12-01-2017, 05:11 PM | #101 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Yeti Jr. upgrades
Finally made the move to proper wheels and tires Boom Racing terra beadlocks Rc4wd Wrangler MT/R 1.55 Crawler innovation lil'nova single stage foams Sent from my Nexus 6 using Tapatalk |
12-01-2017, 05:54 PM | #102 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Give an update how those foams fit and your thoughts about how they handle, more/less roll overs, traction, ect. Im looking to get same tires/foams. Thanks!
12-01-2017, 08:28 PM | #103 | |
| Re: Yeti Jr. upgrades Quote:
I'll post some pictures while building them and try to get some tests done before the heavy snow fall. Sent from my Nexus 6 using Tapatalk | |
12-02-2017, 02:51 PM | #104 |
The tires are super soft and the Rubber is as High end as it gets. The stock rc4wd foams are firm and fill the tire completly. They are still squishy on the side walls. The crawler innovation foams are extra hard, single stage. They have no squishiness on the side walls, pretty much wont roll at all. They dont fill the tires there seems to be about 1/8 of an inch, maybe more, of free space. Im not an expert but i guess the CI foams would have more contact with the road so more traction and less roll over due to the hard closed cell design. The stock foams would look bigger and maybe crawl better being softer. I will add pictures when I mount the beadlocks. Sent from my Nexus 6 using Tapatalk Edit : Found out that you need a 2mm socket driver for the scale bolts on the hub. I used an M2.6 screw with a left over aluminium link, the head makes a great scale driver. I added pictures also. Last edited by Jboucher; 12-02-2017 at 08:03 PM. |
12-02-2017, 10:04 PM | #105 |
Just a little bigger than stock. Sent from my Nexus 6 using Tapatalk |
12-04-2017, 09:28 PM | #106 |
With the aluminium parts and wheels, it's getting quite heavy for the stock motor. So lets talk about the last upgrade on this rig : the motor... I have a Traxxas 18T 380 brushed motor. -it's still brushed so would it make a difference? I know most people use the mamba micro X and 0808 4-pole brushless motor -That combo is close to 200$ in Canada so yeah... Last option is this hobbywing 16BL30 esc with a 2438 2-pole brushless motor. -it looks interesting -it's 50$ Can someone with more experience give me some input on all 3 options? Is there a 4th option I didnt see? Thx Sent from my Nexus 6 using Tapatalk |
12-05-2017, 04:57 AM | #107 |
Any motor that will fit. I ended up with a 24xx Banggood brushless combo much like that HobbyWing combo but for less $$. I at first used a small HobbyWing brushed ESC and it’s good for 2-3s. It since got moved to another rig and the cheap BL combo installed. The problem with the brushless cans are the kV. They’re all high, haul ass, and cog at slow speeds for the cheap sensorless. The motor shaft size is also a problem, too. That’s why I went with the 24xx motor. Basically anything that fits the old Losi Mini will work. Any kV between 3000-4000. The HobbyWing brushed ESC. Any Losi Mini combos. |
12-05-2017, 08:19 AM | #108 |
I went with one of the cheap ebay combos with a 3600kv 2838 motor. That size motor is probably the biggest that will fit without major modifications (slight filing of the motor can and/or center bearing block) and 3600kv on 2S will give about the same top end as the stock brushed motor on 3S which I think is perfect for these. A 4 pole motor that size has no problems pushing around a Yeti Jr and barely gets warm doing it. You will need a 48P pinion for a 1/8 inch shaft but Trinity and Robinson Racing make them in 10T to keep the stock gearing. https://www.ebay.com/itm/2838-3600KV...item1a14e9d545 If you get the cheap ebay system, spend the extra few dollars and get the programming card too. There is no way to make adjustments without it. https://www.ebay.com/itm/LED-Program...item489a419cd2 Last edited by svt923; 12-05-2017 at 08:23 AM. |
12-05-2017, 09:42 AM | #109 |
Same thing I got through Banggood and about the same price. The drag brake is crap, but you can set that up through the Tx.
12-05-2017, 10:20 AM | #110 |
All I know is the castle mirco x setup and 4100kv motor with 3s is way to fast and powerful for it. Lol. But damn its so much fun, till it breaks.
12-14-2017, 08:13 AM | #111 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
| Re: Yeti Jr. upgrades |
12-14-2017, 10:46 PM | #112 |
Newbie Join Date: Nov 2017 Location: Canada
| Re: Yeti Jr. upgrades Yeah, I am running this setup in my Sons Jr. and I have it programmed to 60% power. Even with it throttled back i've still replaced all the axles and driveshafts.
12-15-2017, 10:25 AM | #113 |
| Re: Yeti Jr. upgrades I have the throttle punch set to 70% and its still nuts, lol. I picked up CI 1.55" DW foams for stock tires to test and they fit perfect in them. Made the tires a hair taller too. It should help a ton with ballooning and cornering/rolling over. |
12-15-2017, 10:29 AM | #114 |
| Re: Yeti Jr. upgrades Ya I have the whole drivetrain bulletproofed, but the only parts to break are front plastic spiders/outputs and spur. Im tempted to put a gpm spool up front to ditch the last plastic parts but it already sucks at turning.
12-15-2017, 02:09 PM | #115 |
On our yeti Jr Facebook group, there is a guy talking about a set of LaTrax metal open diff gears that could fit the Jr but he didnt try it yet. Sent from my Nexus 6 using Tapatalk |
12-15-2017, 03:18 PM | #116 |
I thought that was brought up in the beginning that they wouldn't work? It would be sweet if they did though.
12-15-2017, 06:08 PM | #117 |
12-15-2017, 09:07 PM | #118 |
Those output cups look like they need to be cut down. But for $8 bucks, I'll give it a try. Hopefully my lhs has those latrax gears in stock.
02-02-2018, 05:00 PM | #119 |
I am having an issue since I installed the GPM locker in the rear. The front tires spin when no load is on them but as soon as I apply any friction, they stop spinning. Can anyone give me an idea of what may be wrong?
02-02-2018, 05:02 PM | #120 |
Something is binding in the gears. I would reopen the whole driveline and check the gears, bearings and shafts. Grab an aluminium driveshaft too, the plastic won't survive long with the locker. Sent from my Nexus 6 using Tapatalk |
Yeti Jr. upgrades - Similar Threads | ||||
Yeti upgrades | emerstride | Axial Yeti | 2 | 07-29-2015 10:12 AM |
