10-16-2017, 01:38 PM | #141 | |
Newbie Join Date: Oct 2017 Location: Seattle
| Re: From the "tub up" Quote:
Works like a charm, with a bit of Xacto-knife surgery. I originally tried just mounting it with some servo tape to the flat mount, but it kept coming off. Much more secure with this Mamba ESC cage. | |
10-16-2017, 03:17 PM | #142 | |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
I went ahead and ordered it. Can you share a pic? | |
10-22-2017, 06:44 PM | #143 |
Ok, so mounting the MMX is going to be a PITA! The holes on the RPM plate don’t line up. I’ll probably glue the RPM plate to the stock plate and go from there.
10-23-2017, 08:04 AM | #144 |
RCC Addict Join Date: Jun 2016 Location: Germany
Double tape and zip tie easy cheap and clean. no pita just use the correct double tape mine is so sticky that if i have to remove the mmx i'm afraid to break the housing |
10-23-2017, 11:16 AM | #145 |
| Re: From the "tub up" |
10-23-2017, 12:04 PM | #146 |
But you have to remove the paper on the bottom of the mmx if using double tape to mount. my fault i forgot it first time and on a huge hit my mmx came off. sticker was still hold by the tape. that's the reason for the zip tie just in case |
10-23-2017, 04:54 PM | #147 |
| Re: From the "tub up" Sorry, I'll try to post a pic tonight, but the holes lined up perfectly for me. Just my motor mount was in the way, so I had to trim a corner off the ESC cage, and remove one of the mounting points for the ESC switch (there's a mounting point on each side. Just pick one, and remove the other one). What sorts of issues are you running into?
10-23-2017, 07:43 PM | #148 | |
10-27-2017, 05:19 PM | #149 |
Ugh! So close! I need help please. I’ve been at it for days. I’ve got everything installed and mounted,gear mesh is good,2 speed action is good. End points seem to be good, I can change gears by hand easily. Everything turns by hand and rolls across floor smoothly. When I connect battery servos and motor fine but the pinion just spins spur and I can’t get the clutch to engage. I’ve tightened the spring 6-8.5 mm, even tried completely tightening it. Haven’t had this problem with my other rigs so I’m stumped. |
10-27-2017, 06:51 PM | #150 |
Rock Crawler Join Date: Mar 2016 Location: HB
What do you mean by “getting the clutch to engage?” Are you not getting power to the wheels? If you spin the spur manually do the outputs spin?
10-27-2017, 07:08 PM | #151 |
| Re: From the "tub up" I can spin the spur easily by hand and it will spin the transmission shaft turning the wheels.. Under power the spur spins but doesn’t spin the transmission shaft.
10-27-2017, 07:38 PM | #152 |
I’m not sure what spur your running but in the pics on page 3 or 4 it looks like you have both the original style slipper plate(flat washer looking ones) and the vented slipper plates installed. I’d take the washer style ones off and only use the vented style then give it another shot.
10-28-2017, 06:57 AM | #153 |
to check the clutch adjustment put it on the wheels and tide it up to the point where you barley can move the spur. then a little bit more till you can't move it. that's how i did it. all with out movement on the tires. Gesendet von meinem T1-A21L mit Tapatalk |
11-01-2017, 06:55 PM | #154 | |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
I don't know what you had trouble with using the rpm cage. That is precisely how I have my MMX mounted in my Yeti. Works perfect. Everything lines up without issue. I might have had to shave the corner of it like roach said, can't remember. Last edited by Lavaheadache; 11-01-2017 at 07:02 PM. | |
11-02-2017, 02:13 PM | #155 |
I’m recovering from surgery.... will address mounting esc and clutch issues in a week or so.
11-02-2017, 03:20 PM | #156 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
Ouch! All the best! I hope you're doing fine.
11-02-2017, 03:47 PM | #157 |
11-04-2017, 02:00 PM | #158 | |
I tried without “washer style plates” part# ax31059 ,still no go. I’ve tried completely tightening slipper spring, no go. 2 speed transmission shaft spins freely both directions but when I put everything together and apply power, no go, spur just spins. http://www.rccrawler.com/forum/attac...1&d=1509825508 What am I missing? | |
11-04-2017, 02:27 PM | #159 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Last piece on the right, you should have 2. I had tons of problems with my slipper setup on the YXL, and it uses the same slipper parts. The fix was a robinson racing yeti gen 3 slipper set up. |
11-04-2017, 02:28 PM | #160 | |
Gesendet von meinem Nexus 5 mit Tapatalk | |
