Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: From the "tub up"
Old 08-18-2017, 09:51 PM   #81
Default Re: From the "tub up"
I have my fingers all over this thing more than my first girlfriend...
My question is (turbodan, I was looking at your post) ssd 2 speed conversion shift lever definitely has a flop. Is AX31183 truly necessary?
http://www.rccrawler.com/forum/attac...1&d=1503114652
Cheez is offline   Reply With Quote
Old 08-19-2017, 10:56 AM   #82
I've always wondered about the differences between a build like this with aluminum everything, vs one with only carefully placed metal bits. I can only imagine that much extra weight will take its toll.
Either way, looks good, hope it runs well!
MiteyF is offline   Reply With Quote
Old 08-21-2017, 05:24 PM   #83
Okay guys, I need help!
Is the axle built wrong? The housing points down and only rotates further down.
Probably something silly, my inexperience is showing
http://www.rccrawler.com/forum/attac...1&d=1503357842
Old 08-21-2017, 11:24 PM   #84
How does it look if you use the lower holes at the axle?
DavidH is offline   Reply With Quote
Old 08-22-2017, 09:00 AM   #85
Yep, wrong hole. Move it to the lower hole. The mounts you are using are actually for the RR10 Bomber.
shiftauto is offline   Reply With Quote
Old 08-22-2017, 03:49 PM   #86
Thanks guys for the input....after disassembling and reassembling every possible combination I find that the lower hole on the axle mount makes only a slight difference. This is the product description for the mount..."Vanquish Products AR60 Dual Shock/Link Mounts for AR60 Axles. Shock and link locations are threaded for easier installation. Designed to work with stock AR60 axle housings as well as Vanquish V2 axle housings". It says nothing about being for the Bomber.
I'm thinking the problem is with the upper links being to short. I unscrewed a rod end on each one and that lessened the axle downward tilt. The threads on the links are stupidly short so in order to get a "normal " looking rear axle I would have to unscrew the four rod ends about 1/2 way off.
So Vanquish titanium upper links are on the way.
Old 08-23-2017, 01:02 PM   #87
Your other option would be to use the longer Jato rod ends but that's just asking for rod end failure. Youll be happy with the VP links. I've only busted 2 rodends in a year and I launch my yeti pretty good
Old 08-24-2017, 10:38 AM   #88
Question for those of you that have SSD 2 speed conversion and Axial shift support AX31183.
My servo tie rod has a tllt of 4-8 degrees, it's just a little less than pictured
( nothing is secure yet). I know it's mentioned that it should be as parallel as possible, but will this be ok?
http://www.rccrawler.com/forum/attac...1&d=1503592649
Old 08-25-2017, 02:29 PM   #89
A shoutout to Chris at SSD getting back to me so quickly regarding this and letting me know that it should be ok.
It's all about bench testing before hittin' da rocky road.
Old 08-25-2017, 06:01 PM   #90
Starting to get tingly looking forward to scratching it up and getting it dirty.
HH motor/esc still weeks away.
http://www.rccrawler.com/forum/attac...1&d=1503705372
Old 08-31-2017, 05:29 PM   #91
Couple of Yeti's hanging out waiting for a motor
http://www.rccrawler.com/forum/attac...1&d=1504222127
Old 09-02-2017, 03:38 PM   #92
Added GPM front sway bar, probably not needed, but what the heck more bling.
This ultimately may be an exercise in futility but maybe not. Minimal crawling/zero jumping. Thinking about going with Pro-Line Ultra Reservoir Shocks 105mm Fr/Re Rock Racers for the front. Seriously considering Motor Option1 x Puller Pro BL 540 Standard 2700kv - Waterproof $125.99 ESC Option1 x Holmes Hobbies TrailMaster BLE Pro Waterproof $134.99
I'm open to opinions.
This is a no budget project but my allowance is slow in coming
http://www.rccrawler.com/forum/attac...1&d=1504388248
Old 09-04-2017, 01:23 PM   #93
Well, if you're goal is a bullet proof yeti it might be, but in the end the journey is the destination, right? I like what you're doing and I sympathize with the slow progress. My funds are slow in coming too, so far I haven't even got the kit yet, but just a very slowly growing pile of upgrades. All part of the fun.
Antsiranean is offline   Reply With Quote
Old 09-05-2017, 10:45 AM   #94
Actually I'm hoping to make it "Bombproof"....HaHa as if that's possible in the RC world.
I'm really enjoying the build, researching wheels and tires now, haven't decided whether to go with panels or body. Maybe both
Looking forward to pictures of your build
Old 09-05-2017, 12:01 PM   #95
Regarding tires may have a look at the hyrax i use them in my AX10. They will be also great at the Yeti with 2 Stage proline foams or CI. The included ones are too soft and without sidewall support. Also nice are the Voodoo klr have the Gold comp. on ssd rockracer.
Bombproof ... Rc ... Yeti never
Gesendet von meinem Nexus 5 mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 09-06-2017, 09:05 AM   #96
http://www.rccrawler.com/forum/attac...1&d=1504710242
Considering these....anyone have them?
Old 09-06-2017, 11:57 AM   #97
Nice looking wheels, they fit your color scheme. just one disadvantage i see, if you have to take of the wheels, it looks like first you have to unscrew the cover (6 screws) to take them off or to tide them again.
Old 09-10-2017, 06:32 PM   #98
Added Pro-Line ultra reservoir 105 mm shocks
Looking forward to seeing how they work out.
http://www.rccrawler.com/forum/attac...1&d=1505089850
Old 09-11-2017, 04:15 PM   #99
Pulled the trigger on these.
Old 09-14-2017, 05:06 PM   #100
Happy to see the mailman today
I plan on going with ottsix Voodoo u-4 silver and CI Deuces Wild.
http://www.rccrawler.com/forum/attac...1&d=1505430144
