![]() | #641 |
I wanna be Dave ![]() Join Date: Apr 2015 Location: Roseville, Ca
Just FYI for anyone wanting to run smaller losi micro pinions (mmx combo), LOSB1260 is 9T-12T pinions.
![]() | #642 |
In case anyone was wondering, the Tactic TX300 radio (from any other Axial RTR) will bind straight to the stock electronics. It feels like a high end radio after using the awful stock one for about 5 minutes. Of course, most people will be tossing more of the stock electronics than just the radio. ![]() |
![]() | #643 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
| ![]() That's really good to know. The battery for my Score Jr. is sitting underneath my desk, charging right now. When it's done, I'll pop the AA batteries into the stock transmitter and take it for its first run. I have a stock RTR radio left over from my Bomber that'll be a good match for my subsequent runs. Thanks for giving this tip.
![]() | #644 |
Rock Stacker Join Date: May 2012 Location: HSV
Everyone! Stop what your doing and immediately slap a new esc that is 3s capable in it and go bash. Holy crap this was a brilliant idea! So freaking fun on 3s
![]() | #645 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
![]() | #646 |
![]() | #647 |
Just broke a rear axle shaft and there seems to be nowhere to get one. I'm not pissed it broke just bummed I can't use the truck till I find a replacement. Watch out for high grip surfaces and extreme brushless power =)
![]() | #648 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
so whats the best servo for this yeti jr something that'll drop right in?thanks
![]() | #649 | |
| ![]() Quote:
I learned today that both the stock servo and the Savox 253 do not like the cold. When I ran the Yeti Jr. last night when it was -4 with the stock servo it stopped moving the wheels. I assumed it was bad, installed the Savox and had the same result. Today, I removed the stock receiver/ESC, installed a different receiver and a Dynamite WP 60A and experienced the same thing when it was 22 degrees. Both servos acted fine (except for not centering) when I ran the truck inside my office building. I have not encountered this with any of my vehicles with full-sized servos. I guess the Yeti Jr. questions my sanity. | |
![]() | #650 | |
| ![]() Quote:
The spring in the servo saver is incredibly weak and is as much to blame for the mushy steering as the weak servo. Any extra steering torque would just be wasted by the servo saver. | |
![]() | #651 |
Picked up a hitec 225mg (67oz at 6v). Standard 24t spline and 2.6mm servo screw. Also picked up losi mrc servo posts.
![]() | #652 |
Quarry Creeper Join Date: Sep 2016 Location: Canada
![]() | #653 | |
| ![]() Quote:
Is it possible that the cold air is causing something else in the steering to contract or bind and overwhelming the small amount of torque generating by the servo? | |
![]() | #654 | |
| ![]() Quote:
Between the plastic tierods, steering rack, and steering link, there is more than enough flex in the steering system to absorb crashes. The ball cups will also pop off in a big enough crash to prevent too much strain on the servo. I have no worries of ruining a quality metal gear servo in this truck (or any of my trucks for that matter) by not running a servo saver. | |
![]() | #655 |
Newbie Join Date: Dec 2016 Location: Norway
I was thinking of using a standard servo horn on Hitec 5085. Is it possible?
![]() | #656 |
anyone have rear axles they can help a brother out with?
![]() | #657 | |
| ![]() Quote:
![]() | #658 |
Hitec is 24T.
![]() | #659 |
just ordered quickrun 1625 brushed esc $23,flysky transmitter, reciever n power HD 1711 servo. if it works out i'll have to order 2 more of everything. i should've stayed in the 1/10 scale
![]() | #660 | |
Newbie Join Date: Jan 2016 Location: Florence
| ![]() Quote:
Ive found that the steering linkages are tight and add to the drag. Next time you remove the servo linkage swing your steering and note how tight it is. Add subzero temps and that plastic would be even tighter. I've spun the ball ends with a ball and some graphite to try to loosen the steering. Helped a bit. Sent from my iPad using Tapatalk | |
Axial yeti turned into a score? | 1964yeti | Newbie General | 6 | 08-18-2016 01:47 AM |
Upgrading Axial yeti score | Naosis | Newbie General | 3 | 08-11-2016 06:49 AM |
