Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Axial 1/18 Yeti (and Yeti Score)
Old 02-08-2017, 09:59 AM   #741
Default Re: Axial 1/18 Yeti (and Yeti Score)
Which pinions work on the hobbywing motors?
2.3 traxxas?
How many teeth should I gear it at?
Dsss is offline   Reply With Quote
Old 02-08-2017, 10:28 AM   #742
I installed a 2445 3000kV sensorless motor. It has a 2.3m shaft and the Losi Mini pinions have a smaller hole than the stock pinion. The stock pinion fit the 3000kV motor and it netted nearly stock speeds. So I dug around in my box of gears and found a 22tooth that fit. I had to file down the set screw so that it's clear the motor plate.
It has good low speed and a fair amount of speed now. I'm happy with it.
Brake Weight is offline   Reply With Quote
Old 02-15-2017, 11:30 AM   #743
Natedog's Avatar
Originally Posted by Dsss View Post
Nice quality setup for good price!
Good info, thanks!
Originally Posted by monkeyracer View Post
Traxxas LaTrax gears DO NOT work. They are a different size, different pitch, etc.
I've got metal lockers coming very soon though.
Bad and good news, thanks!
Old 02-27-2017, 01:30 AM   #744
Any updates Monkey?
SCREAMER is offline   Reply With Quote
Old 02-27-2017, 04:26 AM   #745
Yes,
The first prototypes came in, but were very far off dimensionally from what they needed to be. I had them re-run them with the tweaks, and those were supposed to show up Friday, but didn't, USPS shows maybe today for delivery.
I will probably have something to share tomorrow if these are dimensionally correct.
monkeyracer is offline   Reply With Quote
Old 02-28-2017, 05:24 PM   #746
Made some new trail with the Yeti Jr in mind- bigger berms! A lot less flipping. Moving the battery foward helped too.
My front ring and pinion is starting to slip under heave load, maybe a shim will help. I need to tear it open and check.
TownsendTdi is offline   Reply With Quote
Old 02-28-2017, 08:11 PM   #747
Yes,
First functional prototypes test fit:
I need to get these installed in the yeti and get some testing done to make sure there are no problems. I expect to start a pre-order thread very soon for these. Pricing will be discussed in the upcoming thread in the vendor's section, so please do not ask in this thread.
Old 02-28-2017, 08:23 PM   #748
Are there going to be axles to accompany that beauty?
Lavaheadache is offline   Reply With Quote
Old 03-04-2017, 09:13 PM   #749
I need that. The open diff makes it really hard to do anything with my JR.
robert@castle is offline   Reply With Quote
Old 03-04-2017, 09:49 PM   #750
Same here. I may just try some Silly Putty.
Old 03-05-2017, 09:42 AM   #751
Has anyone replaced the upper rear link with 2 links with balls on the end? I know it kinda acts as a natural sway bar, but I don't like the way when the axle rolls that it bends the tabs on the chassis where the link mounts. I'd like to replace all of the rear links with turnbuckles, I just wondered if anyone know of any that fit.
Old 03-14-2017, 11:07 PM   #752
Any updates Monkeyracer? I'm gonna crack open this rear axle and superglue everything if I can't get a locker soon.
Old 03-15-2017, 07:19 AM   #753
Testing has been going well. There are some slight tweaks to the dimensions to be made, but it looks like I will be starting a Pre-Order thread very soon for these. I'll link to that thread here when I get it posted.
Old 03-21-2017, 06:55 PM   #754
GPM has some aluminum trailing arms out
1/18 Axial Yeti Jr Aluminum Rear Lower Chassis Link Parts GPM MYT014L Black | eBay
Old 03-22-2017, 11:05 AM   #755
Lower links aren't exactly the first thing these things need. Where is the 2 piece front bulkhead to make pinion mesh less of a guess? Where are the metal diffs and axles/shafts? We need those things, not metal trading arms... though they are nice ��
Old 03-22-2017, 11:27 AM   #756
That's the easiest thing to make.
Old 03-22-2017, 03:30 PM   #757
Im Brandon
Brandon's Avatar
Major problem with solid lower links, you wont get any articulation out of the rear. Currently the flex in the nylon links allow for the axle to articulate while also acting as a sway bar. You make that rigid and the only thing the rear axle can do is travel up/down.
Careful buying those.
Originally Posted by TownsendTdi View Post
Brandon is offline   Reply With Quote
Old 03-23-2017, 12:40 AM   #758
Seems like these are fading away. I run mine nearly daily for 10-15m but it's just because it's so small I leave it on the chest freezer in my garage. So it's right there for a quick spin around the driveway. All the hype before the reaease and the novelty is quickly waning.
Old 03-23-2017, 08:58 AM   #759
Unless there is a local track that likes to run mini's the novelty of a mini version of a capable truck is always going to be a novelty. I've got a couple 1/14 Tacon Thrillers that I literally leave in the car in case one of the big cars breaks and I don't want to end my session so quick. LOL...that's about all they are good for.
Dbdynsty25 is offline   Reply With Quote
Old 03-23-2017, 09:07 AM   #760
The fact they came out right before Axial lost the ability to keep anything in stock has a lot to do with it also. Hard to get excited about a truck when no one has been able to buy one for months.
svt923 is offline   Reply With Quote
Axial 1/18 Yeti (and Yeti Score) - Similar Threads
Axial yeti turned into a score? 1964yeti Newbie General 6 08-18-2016 12:47 AM
Upgrading Axial yeti score Naosis Newbie General 3 08-11-2016 05:49 AM
