11-24-2015, 10:31 PM | #1 |
Newbie Join Date: Nov 2015 Location: United States
| Why is the rear axel off centered
Just curious what the advantage is to have the rear axle off centered. Isn't that harder on the drive train. Wouldn't a centered axel be better.
11-24-2015, 10:35 PM | #2 |
| Re: Why is the rear axel off centered
edit: The only real advantage is not having to design a new axle. It shouldn't be noticeably harder on the drivetrain. Last edited by Duuuuuuuude; 11-24-2015 at 10:38 PM. |
11-25-2015, 12:15 AM | #3 |
Rock Stacker Join Date: Jun 2015 Location: SoCal
Off center axles are used because they have a lot more clearance with rocks and stuff. The off center diff is not any harder on the drivetrain than a centered one
11-25-2015, 12:52 AM | #4 |
Quarry Creeper Join Date: May 2009 Location: India
Regarding an axle there are two points that touch the ground. Those two points are the two tires. If the diff is located close to the tire (off center), it gives the highest ground clearance at the center of the axle.
11-25-2015, 08:39 AM | #5 |
So for crawlers it's better for axel to be off centered. New bomber has a centered rear axel, I'm guessing then it's meant more for trails and racing, not so much crawling
11-25-2015, 08:59 AM | #6 |
Rock Crawler Join Date: Mar 2015 Location: Waltham
| Re: Why is the rear axel off centered |
11-25-2015, 09:55 AM | #7 |
Rock Stacker Join Date: Nov 2013 Location: Meridian, Idaho
The transfer case is more in line with the diffs on the bomber. That's why the drive shafts look straighter.
11-25-2015, 10:29 AM | #8 |
Tks for clarification, I've never worked on RC or my cars b4 (company cars) so new to vehicles
11-25-2015, 10:31 AM | #9 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
In 1:1s, if a rig has an offset pumpkin, the TCase output is offset as well so the drive shaft is straight. Bomber is a perfect example of this.
Why is the rear axel off centered - Similar Threads | ||||
Rear Axle Not Centered | BHP | Axial SCX-10 | 1 | 10-10-2015 11:41 AM |
VP Yeti Centered Pumpkin Rear | jeb. | Axial Yeti | 6 | 02-23-2015 06:20 PM |
Rc4wd centered rear axle | otis683 | Axial Wraith | 2 | 09-15-2013 09:40 AM |
Advantages to a centered rear pumpkin? | DrDiff952 | Axial Wraith | 3 | 09-15-2013 09:33 AM |
