08-29-2017, 08:12 PM | #21 |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
| Re: Trailing arm woes
May try to spring for those alloy ones. Depending on what grade of SS they use, that 7075 has a very similar harness and strength. Edit: not that it really solves the stretching endlink problem. Sent from my Nexus 6P using Tapatalk |
08-29-2017, 09:04 PM | #22 |
Exactly - either choice is better than 6061.... JEC/SuperShafty come with Revo ends. RPM plastics are top-of-the-line, if I ever have issues with the Revo ends I'll switch. But the way JEC frenched-in the ends makes for less stress anyway |
09-09-2017, 11:29 AM | #23 |
Well I pulled the trigger on the alloys a couple weeks ago. Just got them in the mail and installed them. I'll keep you guys posted on how they perform. They are a bit narrower than the ssd's. Had to use different ball ends on my shocks. Also a bit shorter. They say it's to move pinion higher, but I know having the pinion and transfer case output at different angles causes driveshaft wear. Guess I'll hope they're smarter than me (most likely are). Sent from my Nexus 6P using Tapatalk |
09-01-2019, 11:31 PM | #24 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Anybody has this trailing arms? https://store.rc4wd.com/Rear-Trailin...10_p_5111.html Is possible to tap to M4 and install Traxxas revo ends? |
Trailing arm woes - Similar Threads | ||||
Wheelbase vs trailing arm length | MNorby | Axial RR10 Bomber | 241 | 07-11-2018 05:15 PM |
Trailing arm length | Cultus | Losi Rock Rey | 5 | 09-01-2017 05:57 PM |
trailing arm links | mookie | Redcat Crawlers | 6 | 07-07-2010 06:43 PM |
Control Arm Woes / rant | JasonJones | Team Losi Comp Crawler | 11 | 07-25-2009 05:49 PM |
