06-01-2017, 06:04 PM | #1 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Rear link mount question
Just got some vanquish trailing arms and rear link mounts. Should I be attaching the sway bar links in the stock position as shown, or the back upper mount position? Sent from my iPhone using Tapatalk |
06-01-2017, 06:05 PM | #2 |
| Re: Rear link mount question Sent from my iPhone using Tapatalk |
06-02-2017, 03:20 AM | #3 |
RCC Addict Join Date: Jun 2016 Location: Germany
I use the HR Mounts which have also diffrent options mounting sway or trailarms. I have the sway at the moment mounted one hole up. But I'm still testing. It just offers more Setup options too play with. Gesendet von meinem Nexus 5 mit Tapatalk |
06-12-2017, 08:39 AM | #4 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
Those are probably Wraith mounts so the hole you're using would be intended for the shock. The upper hole is for the swaybar. The Yeti being a longer wb (and trailing arm) you could use either hole. My goal with swaybar links is to have the bar horizontal at ride height. How vertical you can get the links determines how responsive the bar will be.
Rear link mount question - Similar Threads | ||||
rear link mount. | dragrcr | RC4WD Bully | 1 | 07-26-2010 08:30 AM |
rear link mount | bigblazerboy | Scale Accessories | 4 | 10-28-2007 08:33 AM |
