Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: axial yeti jr. drivetrain thread
Old 05-03-2017, 05:16 PM   #1
Post axial yeti jr. drivetrain thread
Since there is no subthread for the yeti jr. I made a few threads for different categories. This is drivetrain.(gears, driveshafts, lockers, diffs, etc)
Yeti guy is offline   Reply With Quote
Old 05-14-2017, 11:11 AM   #2
Default Re: axial yeti jr. drivetrain thread
Anyone have any tips for getting the gear mesh right? I've been stuck in a never ending cycle of setting it, screwing down the cover, finding out it's off and repeat.
Cometcyclonemk is offline   Reply With Quote
Old 07-13-2017, 08:36 AM   #3
Use shims
Old 07-18-2017, 01:36 PM   #4
I don't quite follow. The Yeti Jr. Has a little cam drum the motor mounts to. Rotating the cam adjusts the mesh. I can get it to feel great with the cover not tightened down, but never after. It seems like a micro-adjustment takes it from way too loose to way too tight.
Old 07-28-2017, 01:31 AM   #5
Here's how I did mine.
Rotate the cam so that the pinion is above the spur and loose. Tighten the cover down and hope for the best. Hold it down to the ground/floor and ease into the throttle listening for any gear slippage. If none, then make some short runs around the garage listening for the sound of a tight gear mesh. If so, then set it looser and try again. I did this a few times before I got it "right". I just wish there was an aftermarket replacement for this already. But it seems the YJr. is dying off.
Brake Weight is offline   Reply With Quote
axial yeti jr. drivetrain thread - Similar Threads
axial yeti jr. electronics thread Yeti guy Axial Yeti 4 05-28-2017 08:24 AM
axial yeti jr. suspension/steering thread Yeti guy Axial Yeti 0 05-03-2017 05:07 PM
DB's Axial Yeti Build Thread (Deja Vu) Dbdynsty25 Axial Yeti 16 06-13-2016 09:13 AM
Axial yeti xl video thread keebler1510 Axial Yeti XL 1 01-25-2015 04:42 PM
Eritex drivetrain thread........... bob1961 Chit Chat 7 11-19-2011 08:49 PM
