11-04-2017, 03:45 PM | #161 | |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: From the "tub up" Quote:
Gesendet von meinem Nexus 5 mit Tapatalk Last edited by magic_yeti; 11-04-2017 at 04:18 PM. | |
11-04-2017, 08:17 PM | #162 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
I just checked the yeti manual and it does only use one, weird. And yes the slipper pads needs to stick to the spur gear. That's the problem. |
11-05-2017, 02:54 PM | #163 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
I am glad I am following this thread, since I didn't know the slipper pads were supposed to be taped to the spur gear. I did the whole motor assembly two days ago, and now have to remove the spur gear and fix this thing. To my great surprise I find that I can't remove the spur gear without either removing the chassis top brace, or the whole motor assembly. Lots of screws for a simple spur gear change, right? Or am I missing something?
11-05-2017, 02:58 PM | #164 |
Depends. It could be made only with dismounting the spur cover. Little tricky to get it out with the brace mounted but possible. Gesendet von meinem Nexus 5 mit Tapatalk |
11-05-2017, 05:34 PM | #165 | |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
It was a lame oversight ( no flaming plz) I’ve “stuck “ the slipper pads to the spur, still no go. I’m still struggling with post surgery issues, so time spent on it is minimal right now. So close to being finished, darn slipper clutch http://www.rccrawler.com/forum/attac...1&d=1509928731 This is what’s in my manual. I’m using the optional parts. Last edited by Cheez; 11-05-2017 at 05:41 PM. | |
11-05-2017, 05:55 PM | #166 | |
Btw, I have 2 YXL’s one kit one rtr ,and an upgraded rtr yeti.... zero clutch problems. | |
11-06-2017, 09:44 AM | #167 |
if you spin the trans input shaft do the t-case output shaft spin? the spur rotation will be transferred to the input shaft by the vented and the other 2 slipper plates check if its working if you spin these. if not some thing in the trans is wrong. if you have 2-speed check that a gear is in. |
11-06-2017, 10:53 AM | #168 | |
http://www.rccrawler.com/forum/attac...1&d=1509990699 | |
11-06-2017, 11:09 AM | #169 |
Rock Crawler Join Date: Mar 2016 Location: HB
Do you have a different spur/slipper combo you can install to test with? The slipper is a pretty basic setup and shouldnt take this much diagnosis. I’d also do all the spin testing from the spur side and not the wheels. Manually rotate the spur, do the outputs rotate, do the wheels rotate? Can you post a video of your testing? There’s probably something small that we are all overlooking. @ this point you may want to disassemble the trans/2 speed and do it over again. Does the input shaft have any play in it? In/out up/down side/side etc?
11-06-2017, 11:14 AM | #170 |
Spin things one @ a time while installing too. Vented plate, spin manually, check that the center hole of the plate has the flats is properly engaged and is oblongged or anything. Hope that makes sense...
11-06-2017, 11:28 AM | #171 |
This may be a dumb question but I’ll throw it out there. Are you supposed to be running a bearing in the center of your spur gear instead of the little plastic bushing that normally goes in that spot? I know my Gen 3 has a bearing there but I’m not sure if it’s necessary or possibly a bad thing on the gear you’re using.
11-06-2017, 12:17 PM | #172 | |
11-06-2017, 12:35 PM | #173 |
Just wasn’t sure. I’ve run my rig on 3S 19/64 gearing with the plastic spur and bushing forever and never had an issue with it. I only ran into heat issues with that gearing. Cheez’s issue has me perplexed big time.
11-06-2017, 01:21 PM | #174 |
Just went through the whole process again, this time removed motor and put back, gear mesh is fine. Once again With spur removed I can spin transmission shaft in both gears and everything rotates smooth and at the same time I can spin wheels both directions in both gears and transmission shaft spins smoothly. Installed clutch per manual and when I manually spin the spur both directions the wheels rotate. When I apply power the #*@# spur just spins. WTF! Giving up on it... Robinson Racing Gen3 Slipper Unit 64T Spur w/Ridged Hub is ordered. Gives me time to recover from surgery anyway. It’s a no budget project anyway, probably should have gone this route to begin with. Hopefully someone out there has a solution for this particular problem and will share with the community. |
11-06-2017, 06:05 PM | #175 |
Good choice. A few things after you get it installed and go for a spin, tighten the nut down tight, its going to slip and break in, which is good but at the same time, the spur gets stupid hot and could toast the bearing, it gets that hot. So keep the spur cover off, take it for some hard pulls and keep the nut locked down, as it breaks in the nut can be tighten even more. After it stops slipping with the nut tight means its broken in and you can slowly back the nut off a hair while doing some more pulls till you like the slip. Then your good to go. |
11-12-2017, 03:56 PM | #176 |
I’m a little more focused now... The RR Gen 3 gave me grief at first but I got it working Entire drive train is running smoothly in both gears (bench test on stand) When shifting it’s not engaging every time, I’ve read that is a common problem with 2 speed transmission when new. I think my end points are good but the Servo is getting pretty hot. SSD 2 speed transmission owners help me out here.... should the Servo (Tactic TSX55) get hot at all? |
11-12-2017, 05:41 PM | #177 | ||
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
I don't see this listed as a 'digital' servo, so you should unplug it immediately. Many of the newer radio receivers will run analog servos but the servo, in trying to keep up with the finer resolution of the new receivers, will overheat and die in short order. You will want to use a tactic '47 or '57. Or something better than tactic . Something waterproof, at least. Last edited by DavidH; 11-12-2017 at 05:48 PM. Reason: titpos | ||
11-12-2017, 06:07 PM | #178 | |
11-12-2017, 06:18 PM | #179 | |
| Re: From the "tub up" Quote: I should be able to finish up this project within a week or so | |
11-13-2017, 06:25 PM | #180 |
Getting closer... Still a couple of minor issues, got an off balance/ wobbling right front wheel .... Waiting on the back order interior and a second body that I’ll paint. Considering 18/64 ratio http://www.rccrawler.com/forum/attac...1&d=1510622571 |
