01-25-2017, 10:30 AM | #61 | ||
| Re: I'm at a crossroads...truck selection Quote:
01-25-2017, 12:22 PM | #62 |
No need to cut or vent .Your tires will soon go out of balance or the foams will collapse and fail. That must be why some manufacturers vent wheels I'm glad that 1:1 stuff works on your RC's ! Hang up and Drive |
01-25-2017, 01:12 PM | #63 | |
Newbie Join Date: Mar 2016 Location: Cincy
But if driving on grass and it traction rolls, breaks a hub or a-arm....well then I think that's an issue lol. Looking at different style builds and wheel combos and the vast aftermarket, I'm interested to see what I may like to turn the truck into. Use some 2.8 MT wheels for backyard bashing but make some shock/spring/wheel changes and spend they day crawling. At least that's my idea lol. | |
01-25-2017, 01:38 PM | #64 | ||||
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
01-25-2017, 03:00 PM | #65 |
Rock Crawler Join Date: Mar 2016 Location: HB
The yeti sounds like the best rig for what your interested in doing. Adding a front sway bar and better shocks would be in order for your use. Look into beef tubes to strengthen the rear axle and upgrade the driveshaft to MIP. Balanced jumping is easy to do with a bit of throttle control(I know you don't plan to launch it much). If you were looking to heavily bash it I'd probably recommend you stay away from the yeti unless your wallet likes to thin out. Ive only broke a rear axle/bent shaft, bent plastic trailing arm, the crappy rtr servo/servo arm and a driveshaft all on 3S. I did a bunch of upgrades before I broke much but now my rig is a heavy pig. I do launch my rig 7-8' in the air because that's my driving style. The bomber is a cool option but I personally like the ifs of my yeti over the solid front axle on my bomber. The Rock Rey looks really nice too but there's very limited info out on it because it's so new.
01-25-2017, 04:59 PM | #66 | |||
A replacement pair of foams and tires are only US$16 if they do go bad. Quote:
01-25-2017, 05:25 PM | #67 |
I use the dense (closed)inner foams with the softer (open) and always spin my tires after sitting so the water is flung out. The difference I've seen with proper venting and proper foams is the proverbial night and day. The reason to vent RC tires is quite simple, you can't air them down..... tires, wheels, and foams are a system that work if used properly. I pay about 12.00 per pair of foams(CI DW) tires are 25 to 35 per pair, for ones I run. I rarely use stock foams anymore after learning I offer advice from $$$ and experience and never offended if folks don't listen, as y'all spend YOUR money the way YOU want ! Hang up and Drive Last edited by mikemcE; 01-25-2017 at 05:39 PM. |
01-25-2017, 05:36 PM | #68 | |
Quarry Creeper Join Date: Jul 2013 Location: PA
Proline's site seems to indicate that your wheels are for a stampede/ rustler (1/10 monster and stadium trucks)... Traxxas seems to think the stampede is a MT... So you could possibly have MT tires on your yeti. If you simply want to be right, you have stadium truck tires!!! Elusive? only about a 100,000 people have sensored brushless systems that an "crawl" as well as go fast... Just seems you have never seen one. Hardly a unicorn bud. I'll post the video in the "video" section. I'd agree loose the holes in the wheels, vent the tires and run a closed cell foam in a RC like the yeti. Like many others I've have had great success with Crawler Innovations Deuces Wild's, so he always gets my recommendation! | |
01-25-2017, 06:19 PM | #69 | |
I experimented with black tape on the vents prior to sealing them up, and there was no appreciable difference in their performance. They are well balanced, stick like crazy, don't balloon out at 30 mph, and have that great offset you can't get with the 2.2 wheels. They'll do me for now. And, I am not aware of any aftermarket foams made for this tire/wheel combination, and I am not about to make the effort to hack together foams from another set to fit these. | |
01-25-2017, 06:45 PM | #70 | |
Water in the tires left in over time destroys single cell foam, water trapped inside nonvented unbalances, that's all. Venting wheels only will trap water in I'm also not aware of foams by CI now, but Eddie will make some to try. If YOUR combination works on YOUR rig, that's what's it is all about , along with playing with little trucks ! I will add my 2.8 glued tires with factory foams look like pizza cutters when powered with 3s.... that's why I don't use them on the yeti. Hang up and Drive Last edited by mikemcE; 01-25-2017 at 06:49 PM. | |
01-26-2017, 08:09 AM | #71 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
