03-24-2017, 05:35 PM | #1 |
Rock Stacker Join Date: Nov 2016 Location: Fenton
| Electronics
So I got electronics for my yeti and got it all wired up and bond my receiver to transmitter and all I can get is steering no throttle or reverse any help on what I did wrong Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:38 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Electronics
ESC? Servo? Lipo? Calibrate the ESC? sent by magic_yeti |
03-24-2017, 05:41 PM | #3 |
| Re: Electronics
Esc is a tekin rx8 gen 2 servo hitec 7950 receiver spektrum dx4c Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:42 PM | #4 |
| Re: Electronics
Liposuction is brand new freshly charged 3 cell Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:43 PM | #5 |
| Re: Electronics
Did u calibrate it? sent by magic_yeti |
03-24-2017, 05:44 PM | #6 |
| Re: Electronics
No Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:45 PM | #7 |
| Re: Electronics
Do this and try again maybe this helps. sent by magic_yeti |
03-24-2017, 05:45 PM | #8 |
| Re: Electronics
How do i do that Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:47 PM | #9 |
| Re: Electronics
See in the Manual on.my MMX i have to Switch on with full throtlel to start calibrate. But u will find it in the Tekin Manual sent by magic_yeti |
03-24-2017, 05:48 PM | #10 |
| Re: Electronics
Found a YouTube video thank you for all your help Sent from my SM-G920V using Tapatalk |
03-24-2017, 05:50 PM | #11 |
| Re: Electronics
Hope it helps solving the issue sent by magic_yeti |
03-24-2017, 05:51 PM | #12 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: Electronics
Should be a procedure in the instructions, if you don't have instructions look online. Maybe the Tekin website. Usually involves powering up in a different manor, then you have to work the throttle control, and wait for beeps or blinks. It tells the esc where full forward, brake, and reverse are.
03-24-2017, 06:47 PM | #13 |
| Re: Electronics
Thanks guys I got it appreciate all the help ...new to this learning as I go Sent from my SM-G920V using Tapatalk |
03-26-2017, 08:20 AM | #14 |
| Re: Electronics
Alright I'm dealing with a new problem. Everything hooked up running good but now my servo is humming. I a just the trim a hair and it stops. Then when I steer back and forth it starts all over again. Servo is a hitec 7950 Sent from my SM-G920V using Tapatalk |
03-26-2017, 08:42 AM | #15 |
Pebble Pounder Join Date: Jan 2017 Location: Kalispell
| Re: Electronics
I wouldn't worry about it, it seems most digital servos are always "hunting". When you are outside its not really noticeable. I do have a RC vehicle that I replaced the servo's with analog one's because the noise was annoying, and I was never more than 10 feet away from. I did read that the Hitec servo is programmable, do you have a programmer for it? |
03-26-2017, 08:59 AM | #16 |
| Re: Electronics
For no I guess I'll have to look into it. So far I'm not to into them programmers. Got a tekin hotwire that want save changes and the same port is the fan and if I hook the fan up the throttle and reverse quit working Sent from my SM-G920V using Tapatalk |
03-26-2017, 09:00 AM | #17 |
| Re: Electronics
My savöx ist doing the same. Common for digital servos.something with Center POS. Nothing to worry about. sent by magic_yeti |
03-26-2017, 09:05 AM | #18 |
| Re: Electronics
Thanks for the help guys Sent from my SM-G920V using Tapatalk |
Electronics - Similar Threads | ||||
Can someone with a BEC electronics post a picture of electronics please. | mkilci | Axial SCX10 II | 3 | 01-17-2017 05:42 PM |
Electronics help | wsmb | Electronics | 12 | 11-12-2015 10:01 PM |
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
