09-06-2017, 04:05 PM | #21 | |
Rock Stacker Join Date: May 2015 Location: central PA
| Re: Baddest motor /esc set up for the Yeti Quote:
I thought I was the only one who enjoyed 20-ish speeds from a flying pig. The baddest motor for the Yeti is the $15 no-name 3660 4300Kv in my ride right now. That motor lets me visually enjoy all that Yeti suspension travel goodness while navigating larger than life obstacles. I can throw a 2S pack in the Yeti's belly and know that I won't be waiting for parts . | |
09-24-2017, 06:10 PM | #22 |
Rock Stacker Join Date: Apr 2016 Location: Fort McMurray, AB, CAN
I run a Holmes Hobbies Puller Pro BL 540 XL 3500kv with a Trailmaster BLE Pro ESC. on stock 16/64 gearing it's mental on 3s. I had it on 20/64 but really it's already fast enough on stock gears.
09-29-2017, 03:22 PM | #23 |
Rock Stacker Join Date: Dec 2015 Location: Deep South
It's hilarious that anyone would feel "disrespect" because of someone's else's opinion/thoughts about a RC vehicle being slow. Hahahahaha!!!! Dude go with the Tekin Pro4 HD 3000kv or the Holmes Hobbies motor with the Castle Monster X ESC (like mentioned previously). You will break parts so be prepared or upgrade some of the vital weak links now. Have fun!
09-29-2017, 04:50 PM | #24 |
RCC Addict Join Date: Jun 2016 Location: Germany
my thought's for a yeti of cause 3s, the yeti depending on his weight it's a 3s rig.. kv should be between 3000 and 4000 kv. rest is left to gering, but i talk about 4pol +. i wouldn't use a 2pol. 2s dr. yekill 3s mr hide i love my little monster. Gesendet von meinem T1-A21L mit Tapatalk |
03-23-2018, 02:38 PM | #25 |
Pebble Pounder Join Date: Jul 2013 Location: BFE
1850kv pro4hd @4s , it is easy to detune.with punch control alone you can easily tune out the axle twisting launch torque while maintaing the power to go plenty fast. Run sensored and you have incredible throttle resolution for low speed. Sent from my SAMSUNG-SM-G891A using Tapatalk |
03-23-2018, 02:56 PM | #26 | |
Great package with 4s, with 3s a 3000Pro4HD is as sweet! Hang up and Drive | |
03-23-2018, 03:01 PM | #27 |
| Re: Baddest motor /esc set up for the Yeti |
03-26-2018, 01:41 AM | #28 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
Just dropped in CC Mamba Monster X and HH puller pro bl 540XL 3500kv... beast mode. Sent from my iPhone using Tapatalk |
03-26-2018, 02:24 AM | #29 | |
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
04-10-2018, 11:04 AM | #30 |
05-01-2018, 09:21 PM | #31 |
Newbie Join Date: Jul 2014 Location: what are you a stalker
I'm running a mamba monster X and a tekin pro4hd 3000kv with a 45c 3s lipo. Has plenty of top speed and will do rolling back flips if your not careful (stock gearing)
05-02-2018, 01:17 AM | #32 |
With adjustable timing in sensored only mode with the tekin speed control line allows for setting up a turbo function. You have control of what rpm it starts, the power curve , and the amount of lag off full throttle that initializes the boost. It is almost literally a 2nd gear. Sent from my SAMSUNG-SM-G891A using Tapatalk |
07-24-2018, 09:43 AM | #33 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
07-24-2018, 10:14 AM | #34 |
Puller Pro 4100kv "R" type 540-L vs XL series... Per Holmes Hobbies site: "Notes: Designed for dominating 1/10th scale U4, rock racing, endurance, G6, trail adventure, and rock crawler situations. Installs into Axial Yeti & Bomber, Losi Rock Rey, Traxxas TRX-4, and similar vehicles. Also makes 4x4 stampedes an airplane. Recommended battery 2s or 3s lipo, 3800mah 35c or greater. Recommended ESC 1/10th or 1/8th scale suitable for 4x4 vehicles. If you get your motor wet, you must clean, dry, and relube bearings to avoid damage." I bought one to go in my overbuilt Bomber, gotta take care of a few build issues before it will be up and running. These are supposed to give better low-speed control than the XL line of HH motors, while still being VERY fast on the top end... The rotor is a hair larger than a XL, but not quite as long - although it's quite a bit longer than a standard 540 Puller Pro. |
07-24-2018, 01:32 PM | #35 |
Rock Crawler Join Date: Mar 2012 Location: UK
The R is a beast, I run one with a MMX in my Yeti on 3s and it’s brutal, but at the same time it’s super smooth at lower speeds
07-24-2018, 03:45 PM | #36 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
maybe I'm the only one with the problem, but I break enough shit with the stock vanguard system on 3s I don't need more torque or speed, I can drift it around my dew covered morning yard with ease as is.
07-24-2018, 11:03 PM | #37 | |
Before the R was announced i was planning to get a XL, changed my mind after i read the description of the R after the announcement. see Durok's post The R fit's without modification and as Curb Crawler say it's a beast on 3S Advantage to the XL i can gear it higher (smaler pinion) for more torque without loosing top speed. And it has incredible low speed control. | |
07-25-2018, 04:04 AM | #38 | |
Did you do anything to the motor to help with wet conditions? Quote:
07-26-2018, 02:10 AM | #39 |
07-30-2018, 07:53 AM | #40 |
Rock Stacker Join Date: Feb 2016 Location: Gorham, Maine
Im running a Sidewinder 8th ECS and a Castle 1512 2650KV on 11.1v.... No issues yet
Baddest motor /esc set up for the Yeti - Similar Threads | ||||
motor/esc for my yeti | desertdude | Axial Yeti | 9 | 03-08-2015 06:34 PM |
Baddest motor/esc | ms4x4outlaws | Formula Offroad | 36 | 12-31-2013 08:11 PM |
baddest Mini-T motor with stock ESC? | JavelinSST390 | Non Crawler RC's | 7 | 03-11-2008 11:15 PM |
