09-12-2017, 12:15 PM | #1 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Dukes Walking Dead ApocaYeti
Welp, my sickness continues.... What started as a scx10 has now grown into a stable... Wroncho, AX10 Ridgecrest, Bomber, Custom Tube Wraith based truggy... and now a Yeti 380 1/10... since June... It started life as an RTR I believe... As I got it, has the 3150kv Vanguard system, Proline beadlocks with r35 compound bajas with dual stage foams, Proline shocks front and rear, proline lightbar with a gearhead roofrack. RC4WD center rear housing with stock diff. Hot racing castor blocks and steering knuckles got thrown in yesterday. It's a blast with 35c 2s batteries in comparison to some of the others, but no faster than my roc412 powered bomber, but infinitely more stable. First question for the yeti thread... I have a 5700 kv 4 pole castle brushless motor... What kind of animal would this thing become with that? I will not ever be crawling the yeti, trailing and bashing exclusive, I have lots of trail trucks. Last edited by DukeMinnix; 02-06-2018 at 07:53 AM. |
09-12-2017, 03:32 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Duke got a Yeti
I suspect that the 5700kv motor will be overheated and overwhelmed by the weight of the yeti. Try a 3s battery with the stock motor before you change the motor out.
09-12-2017, 03:38 PM | #3 |
| Re: Duke got a Yeti I wondered because its designed for buggies and rwd stadium trucks, but I had it laying around so thought what the hell.
09-13-2017, 12:47 PM | #4 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Duke got a Yeti
mine is also a used RTR (with tons of upgrades) still running stock electronics. I run it on 20c 3S all day and I have never had a problem. well it hit thermal cutoff last weekend but it was super hot and going slow over huge rocks didn't help. lots of hard throttling and not much movement lol but yeah 3s will REALLY wake it up! |
09-13-2017, 01:04 PM | #5 | |
| Re: Duke got a Yeti Quote:
09-13-2017, 03:37 PM | #6 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
| Re: Duke got a Yeti
The Yeti is very slow on 2S but is pretty much right on 3S. Doesn't need to go faster than this for rock racing and it's reliable once modified. Doesn't need too much but it definitely needs a full set of metal links.
09-13-2017, 05:56 PM | #7 |
| Re: Duke got a Yeti
I would be careful of running a Yeti on the road. If you do some reading, it seems that many guys have major mechanical issues with them with lots of power on high traction surfaces. On dirt mine has take an amazing amount of thrashing without blinking an eye, but there are loads of stories with snapped axles and chewed up gears and spurs and links being bent or ripped out etc when running on high traction surfaces. Anything that can make it do a wheel stand is likely going to cause problems quickly unfortunately...at least without some expensive, overbuilt CNC bits anyway! Wet roads seem great though; it's a great drift machine in the wet! |
09-14-2017, 07:41 AM | #8 |
| Re: Duke got a Yeti
Some pictures as she sits, I had a set of VP methods with CI foam and Rock Beast IIs sitting, so on they went. The Bajas and proline beadlocks didn't cooperate and kept debeading. Anyhow, enjoy the pics, I'm all ears for needed upgrades. Its going to get trailing arms and uppers donated from the bomber I'm decommissioning. I would like to strengthen the front end up without making it even more nose heavy than it already is. I also am all ears on tuning the castor and camber. It seems off.
09-14-2017, 12:05 PM | #9 |
| Re: Duke got a Yeti
destroyed one of the bell cranks today jumping and thrashing, guess I'll get an order for those in haha
09-14-2017, 02:43 PM | #10 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Duke got a Yeti
first i would sleeve the hinge pins. next would be changing the font chamber and steering links to the kit steel adj. will test next days with the new traxxas trx-4 rods. It looks like a rtr so consider some hd gears for the front and rear diff. also i would change to ssd trailing arms and upper links in the rear. otherwise you will see what breaks. |
09-14-2017, 02:50 PM | #11 | |
09-14-2017, 03:34 PM | #12 |
| Re: Duke got a Yeti
Don't forget to sleeve the hinge pin Gesendet von meinem Nexus 5 mit Tapatalk |
09-15-2017, 12:20 PM | #13 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Duke got a Yeti
You might look another direction for the steering rack. The VP is nice but loses the servo saver and on a basher the weight of the yeti, it's a good idea to keep it. I went with an STRC rack/bellcrank/saver. You can ditch the front plastic steering links and camber links for cheap with traxxas turnbuckles, revo, and jato rodends. Start looking into driveshaft options also. 3S can spin the stock shaft pretty easily, I use MIP. Be ready to replace the servo if it's still running the rtr one.
09-15-2017, 02:15 PM | #14 | |
09-15-2017, 02:40 PM | #15 |
| Re: Duke got a Yeti
Shock oils tend to be terrain and driving style based. I had my setup dialed in pretty good before the rebuild but am trying some stiffer oil because a friend of mine is positive it's going to be better. I'm skeptical, only one way to find out. I ran 45/30 combo for months with good results. I'm basically doubling down on the weights with a 70/60 combo this time around while also messing with the rear upper link locations to see how it does. Unfortunately I haven't had a chance to get my rig out since the rebuild...it needs an outdoor photo shoot before it reclaims the used and abused look.
09-15-2017, 03:58 PM | #16 |
| Re: Duke got a Yeti
HR also have an adj. version. I have 700cst Front 500cst rear which ist approx 60wt/40wt. Gesendet von meinem Nexus 5 mit Tapatalk Last edited by magic_yeti; 09-15-2017 at 04:01 PM. |
09-18-2017, 11:05 AM | #17 | |
so for all you Yeti guys, when/if this castle/axial motor gives up the ghost, what is the go to for all around good running yeti. I really enjoy the way this thing runs, It's right on the edge of being uncontrollable fast. I have a roc412 laying around doing nothing, but I don't feel like that's a good choice for this. | |
09-18-2017, 03:13 PM | #18 |
| Re: Duke got a Yeti
i love my mmx 1410 3800kv combo 5mm but also nice the hh puller xl 3500kv. many options
09-19-2017, 11:58 AM | #19 | |
Get a Mamba X, and then you'll be ready for a sensored motor if and when you want to change out the factory motor. | |
09-19-2017, 01:25 PM | #20 | |
I like the mamba series, heard great things about the mamba X, although I don't own one yet. I have a mmp in my bomber with a roc412 and another going in a custom truggy I'm building. I don't plan to change stock motor and esc until I have to. This is the fun bashing truck. I'll strengthen what breaks and keep on beatin.... although, I am going to do a mini theme build with it, stay tuned for a new thread when all the stuff for it arrives | |
Duke got a Yeti - Similar Threads | ||||
Duke Scaling | meanbgreen | Scale Videos! | 0 | 03-10-2012 10:52 PM |
