07-22-2016, 07:26 AM | #21 | |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: A Yeti for the Alllgäu or my little monster Quote:
i will check some options, maybe i find a solution for the loose wheels. first will be 2 nuts... and i will order few different nuts to test..... on next orders Gesendet von meinem T1-A21L mit Tapatalk | |
07-22-2016, 07:59 AM | #22 |
Pebble Pounder Join Date: Feb 2006 Location: Calgary 'Berta
Why are you still running pin drive hubs? Get rid of that garbage and run hex drive.
07-22-2016, 09:19 AM | #23 | |
And Hex mounted Hubs won't solve the Problem of getting loose locknuts. Only thing is that the issue is not so important. Gesendet von meinem Nexus 5 mit Tapatalk | |
07-22-2016, 10:31 AM | #24 |
If it's rubbing on a bearing or anything else it can cause issues. I get rubbing on my rear lock outs and every once and a while the nuts will be a bit loose, I can only assume the pin drive is doing the same thing but worse since you have two pieces of metal in close contact. It could just be needing fresh nuts either way, but I've seen many strange things happen when stuff rubs together
07-22-2016, 12:57 PM | #25 |
I have no Lockout cause of i have ssd wide Diamond axle in the rear. never had issues rubbing against bearing with my Hubs. And the gpm are working perfect with the 11 mm axial Pins. I will order serrated nylock nuts and several others. And test 2 nuts..... Gesendet von meinem Nexus 5 mit Tapatalk |
07-31-2016, 04:08 AM | #26 |
I think i found the nut problem.... The ones i used where serrated but have no nylock..... next week back home i will check this. Also some replacements and new upgrads to install waiting . I'm just thinking about the hot racing adjustable steering rack. Hot Racing Axial Yeti RC Car upgrades and Hop-ups Any one uses this and can tell how the adjustable range is on this? could it adjust to nearly lock? |
08-01-2016, 11:57 AM | #27 |
Back home replacement and New Upgrades arrived Inssion front vdi Vanquish Caster Blocks Ssd rear trailing arm That's today work First issue... Killed both bearings on the innerside .... Have to order New bearings. Just preparing last replacements with bearing oil Fighting to get the inner bearings out Gesendet von meinem Nexus 5 mit Tapatalk Last edited by magic_yeti; 08-01-2016 at 12:03 PM. |
08-01-2016, 12:50 PM | #28 |
Newbie Join Date: Jun 2016 Location: Glen Burnie
Don't bother with the Yeah Racing serrated nuts, while they are serrated and grab they do not have nylon internal locking so they come loose and fall right off. They were a waste of money. Stick with the nuts with the nylon locking and serration.
08-01-2016, 03:18 PM | #29 | |
but they doesn't look so nice Gesendet von meinem T1-A21L mit Tapatalk | |
08-01-2016, 04:55 PM | #30 |
Finished for today Installed SSD Trailingarms, limiting Straps and Hot Raicing lower link mounts Only stock left on the rear are the sway bar, the dif with locker and the Wild Boar. Rear config: SSD Wide Diamond, Hot Racing lower link mounts, SSD Trailingarms, Vanquish titanium upperlinks, GPM Hubs, KBESS limiting straps. HH Torque Master Spool, will be installed next time i open the diff. I think for now i'm finished with the rear, if nothing breaks. Installed inssion vdi, and vanquish caster blocks Next to come is the steering, but first i will start with my lights. Last edited by magic_yeti; 08-01-2016 at 05:10 PM. |
08-03-2016, 11:30 AM | #31 |
Did some diy parts today for my rear swaybar, to replace plastic links. Used m4 threaded rod, 5mm Alu Tube and Traxxas rod ends. Cutted the threaded rod to 33mm and the Alu Tube sleeve has length 21mm. Gesendet von meinem Nexus 5 mit Tapatalk |
08-06-2016, 12:35 PM | #32 |
Unfortunatly no testing this week. After put replacements in. I found another breakeage, caused by my loosen Lock Nut issue. The Pin killed my Hub After arrival of new ones. I faced the next issue. Most of the screws that came with the rims a rounded on my wheels. I recommend never use the gpm screws that came with the parts Ordered New ones from rc-schrauben, but have to get the bad ones still out. Next time..... Gesendet von meinem Nexus 5 mit Tapatalk Last edited by magic_yeti; 08-06-2016 at 12:38 PM. |
