02-16-2016, 11:39 AM | #1 |
Newbie Join Date: Feb 2016 Location: Kansas City
| My Yeti build in progress
This is my first kit build in ages and I went a little crazy with upgrades. Parts list so far: Axial Yeti 1/10 kit Electronics: Tekin RX8 Gen2 Tekin Pro4HD 3000kv sensored HeyOK No Brainer BEC - Adjustable Turnigy Heavy Duty 5000mAh 3S 60C Lipo TrackStar TS-940HG Brushless Digital Helical Gear High Torque Servo Turnigy Receiver Controlled Switch Vanquish Parts: Clamping Lockouts VPS07670 Front Knuckles VPS06550 Double Sheer Steering Rack Kit VPS07230 Front Caster Blocks VPS07580 Front Skid Plate VPS07890 Steering Rack VPS07231 Bell Crank VPS07810 Front Shock Adjuster VPS07770 AR60 Axle Shock Link Mounts VPS04721 3D Machined Differential Cover VPS03230 Currie Antirock Sway Bar VPS07690 OCP Axle Bearing Caps VPS04740 Wraith Rear Diff Locker VPS05990 Titanium Front Link Kit VPS07200 Titanium Rear Upper Suspension Link Kit VPS07201 Axial Option Parts: 4-Link Mounts Machined AX31165 Shock Mount Plates Machined AX31166 Machined Adjustable Motor Mount Yeti AX31156 Machined Slipper Plate AX31164 Aluminum Servo Horn, 23T AX30834 Machined Sway Bar Clamp #AX31167 Machined Alum Body Post Mount AX31169 STRC Parts: HD FRONT BUMPER MOUNT SPTSTA80093FO Aluminum Shock Caps SPTSTA80035GM Aluminum HD Front Shock Tower SPTSTA31170GM Aluminum HD Rear Cage Stiffener SPTSTA31102RGM Aluminum Lower Shock Spring Retainers SPTSTA80035CGM Aluminum Shock Collar SPTSTA80034GM Misc brand parts: RC4WD Rear Wheel Adapters RC4Z-S1604 RC Screwz Stainless Steel Screw Kit AXI014 RPM Front A-arms RPM70472 Kronik Axle Tubes Stainless BR247052S Full Ball Bearings Set Rubber Sealed YTBBZ Last edited by THX_138; 11-03-2017 at 09:00 AM. Reason: Images wayyyyyyyy too large |
03-04-2016, 08:26 PM | #2 |
| Re: My Yeti build in progress
Long time for an update, Finally got the body finished and even made a custom roof panel and light bar with 2 12v 4.8w cob leds and it's super bright lol. This is the first mock up that my buddy and I are working on, as we get better at it we'll be making some for anyone that would be interested in it. Last edited by THX_138; 11-03-2017 at 08:59 AM. Reason: Images wayyyyyyyy too large |
03-04-2016, 08:48 PM | #3 |
Rock Stacker Join Date: Dec 2014 Location: Tasmania
I need those LED's in my life! Never considered using them before...
03-05-2016, 01:20 PM | #4 |
Thanks guys! Going to try and work on the leds today.
03-05-2016, 01:22 PM | #5 |
| Re: My Yeti build in progress |
03-16-2016, 06:22 AM | #6 |
I ordered a few of those led's, I assume you're just running them directly off of a 3s pack?
07-07-2016, 03:40 PM | #7 |
Servo saver for steering or not??
My Yeti build in progress - Similar Threads | ||||
CF Progress Build | ZoSo | Axial XR10 | 26 | 04-16-2014 05:30 PM |
Wraith build (in progress) | GiantsCheated | Axial Wraith | 16 | 09-09-2013 03:47 PM |
CJ-7 build in progress | KeddeX | Losi Micro-Rock Crawler | 14 | 01-12-2010 01:46 PM |
MY build in progress | TXmade | HPI Wheely King | 1 | 02-21-2008 05:30 AM |
My WK build in progress | Rex4223 | HPI Wheely King | 14 | 05-04-2007 05:57 PM |
