![]() | #561 |
I put a longer can 380 from a Redcat. The can contacted in the back with the pinion I used. It can be done if you rotate the motor to the top instead of down.
![]() | #562 |
Rock Stacker Join Date: Dec 2014 Location: tulsa
![]() | #563 |
Anybody know if a traxxas 380 motor fits? Looks long |
![]() | #564 | |
| ![]() Quote:
I didn't run it. I got a pair off fleaBay for Redcat's MOA rig. I think they were billed as 40t, but I don't remember and it wasn't labeled. I put the sticker back in and called it a day. I had stripped 5 bolts and my m2.5 variety bolt bag was getting slim. ![]() | |
![]() | #565 |
Newbie Join Date: Aug 2016 Location: Concord, NC
![]() | #566 |
![]() | #567 | |
| ![]() Quote:
Sent from my SAMSUNG-SM-G890A using Tapatalk | |
![]() | #568 |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
Is the gear mesh held in place only by the top gear cover keeping the motor mount from rotating?
![]() | #569 |
![]() | #570 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
![]() | #571 |
![]() | #572 |
Newbie Join Date: Dec 2016 Location: Mustang, OK
Finally got the Losi pinion gears in today for my Mamba setup! I'm running the 13T, and all of the gear noise I had with the stock pinion is GONE. Definitely a relief! But a better way to adjust the mesh would be a welcome change. There's no telling what goes on in there when you tighten it down. Haven't had it out for an actual top speed run yet, but I can only assume it's going to be pretty wild on 3S, going from 6:1 to 4.6:1. I'm ready for some rear locker action, now! I think that'll be a big improvement. |
![]() | #573 |
I was going to try the longer can 380 I had but I would have to rolled the motor over the top of the spur to make it clear in the back of the chassis. But then it would get tightened down into the spur and there's no way of seeing what will happen to the mesh so I went back to the short can. The Losi 24mm brushless combo I had in there had plenty of power. It just needs less than 4500kV for low speed play. |
![]() | #574 |
Quarry Creeper Join Date: Sep 2016 Location: Canada
My servo setup ..Up right , works awesome still need to trim power wires cos parts where out of my other truck that now is brushless. Also need a balloon over receiver to waterproof it . PS run a servo sever ,will fit one later but now I have a clicking noise in the servo after a crash lol but still works way better than not working at all with crap stock electronics. Fun truck but way over priced for us Canadians ..275 shipped sucks but it is what it is. ![]() ![]() ![]() ![]() ![]() Sent from my SM-G925F using Tapatalk Last edited by Exiwolfman; 12-31-2016 at 03:15 PM. |
![]() | #575 |
Newbie Join Date: Dec 2016 Location: So Cal
This is the only place i can find any decent info. I been on rcshortcourse for a while and been lurking here. Well i bought the score version. After reading through all the pages I was almost regretting my purchase before it got here. Anyway I bought all new electronics and gears before it even got here. Ups showed up yesterday late evening. Unboxed it this morning. Looks pretty impressive so far, figured I'd give it a chance with the stock set up. Charge the battery and take it for a run. Goes for about 1 min then shuts off. Thinking the battery false peaked. Hooked the battery up to my normal charger for my lipos...we will see.
![]() | #576 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
So.......looks like CBERCFAB got some nice tabs for shock options!!! ![]() |
![]() | #577 |
I wanna be Dave ![]() Join Date: Apr 2015 Location: Roseville, Ca
RPP has the score in stock. Axial Yeti Jr. SCORE Trophy Truck 1/18th Scale Electric 4WD - RTR Tower shows late May for both. Lol |
![]() | #578 |
Charged the battery good to go. Like others have stated slow steering. But still running on all the stock stuff.
![]() | #579 | |
| ![]() Quote:
![]() | #580 |
Switched to a spare brushless setup from a losi mini 8. Found a great pinion for 2mm shaft motors- unfortunately it came with a motor, not sure where to get it separately. It's the same pitch as the stock pinion. It's the 9t on the left. Stock center, the right one is a losi mini .5m pinion. ![]() Here's the motor if anyone is in desperate need for the pinion. The motor might not be bad on the jr, didn't try it though. It's a bit smaller diameter. 380BL Ball Bearing Motor-A (Esky Big Lama, with 10, 11T) [EBL015] - US$9.90 : Xtreme Production Official Web Site, RC Helicopters Parts for Helicopters Accessory I've had that pinion a while, looks like it comes with a 10 and 11t now. I don't use this for poking around or pseudo-crawling, but jumping stuff and zipping around my track so I'm not concerned about cogging. But it felt great in my basement, not much cog with the 9t pinion. ![]() |
Axial yeti turned into a score? | 1964yeti | Newbie General | 6 | 08-18-2016 01:47 AM |
Upgrading Axial yeti score | Naosis | Newbie General | 3 | 08-11-2016 06:49 AM |