I have 2.2 badlands with unkown foams because they came with the car. Also came with rtr tires on upgraded axial beadlock wheels with foams by...? I recently ran it in snow and im sure the foams are soaked. Maybe i will try ci foams when these rot. Sucky thing is the badlands are glued to the stock rtr walker evans wheels. Not a fan of how they look, despite being 2.2 they look like tires from a quad or 4 wheeler. Not much sidewall. However they do grip like crazy and the accelleration is nice! But i usually run the rtr tires because it looks better? Little more ground clearance and cusioning too. Smitty i hope you decide on a rig soon! I think we have the same ideas for these and cant wait to see what you do! |
01-26-2017, 11:28 AM | #72 | |||||||
And, I doubt the s5 would fail the moose test. Quote:
01-26-2017, 12:08 PM | #73 |
Yikes, my wife has a grand cherokee lol I have an frs so no rollovers for me haha although, i drive the jeep when its more than just me going anywhere... Been on the fence about getting that jeep yeti body from proline. Leaning more towards aluminum panels though. So uh, smitty? |
01-28-2017, 11:37 AM | #74 |
So I'll probably make some people mad or do a face palm, but once I came across Jang's Shapeshifter project I'm having a hard time looking into the Yeti anymore. Project: ShapeShifter - Stampede 4x4 conversions It's a Stampede 4x4 made into multiple different combinations. The ones that interest me the most are the Chimera B trail truck and Rustler 4x4/Truggy setup. The Stampede or Slash into a "crawler" https://www.youtube.com/watch?v=1f-XmaaMz8k This is similar to my idea of crawling, not hardcore, but something different than high speed bashing. I can swap on longer arms and play with wheel offsets to give it a wider footprint for high speed bashing or go shorter arms and tall crawler tires with a "crawler" motor. I can find Stampede 4x4's at least $100 cheaper than people are asking for their slash 4x4's with similar mods. Stampede is a shorter wheelbase with a HCG chassis decent for crawling setup. Like many have said, the Yeti will take $$$ to beef it up where the stampede/slash is very durable. I needed to sell my slash to get some things pad off, if I didn't have to I may have just converted to HCG chassis and gone from there. Once bonus checks come out, I may pick one up. |
01-30-2017, 11:00 PM | #75 | |
I agree that the slash platform should be more durable than the more complex Yeti. And what the Slash will give up to the Yeti on the rocks, it will give back with higher top speed. A $100 savings at the start should not be enough to sway your decision in any particular direction, as that perceived savings will quickly disappear with repairs, upgrades, and the purchase of new tires, wheels, batteries, bodies, and various electronics. While I admire Jang's ability to re-purpose the traxxas chassis, I don't want to wrench on the truck when switching between venues, beyond perhaps adjusting the spring perches. But, put me down for a Traxxas Rally with an MX28 tire/wheel combo as my next vehicle, to complement my Yeti Score. | |
02-14-2017, 01:26 PM | #76 | |
Back in my shop, I used a leather hole punch to add some holes to the yeti tires, and spun them with the truck on its stand on the floor, a bit of water came out. I invited my son to the shop, where he enthusiastically punched the holes in the tires of his summit. He then tried to hold the truck on a block of wood with one hand as the truck bucked and wobbled and sprayed him with water. I let him do that for a minute or so before telling him he would be much better off just driving it around on the driveway. Oh, and I found out the proline makes closed cell foams for their 2.8" tires, so I am off to order me a set. | |
05-04-2020, 06:45 PM | #77 | |
Newbie Join Date: May 2020
Hi Mike, would the yeti Raptor body fit the slash 4x4? I want use for my slash monster truck with that body without the frames and interiors. Many thanks Sent from my iPhone using Tapatalk | |
05-05-2020, 04:39 AM | #78 |
It might, I think it’s too narrow to cover tires though Hang up and Drive |
05-05-2020, 04:45 AM | #79 |
I run 2.8 trencher. Will be good if it doesn’t. Wheelbase wise ok? Mind posting some shots with the Raptor sit over the slash? Sent from my iPhone using Tapatalk |
05-05-2020, 06:36 AM | #80 |
| Re: I'm at a crossroads...truck selection |
I'm at a crossroads...truck selection - Similar Threads | ||||
Shock selection & locker selection | 701scaler | Axial SCX-10 | 1 | 02-24-2016 09:29 PM |
Carnes Crossroads | Satheddal | South Carolina | 7 | 03-22-2015 03:20 PM |
Newbie at a crossroads | Verewolf | Newbie General | 3 | 08-27-2014 10:54 PM |
Crawling in Carbes crossroads. | Satheddal | South Carolina | 2 | 06-14-2014 08:47 AM |
Carnes crossroads | Arock87 | South Carolina | 8 | 03-30-2014 08:32 PM |