08-29-2016, 12:57 PM | #33 |
Last week i had time for more testing. I think locknuts issue is solved, Problem was using only serrated ones without nylock. Screw issue solved i drilled them out with my New Tool ( have to find place in basement otherwise my wife will Kill me) Found New issue with front sway bar, cause the incession cvd has larger diameter than stock. Have to investigate. On full right Turns the front left was Roll and stop with nasty Sound After removing the sway bar it was ok... Have to figure this out. Did some trailing this time and had some water fun Also did some video have to figure out How to cut and Post them. sent by magic_yeti |
08-31-2016, 01:38 AM | #34 |
i'm not sure if my motor turns in the right direction. i have the cc3800kv, how could i check this?. can somebody tell me which cable of the motor is a b and c? second can anyone recommend an really waterproof switch for the mmx esc. my little monster goes crazy after a while, when i have some water fun. Gesendet von meinem T1-A21L mit Tapatalk |
09-13-2016, 04:14 PM | #35 |
new shoes for my little monster. here some weights from left to right vodoo klr 2.2 gold on ssd rockracer with ci dd 6.0 comp cut medium front firm rear axial wildpeak on kit methods / gpm alu with ci dw standard front kit tire rear after market which is lighter than stock. i was impressed that the new combo is lighter than old one. after changing to the incission vdi. i have an issue on full turn right the rotation stops and makes a nasty sound before it continue to rotate. it sounds like “klack“. i don't see any rubbing on full right turn. any idea?. no issues on full left turns. Gesendet von meinem T1-A21L mit Tapatalk |
09-14-2016, 06:04 AM | #36 |
i found out what was wrong regarding the turning issue. i mounted my tbr a-arm skids wrong. too far out so on full turn the skid rubbed on tire inner side. Gesendet von meinem T1-A21L mit Tapatalk |
10-29-2016, 12:54 AM | #37 |
On the first outing with the new shoes , i had the issue that the tire was sliding sideways over the foam inside. this was caused by the wider width of the rockracer wheels. so i ordered ci tuning discs. i used one on the outside per tyre, and now the sliding is gone. i also ordered a few spare parts, like gpm front axle (no issue with the in incisions just in case), for testing vanquish shock adjuster, bearings ..... Also i couldn't resist to get gpm link mounts, need more green The days getting shorter so i started with my lights, and mounted the gearhead leds (roof and front). No major breakages on the last 6 packs, i just started to break the axle pins specially on the front left. I have to get or make better ones. Gesendet von meinem T1-A21L mit Tapatalk Last edited by magic_yeti; 10-29-2016 at 02:29 AM. |
10-29-2016, 05:09 AM | #38 |
Newbie Join Date: May 2016 Location: Australia
Love this thread, keep up the good work!
10-29-2016, 01:35 PM | #39 |
| Re: A Yeti for the Alllgäu or my little monster thanx. Still working on videos. Cuting isn't easy. Finished the first one, will upload it the next days. Today i went out for trail crawling on an Mountainbike downhill track near by. For that i use my tbr roof to mount my action cam on it. Cam mount is doubletaped and screwed to the roof. Roof and Base hold well, but the case of my cam not . A few pictures At the end Yeti car wash you can see the rest of the cam case Cleaned up and heading home killed 3 pins today, china crap i have on hand from my gpm hubs. Have to get definitely new ones. Gesendet von meinem T1-A21L mit Tapatalk |
11-01-2016, 07:04 AM | #40 |
So pin problem should be solved. Bought 2 mm spring steel and made my own. Cheap and easy. Costs 1,20€ time 10 min Time will show if I'm right Tools used Outcome on green new diy pins right side the rest of the old ones sent by magic_yeti |
A Yeti for the Alllgäu or my little monster - Similar Threads | ||||
This is a Monster....Yeti XL is a fitting name!!! | redsawacs | Axial Yeti XL | 198 | 11-29-2017 01:23 PM |
Mamba monster motor in Yeti? | jordanbottle | Axial Yeti | 8 | 06-01-2015 09:55 AM |
Yeti Monster! | twissted | Videos! | 3 | 12-17-2014 02:36 PM |
