07-31-2017, 02:20 PM | #1 |
Pebble Pounder Join Date: May 2014 Location: SF
| Yeti and the Mamba X??
Anyone run this in their yeti? It's the new mamba X with a 4600 kv sensors motor? It says up to 5 lbs but I have been reading around and I know guys are running this. Any input, thoughts or suggestions??? |
07-31-2017, 04:55 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Yeti and the Mamba X??
I am still researching alternate motors for the yeti, but I gather they should be in the 2800-3800kv range, depending on vehicle weight and use. Why are you considering 4600kv? |
07-31-2017, 07:05 PM | #3 | |
| Re: Yeti and the Mamba X?? Quote:
Only because it's in the set. I might get a HH motor. I am just undecided. I have basically rebuilt my yeti and the esc/ motor are all that's left. | |
07-31-2017, 07:18 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
I was running a castle sensored motor 1410 3800kv, in my yeti and it was on the slow side for me. My buddy runs a Tekin 4600kv and its crazy perfect haha.
07-31-2017, 08:01 PM | #5 |
| Re: Yeti and the Mamba X?? |
07-31-2017, 10:52 PM | #6 |
What size is the motor? 1406? If so might getter warmer than usual.
08-01-2017, 11:08 AM | #7 | |
Mamba X I'm just curious about how one settles on a kv number, given the manufacturer's recommendations by weight, and the common mantra of 'volt up and gear down for speed'. Is this just to go fast on pavement? 2s? 3s? | |
08-01-2017, 01:24 PM | #8 | |
Like I said, I think I will be switching to a HH motor shortly, like i said. It's is gonna be on 2S. I have different options of places to run. | |
08-01-2017, 06:03 PM | #9 |
If you are switching motors then why even mention or buy the 4600kv? Just ask about the ESC then, and yes the Mamba X will work fine in the Yeti. Like you said your gonna switch to HH motor.
08-06-2017, 04:26 PM | #10 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
Monster X and Puller Pro XL works great in my slightly obese Yeti.
08-06-2017, 10:59 PM | #11 |
After catching the tekin roc412 HD thread in the electronics forum, I'm thinking the Mamba X (for the aux wire) and the roc412 HD 3100kv motor on 3s. This combo should give me the speeds I currently get or better with the current weight of the truck (8 lbs) and fits the recommendations of the manufacturer(s) for crawling and trail use. I'll use the hot wire to turn on the drag brake in low gear; I don't have much cogging now, but with the sensored setup, it will be even smoother, and it should be a lot less sensitive to gearing (compared to the RTR esc/motor). And it frees up the rtr combo for use in another project. |
08-07-2017, 08:37 AM | #12 |
Great combination ! I'm running the older MMP and a Tekin 3100HD, the roc would be an upgrade , and the X wasn't available when I spec'ed mine out. Let us see and know how it works for you Hang up and Drive |
08-07-2017, 03:22 PM | #13 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
Running a MMP & Pro4 4000kv on 3S in my 11lb Yeti. The only time I was concerned of the loads on the ESC was on Trail I at AF'17. It was in the high 80's/low 90'sºF when I started the trail. 99% of the trail was out on the sun exposed rock, and the ESC fan was blazing away nearly the entire time. Motor was warm to the touch, and esc was a tad warmer than the rest of the rig, but never had any issues.
08-07-2017, 03:36 PM | #14 |
ok all the feed back is awesome. i ordered the 412HD 2200kv based off a few recommendations and reading. enough said on that. |
08-07-2017, 05:16 PM | #15 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
What a good choice. Congratulations on your new motor Sent from my iPad using Tapatalk |
Yeti and the Mamba X?? - Similar Threads | ||||
Mamba Max Pro SCT upgrade for Yeti 1:10 | vashan | Axial Yeti | 25 | 05-25-2016 01:49 PM |
Mamba monster motor in Yeti? | jordanbottle | Axial Yeti | 8 | 06-01-2015 09:55 AM |
