05-10-2016, 10:57 AM | #1 |
Quarry Creeper Join Date: Jul 2015 Location: Winter Park Colorado, 8000Ft Elevation
| My solution for a sagging front end, dual shocks
I have a heavy Yeti due to all of the aluminum and even with the stiffest springs I was still bottoming out way to easily. I tried the Proline shock with their heavy springs but it didn't improve the situation so I got the Vanquish shock re-locator and mounted both the Icons and the Prolines with 25 weight in both. The Prolines are mounted in the normal position and the Icons are mounted on the top into the VP re-locator and at the bottom I simply put a screw into the upper bracket on the T-Bone skid plate. It works great. |
05-10-2016, 10:58 AM | #2 |
| Re: My solution for a sagging front end, dual shocks Sent from my SM-G900V using Tapatalk |
05-10-2016, 01:44 PM | #3 |
Pebble Pounder Join Date: Apr 2010 Location: Charlotte
i just ordered firm springs and i rebuil tmy shocks with the traxxas rebuild kit and 45 wt fluid. Im hoping those will help together. If not Ill get the vanquish shock mount to get them more vertical, THEN is that doesnt work Im going to cut the stock springs and put a super stiff spring on top and do a dual rate setup.
05-10-2016, 02:20 PM | #4 |
What I found was that with the super stiff spring the front end rebounded too quickly and became bouncy. With the thick oil (I tried up to a 70w) the front end became too resistant to absorbing a bump resulting in again too bouncy. With the dual setup I am running medium springs with 20w oil, I can set the droop so the axles are level to the ground and when I drop it from about 18" it just barely bottoms. It worked great for my heavy truck, 9.5 pounds. |
05-10-2016, 02:52 PM | #5 |
after reading this its got me thinking....i have the kit truck and mine came with the dual rate pistons.. i am thinking about rebuilding my fronts with the dual rate pistons tonight and back with 40wt. Ive read a lot of goof things about the RPM dual rates but they are meant for traxxas trucks. I am hoping they will help hold against impact better and still return to top quickly.
05-10-2016, 04:32 PM | #6 |
give it a shot, what can it hurt.
05-11-2016, 02:15 AM | #7 | |
Newbie Join Date: Mar 2016 Location: barstow ca.
| Re: My solution for a sagging front end, dual shocks Quote:
05-11-2016, 06:45 AM | #8 |
| Re: My solution for a sagging front end, dual shocks did you find instructions on setting them up properly? i was gonna just have to do it and hope i guess right
05-11-2016, 08:20 AM | #9 |
| Re: My solution for a sagging front end, dual shocks |
05-11-2016, 09:27 AM | #10 |
05-11-2016, 09:42 AM | #11 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
The RPM pistons are for the type of shock shaft that uses an e clip. Axial uses a nut so you may have to fiddle around a bit. I run the Axial dual rate pistons on the rear with 40wt (PL Prospecs w/32.5wt up front). Honestly, its not that big a difference vs the stock pistons. I've been sitting on a set of RPMs for a while but havent tried em yet...
My solution for a sagging front end, dual shocks - Similar Threads | ||||
Slow shocks: Best Solution? | LAV25 | Newbie General | 4 | 05-02-2008 12:48 PM |
