: canada
i run a 5700kv with 16/64 gearing on 2s lipo and its pretty quick (more basher than crawler). i assume a 4600kv with similar gearing should be pretty good. enough speed to entertain yet still enough low speed to have fun on a scale run. I might be completely wrong though haha
11-08-2015, 06:20 PM | #4 |
Newbie Join Date: Sep 2015 Location: Minnesota
I would say the vanquish Bell cranks. With to other upgrades you have listed it will eliminate all slop in the steering.
11-09-2015, 03:21 AM | #5 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
HD gears in the front and rear.
11-09-2015, 09:37 AM | #6 |
Good... I plan to open the diff and tranny to inspect everything.. I will check for HD diff parts!
11-13-2015, 12:20 AM | #7 |
| Re: Girlfriend Yeti.... |
11-13-2015, 03:03 PM | #8 |
Rock Stacker Join Date: Jun 2014 Location: Ontario, Canada
Cool idea with painting the wheels two tone.
11-13-2015, 07:40 PM | #9 |
Newbie Join Date: Jul 2015 Location: Bacchus Marsh, Australia
11-14-2015, 09:24 AM | #10 |
11-14-2015, 09:26 AM | #11 | |
| Re: Girlfriend Yeti.... Quote:
11-14-2015, 05:12 PM | #12 |
Rock Stacker Join Date: Sep 2015 Location: US
I fun a castle 3800kv and that does good all around Sent from my XT1042 using Tapatalk |
11-14-2015, 06:43 PM | #13 |
not bad you won't even notice once there dirty
11-14-2015, 08:06 PM | #14 |
The bright coloured orange spray painted rims look like destruction derby style.
11-15-2015, 02:06 AM | #15 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
After my 1st run with my RTR, on 2S, the hinge pins for the a arms were pretzeled. I had to use a cutoff wheel to cut one of the pins so I could get it off. So I put on one of these CNC Machined Aluminum Front Skid Plate/Hinge-pin mount for Yeti (Black) I also replaced the plastic nut the pins screw into with an actual metal 4mm locknut. I ran a set of stock hinge pins for a couple days until a set of these Carter Fab & Machine » Axial Yeti Hinge Pin Upgrade Kit showed up. When I swapped them out the stock pins were not bent in the slightest. Since then I have run into stuff hard enough to break 3 stock knuckles and one knuckle carrier. The hinge pins are still not bent. |
11-15-2015, 04:53 AM | #16 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
I have the Carter pins as well. Excellent upgrade. I ordered three sets but probably won't need the other 2. Lol Sent from my iPhone using Tapatalk |
11-16-2015, 09:03 AM | #17 |
11-16-2015, 10:19 AM | #18 |
Just shot them.... Since I don't plan on dumping money/time into this RC at the moment... It's only to entertain the girlfriend.. |
11-16-2015, 01:28 PM | #19 |
I bent the carter fab pins. IMO strong arm sleeves are a necessary upgrade. they have a page on facebook.
11-16-2015, 01:46 PM | #20 |
When I search FB for strong arm sleeves I get a page about sleeves for athletes
Girlfriend Yeti.... - Similar Threads | ||||
Girlfriend problem | JRmudmanXJ | Chit Chat | 150 | 01-28-2011 08:04 PM |
Ex Girlfriend | Slowkrawl | Chit Chat | 24 | 11-24-2010 09:29 AM |
the girlfriend pisseroffer | rusty_86 | Tamiya Clod Buster | 10 | 09-01-2008 09:29 PM |
girlfriend issues | TLTCrawlin | Chit Chat | 87 | 08-28-2007 04:17 PM |
